vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Mar 31, 2021 at 1:59 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Have you started to wonder what is causing these issues?
    Mooseditty17 likes this.
  2. Mar 31, 2021 at 2:03 PM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Old flash tool worked. New flash tool seems to be the problem.
  3. Mar 31, 2021 at 2:03 PM
    OVTune
    OVTune Well-Known Member
    OVTune
    Was the file provided .VFT or .VFC? What version of vF Tuner was used?
    What version of vF Tuner are you using to make these files? and are they provided in VFC format?
    99% of the bricking cases are coming from files you are providing. (not blaming. Trying to figure out why).
  4. Mar 31, 2021 at 2:09 PM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    I used 1.2.8.1, the last version that makes vft files.
    Everyone wants me to keep them as vft files. That is why I use that version to make the tune files. It is the most up to date for vfts.
    No one has had trouble flashing them with the old flash tool.
    kibo and FCL30 like this.
  5. Mar 31, 2021 at 2:12 PM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    @wiljayhi was using the latest VFTuner and it caused the problem. But when he used the 1.3.2 vf flash tool it worked with no errors.
    He is driving now.
  6. Mar 31, 2021 at 2:13 PM
    OVTune
    OVTune
    This older version software may not be correctly communicating with our server services. While it's unlikely that is the reason, please use the latest version for making files.
    The older flash tool does not do individual vehicle communications and is easy to abuse that is why we have moved away from it.
    There will be a recovery method coming to our new software son.
  7. Mar 31, 2021 at 2:15 PM
    N5J_Taco
    N5J_Taco Well-Known Member
    Soooo all the older 2.0 tunes that I have will NOT work using your new software?
  8. Mar 31, 2021 at 2:16 PM
    Shellshock
    Iowa
    Vft files work with the new software. Vfc files do not work with the old software.
    Rainoffire and tonered like this.
  9. Mar 31, 2021 at 2:17 PM
    OVTune
    OVTune
    no, they should work perfectly fine. I said it's unlikely to be the case but it's better to just update.
    Even the stock files are provided in VFT format and have no problem flashing.
    What I am saying is that PapaRees files have an above average ratio of bricking (unknown as to why) so updating to the lastest version is eliminating one possible cause.
    tonered likes this.
  10. Mar 31, 2021 at 2:17 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Manitoba
    3G, Tuned
  11. Mar 31, 2021 at 2:47 PM
    trdquoc
    trdquoc Well-Known Member
    "Q"
    2020 Cement DCLB TRD-Offroad
    There's an average bricking rate even with your files? The brick rate with the new vFTuner seems to be high (regardless of who's tunes are being used.. but that's just what I've heard, not pointing fingers. I've flashed every version of @PapaRee tunes, not one has had given me any issues.
    kibo and Phich like this.
  12. Mar 31, 2021 at 2:48 PM
    N5J_Taco
    I guess what I don't understand IF @PapaRee is sending out .VFT files made with the 1.2.8.1 old software and I can use older 2.0 .vft files...what is the problem? I'm running the new software and I have tuned several of Paparee's tunes NO issues!
    kibo likes this.
  13. Mar 31, 2021 at 2:50 PM
    OVTune
    OVTune
    omg people nevermind. Do whatever the hell you want.
    No there is no average rate. People brick their ECUs every once in a blue moon. The only difference is our current flasher verifies credentials before allowing you to flash. Since we have got several messages that people have had bad flashes with a kreg / paparee tune (no blaming him) I am asking him to update only to eliminate that as a possibility.
    Bad flashes happened all the time on the old flasher. It's NOT the flasher, it's toyotas relic method of flashing. The only difference is that it was way easier to recover on the old flasher. People brick their ECUs all the time with techstream, Toyotas OEM multi million dollar software tool.
    That same method is being put into the new flasher.
    Mooseditty17, C41n, AZC Edge and 2 others like this.
  14. Mar 31, 2021 at 2:51 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    I have flashed @PapaRee tunes on the last version of flash tool before the big software update. I venture to say I have flashed my truck over 100 times, for testing, and tuning, no issues at all. it seems to me, the issue may be the new software, not the old.
    the old way, is by far more stable, in my opinion but, everyone likes the latest and greatest. yes, there is a risk of abuse but, it is a solid and stable platform, and the tunes and flashes go in and start with no bricking. that is worth the price of admission for me.
    Ski
  15. Mar 31, 2021 at 2:53 PM
    wiljayhi
    Jim
    Manitoba
    3G, Tuned
    Thanks. @PapaRee got it solved using old flash tool to clr DTC and Flash the tune. No problem with tune file.
    wahoobie, Phich and PapaRee like this.
  16. Mar 31, 2021 at 2:54 PM
    trdquoc
    "Q"
    No one was getting mad just asking questions to try to figure out how this witchcraft shit works lol. Have a beer on me!
  17. Mar 31, 2021 at 2:55 PM
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    I’ve also had 2.0 base tune flashes returning unsuccessful messages not just Paparee made tunes.
    Rainoffire and PapaRee like this.
  18. Mar 31, 2021 at 2:55 PM
    wiljayhi
    Jim
    Manitoba
    3G, Tuned
    This is a .vft file that stopped mid-flash using new flasher. @PapaRee got me through it using the old flash tool.
    kibo, PNWTacoma and PapaRee like this.
  19. Mar 31, 2021 at 2:58 PM
    OVTune
    OVTune
    some trucks will never have a problem flashing.
    Other trucks will fail multiple times.
    There is only 1 way to flash these ECUs. So it's not like the new software does it differently than the old.
    I am literally only saying "hey maybe try making the files on the newest version to eliminate that as a possibility" that's it.
    Mr. Nobody, FCL30, Rainoffire and 4 others like this.
  20. Mar 31, 2021 at 3:00 PM
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    I had my radio start end endless reboot the other day right in the middle of a flash. When i started the truck i had a couple of errors.
    Just the radio going wacky screwed up a flash for me.
    And as far as i know, the radio and ecu don't correlate
Thread Status:
