vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Mar 31, 2021 at 3:02 PM
    OVTune
    OVTune Well-Known Member
    OVTune
    Yes they do, power draw. unstable power / voltage, even for a moment is all it takes. Blame toyota that it over writes the boot sector meaning the ECU must be put in reset mode to make flashing again doable. It's toyotas ancient method of thinking. OEMs haven't done this type of crap since....IDK 2003.
    Mr. Nobody, FCL30, Rainoffire and 3 others like this.
  2. Mar 31, 2021 at 3:03 PM
    Shellshock
    Iowa
    You should turn all that off when flashing - lights, radio, etc. anything that pulls power
    Mr. Nobody, pinochle, kibo and 3 others like this.
  3. Mar 31, 2021 at 3:05 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    .vft file provided and version 1.2.9.9.2 (latest) & drivers installed. I had flashed 5 previous .vft files with the vf tool with no problems.
    @PapaRee is making the files in .vft format. Don't know if in .vfc or not.
    It appears that the new flash tool lost contact with the ECU. @PapaRee talked me through getting it fixed and flashed with the old flash tool (1.3.2)
    PapaRee, DES2009 and PNWTacoma like this.
  4. Mar 31, 2021 at 3:13 PM
    OVTune
    OVTune
    To be clear the new flash tool does not lose contact or disconnect from the ECU. Th ECU will send a message to the tool. Simply "good, bad" during a flash.
    Our software will wait for that message.
    It errors out if the ECU sends a message "bad"
    Why that bad occurs
    1. loose connection
    2. unstable voltage
    3. Trying to flash multiple times when you never started the truck
    4. Trying to flash when you are clearing all sorts of things (clear DTC, clear AT, etc) without starting and running the engine, leaving the ECU in a reset state.
  5. Mar 31, 2021 at 3:19 PM
    SubaruTheTacoma
    SubaruTheTacoma SubaruTheTacoma
    Rhys
    USA
    2017 STI Off Road
    HELLA Horns BP-51 ARB Summit SCS Ray 10 And many many others
    this is great to see in writing.
    I always start the truck and let it run for at least 5 minutes after every step
    TSB
    Flash
    Clear values
    Pray the idle doesn’t sound like a sad truck
    Test drive
    AZC Edge and tonered like this.
  6. Mar 31, 2021 at 3:20 PM
    wiljayhi
    Jim
    3G, Tuned
    Thanks for the assistance, Kreg. All good now. I've flashed maybe 20 times using the old flash tool with no problems. I've flashed 6 times with 1 brick-fail using the new flash tool. I'm going to be a little flash-shy going forward. I'm happy it's all working now and the latest tune is great.
    kibo and PapaRee[QUOTED] like this.
  7. Mar 31, 2021 at 3:23 PM
    OVTune
    OVTune
    It's not the first time I've said this. That's why we removed the buttons. People use them way more than necessary. They will return with *crystal* clear instructions on exactly when they should be used.
  8. Mar 31, 2021 at 3:25 PM
    HCFR TACO22
    HCFR TACO22 Well-Known Member
    Vic
    Tampa,FL
    2019 Tacoma SR5 on 33's DCSB
    KDMax Performance Tune
    Well just in my own experience I've flashed @PapaRee tunes on my truck over a dozen times and half also flashed other people's trucks with his tune files using the flash and I can say that not once I've ever ran into a issue. If I did I'm pretty damn sure he'd be able to help me out if so. Keep up the good work papa!
    shotgunbilly420 and PapaRee like this.
  9. Mar 31, 2021 at 3:28 PM
    wiljayhi
    Jim
    3G, Tuned
    Ok, I caan eliminate 2-4 so it probably got a "bad" because of a loose connection. The error message stated that the "openport was not connected or the truck is off" That's why I thought it might have lost connection. I've had good luck up till then with flashing but there's always a 'pucker' factor.
    PapaRee likes this.
  10. Mar 31, 2021 at 3:30 PM
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    Can't turn the head unit off that i know of
    C41n and blitzkrieg3002 like this.
  11. Mar 31, 2021 at 3:34 PM
    OVTune
    OVTune
    Just to be clear I am not saying it is the files, his tunes, or even the software version. I simply am asking to try making them on the newest to eliminate it as a possibility.
    If it was the files, everyone would be bricking. That's clearly not the case.
    The most likely case is connection, drivers, or battery / electrical drain. That is almost surely going to kill a flash attempt.
    regardless a recovery method will be included in our new flasher.
    Mr. Nobody, C41n, Rainoffire and 4 others like this.
  12. Mar 31, 2021 at 3:45 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    There *WAS* a way to turn it off completely in my 2017... I've done it before when flashing. But the most recent time I flashed (many months ago) I could no longer find where to turn off the HU completely.
  13. Mar 31, 2021 at 4:00 PM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    Wow, I just read a bunch of new posts l and am a happy user of @PapaRee tunes. I'm glad to hear that the older software is not the fault and I can stay with it until new features makes sense to upgrade.
    wiljayhi and PapaRee like this.
  14. Mar 31, 2021 at 4:03 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    He is right I make sure everything is off everything
    wahoobie likes this.
  15. Mar 31, 2021 at 4:06 PM
    92ehatch
    Kinley
    Hendersonville NC
    everything is off that can be, blower, lights, i even wait for the brake unit to do its buzz thing.
    However, the only thing you can do with the head unit is turn audio off (which i do) but you can't turn it "off" that i know of.
    Ive flashed so many times its not funny, i did 12 flashes just the last 4 days playing with some fine tunes. It was just that one time, the radio did some weird crap. It even reset my GPS settings when it did it.
    I was just including the information to say that even that event messed up a flash, but it was easily recoverable by just flashing again.
  16. Mar 31, 2021 at 4:06 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Yep, and I've seen the headlights alone pull the battery down 0.2-0.5V.
    Shellshock likes this.
  17. Mar 31, 2021 at 4:09 PM
    LstMinutePanic
    LstMinutePanic Well-Known Member
    Colorado
    2018 Black Tacoma OR DCLB AT
    You can turn the screen off at least. I believe you do so from the "apps" tab, then select "settings", then at the bottom of the screen a button pops up that says "turn screen off". If this isn't the exact step-by-step to follow, it's at least close and should get you there.
  18. Mar 31, 2021 at 4:12 PM
    SubaruTheTacoma
    Rhys
    USA
    2017 STI Off Road
    If someone knows how please let me know the power button just reboots it and the screen off is just ... screen off
    DES2009 likes this.
  19. Mar 31, 2021 at 4:12 PM
    92ehatch
    Kinley
    Hendersonville NC
    yeah, ive done that some, but not always. Its technically still on (the backlight is still lit) its just dim.
    also, the random reboot is something ive seen posted here before, and im at 29k miles, i may mention it to them so its on record
  20. Mar 31, 2021 at 4:14 PM
    shotgunbilly420
    I turn off my screen on my way to work when it's night time helps me see a bit better
Thread Status:
