vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Apr 19, 2021 at 7:15 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No. You're just out of luck. The System ID of your computer likely changed and the REG file no longer works.
    The other option is using the Resets in TS. There are screenshots in the 1st Post of the ECU Update thread.
  2. Apr 19, 2021 at 7:19 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    I should've had the situational awareness to see if they were available with 1.2.9.9.6
    Flashed someone on Friday and because it included an ECU update, I didn't intend to do resets anyway.
    tonered[QUOTED] likes this.
  3. Apr 19, 2021 at 7:21 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If I tried last in 1.2.9.9.4, I have been completely forgetting to try in 1.2.9.9.5. Hahaha!
  4. Apr 19, 2021 at 7:25 AM
    OVTune
    OVTune Well-Known Member
    OVTune
    They work in the latest version of vF Tuner.
    TCU support is *expected* this week (TCU Read, Edit, Flash)
    Heavy Dupree and tonered like this.
  5. Apr 19, 2021 at 7:30 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks!
  6. Apr 19, 2021 at 7:43 AM
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    What are the parameters available to tune within the TCU? Are there parameters that affect when the truck shifts?
  7. Apr 19, 2021 at 1:30 PM
    Soobieajax325
    Soobieajax325 Member
    thanks, i emailed them
  8. Apr 19, 2021 at 6:21 PM
    N5J_Taco
    N5J_Taco Well-Known Member
    @tonered or @OVTune servers down? I'm trying to flash and I get can't connect to credit server error??
  9. Apr 19, 2021 at 6:24 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Big oof
    Shellshock likes this.
  10. Apr 19, 2021 at 6:38 PM
    OVTune
    OVTune
    should be working fine, exit software and try again?
  11. Apr 19, 2021 at 6:53 PM
    AZC Edge
    AZC Edge AZ OTT Tuner
    Eddie
    Arizona
    2020 TRD OR 4x4 DCSB MGM
    Tacoma build stuff Kings all around with adjustable reservoirs SKU: KIN25001-119A-EXT KIN25001-121A-EXT Pakrax sliders https://pakrax.com/products/pakrax-16-current-tacoma-sliders Pakrax tailgate panel https://pakrax.com/collections/toyota-tacoma/products/pakrax-05-current-tacoma-tailgate-panel?variant=30310492569705 Body armor pro series front bumper https://www.bodyarmor4x4.com/product/toyota-tacoma-pro-series-front-bumper/ Westcott roof rack https://westcottdesigns.net/product/toyota-tacoma-3rd-gen-modular-roof-rack/ SPC UCAs https://www.4wheelparts.com/p/specialty-products-upper-control-arm-set-25470/_/R-FCMW-25470 Ironman 4x4 full skids https://ironman4x4america.com/heavy-duty-skid-plate-kit-suited-for-2005-toyota-tacoma/ Rough country 30” light bar w/DRLs https://www.roughcountry.com/30-inch-led-light-bar-70930blkdrl.html Rigid fogs https://www.rigidindustries.com/d-series-pro-spot-surface-mount-black-2-lights-202213.html Voswitch 8-button switch panel https://m.voswitch.com/UV100-Universal-8-Gang-Programmable-Switch-Panel-for-Truck-UTV-Side-by-Side-Boat-p1291994.html Gatorfx tri-fold tonneau https://gatorcovers.com/p/gator-fx-tonneau-cover/v/toyota/tacoma/2020/ Anytime backup and front cam https://www.anytimebackupcamera.com/products/2020-kit 3TPAM powered dash mount https://expeditionessentials.com/collections/frontpage/products/toyota-tacoma-3rd-gen-usb-powered-accessory-mount Fieryred 13k synthetic winch https://fieryred.com/collections/winch/products/12v-13000lbs-synthetic-rope-winch-kit Meso Customs stealth pro 2-button shift knob https://mesocustoms.com/collections/toyota-tacoma-3rd-gen/products/stealth-pro-shift-knob?variant=21433407438961 Meso/Morimoto collab Ultimate Tail Lights https://mesocustoms.com/collections/toyota-tacoma-3rd-gen/products/ultimate-tacoma-tail-lights-full-led AJT key fob https://www.ajtdesign-llc.com/online-store/V1-Fob-Case-c69661004 Victory 4x4 center console molle panels https://www.victory4x4.com/product/VTCC.html Desert Does It Seat Jackers https://desertdoesit.com/collections/toyota/products/2005-2019-toyota-tacoma-1-1-4-front-seat-spacer-lifts-front-of-seat + multi mount panel on passenger seat https://desertdoesit.com/collections/toyota/products/front-multi-mount-panel RXT leaf pack https://iconvehicledynamics.com/accessory/15947/icon-accessories-05-up-tacoma-multi-rate-rxt-leaf-pack-w--add-in-leaf/ Redline hood quicklift elite https://www.redlinetuning.com/2016-Toyota-Tacoma-Hood-QuickLIFT-ELITE-p/21-27015-03.htm Hypertech speedometer calibrator https://hypertech-inc.myshopify.com/pages/product-result?rq=yr_2020~mk_toyota~md_tacoma~wa_3-5l-v6-gas Kicker speakers all around https://www.crutchfield.com/p_20646CC674/Kicker-46CSC674.html https://www.crutchfield.com/p_20646CC693/Kicker-46CSC6934.html Kicker Key 500.1 https://www.crutchfield.com/p_20647KEY50/Kicker-47KEY500-1.html Wireless CarPlay adapter https://cplay2air.com/ Duro bumps front and rear https://durobumps.com/product/3rd-gen-toyota-tacoma-front-bump-stops/ https://durobumps.com/product/3rd-gen-tacoma-rear-bump-stops-3-5-2016/ K&N CAI https://www.knfilters.com/63-9039-performance-air-intake-system 285/75/17 Falken wildpeaks a/t3w https://www.discounttire.com/buy-tires/falken-wildpeak-a-t3w/p/26812 KMC Grenade 17x9 -12mm offset wheels https://www.kmcwheels.com/kmc-grenade-off-road AVS bugflector 2 hood shield https://www.autoventshade.com/bugflector-ii/2020/toyota/tacoma AVS low-profile window visors https://www.autoventshade.com/low-profile-color-match-ventvisor/2020/toyota/tacoma Cheap+effective Amazon front&rear dash cam https://www.amazon.com/dp/B08M9JD55C/ref=cm_sw_r_cp_api_i_5K49S7WFCC5XMAPDDY3E Tailgate lock https://www.amazon.com/dp/B07ZL2WCLD/ref=cm_sw_r_cp_api_i_KYY3FYH3ZS06DYZVDAHT Fumoto valve(easier oil changes) https://www.amazon.com/dp/B085RBL4KW/ref=cm_sw_r_cp_api_i_GPBZJTJ0NTAA85R3G2DY?_encoding=UTF8&psc=1 K&N Premium Oil Filter https://www.amazon.com/dp/B0067ED49C/ref=cm_sw_r_cp_api_i_D5DHE5F27G5CW8HHCC31?_encoding=UTF8&psc=1 Raptor-lined fender flares and rocker panels https://www.amazon.com/dp/B07DGVMWS9/ref=cm_sw_r_cp_api_i_KQXFHYDEVNH49SKTA9P4?_encoding=UTF8&psc=1 Supreme Suspensions D-Ring Shackles https://www.amazon.com/dp/B082PDV9KR/ref=cm_sw_r_cp_api_i_EGX04F00SXJ6MBMCR3NW Heritage grill with lights CMC Arizona Toy Pros Needle bearing -> bushing swap Arizona Toy Pros OTT tune with Mild>Medium throttle by Eddie Erosa/AZC Edge/me!
    Mine's fine. Just credited and tuned a guy about 20 minutes ago with my phone hotspot
  12. Apr 19, 2021 at 7:32 PM
    N5J_Taco
    Nope a big NO GO! I reset everything AT/LV/DTC, reloaded software, tried different USB port and restarted computer. I keep getting unable to connect to credit server operation aborted.
  13. Apr 19, 2021 at 9:10 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I booted up and my Credits updated.
  14. Apr 20, 2021 at 4:33 AM
    OVTune
    OVTune
    What version software are you using?
  15. Apr 20, 2021 at 5:20 AM
    N5J_Taco
    Running 1.2.9.9.6 Update...It was my computer antivirus wasn't letting my computer to talk to yours. Antivirus updated and I didn't know, everything works fine now!
    TacoLarn, mZiggy and tonered like this.
  16. Apr 20, 2021 at 5:37 AM
    mZiggy
    mZiggy Honey badger
    Marc
    Recommend creating an exception within your AV for an entire OVTune folder.
    FCL30, MOC221_ and tonered like this.
  17. Apr 20, 2021 at 5:39 AM
    N5J_Taco
    Yeah I thought I did but missed one I guess! HA!
    tonered likes this.
  18. Apr 20, 2021 at 9:19 AM
    OVTune
    OVTune
    VF Tuner version 1.2.9.9.7 Release
    - Multiple new 3UR-FBE and 3UR-FE ECUs Supported
    - Sequoia/LX/LC 3UR Support
    - 2019 0CP70 0CP80 Tundra Full support
    - Generation 2 Phase 5 ECU TCU Read And Flash Now Supported
    - Generation 2 Phase 5 TCU Read and Upload Functionality
    - Generation 2 Phase 5 TCU Brick Recovery Functionality
    - Generation 2 Phase 5 ECU Brick Recovery Functionality - Update
    - Resources folder (inside installation folder) includes Tuning PDFs - will be continually updated
    - Tacoma 4.0L Manual Transmission 2009+ Support Updated
    We still need more people to readout TCUs and upload them please! it's the only way to get support
    mZiggy, C41n, tonered and 1 other person like this.
  19. Apr 20, 2021 at 9:23 AM
    AZC Edge
    Eddie
    Arizona
    I believe I’ve uploaded the ‘21 04C20 TCU, but I’m unsure. Is that one that you still need? I can also try to make it a point of reading them before tuning to assist!
    tonered likes this.
  20. Apr 20, 2021 at 9:23 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    For 3rd Gens or other models? If so, I will do that for folks that I flash.
    AZC Edge likes this.
Thread Status:
