vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Apr 24, 2021 at 4:38 PM
    AZC Edge
    AZC Edge AZ OTT Tuner
    Eddie
    Arizona
    2020 TRD OR 4x4 DCSB MGM
    Tacoma build stuff Kings all around with adjustable reservoirs SKU: KIN25001-119A-EXT KIN25001-121A-EXT Pakrax sliders https://pakrax.com/products/pakrax-16-current-tacoma-sliders Pakrax tailgate panel https://pakrax.com/collections/toyota-tacoma/products/pakrax-05-current-tacoma-tailgate-panel?variant=30310492569705 Body armor pro series front bumper https://www.bodyarmor4x4.com/product/toyota-tacoma-pro-series-front-bumper/ Westcott roof rack https://westcottdesigns.net/product/toyota-tacoma-3rd-gen-modular-roof-rack/ SPC UCAs https://www.4wheelparts.com/p/specialty-products-upper-control-arm-set-25470/_/R-FCMW-25470 Ironman 4x4 full skids https://ironman4x4america.com/heavy-duty-skid-plate-kit-suited-for-2005-toyota-tacoma/ Rough country 30” light bar w/DRLs https://www.roughcountry.com/30-inch-led-light-bar-70930blkdrl.html Rigid fogs https://www.rigidindustries.com/d-series-pro-spot-surface-mount-black-2-lights-202213.html Voswitch 8-button switch panel https://m.voswitch.com/UV100-Universal-8-Gang-Programmable-Switch-Panel-for-Truck-UTV-Side-by-Side-Boat-p1291994.html Gatorfx tri-fold tonneau https://gatorcovers.com/p/gator-fx-tonneau-cover/v/toyota/tacoma/2020/ Anytime backup and front cam https://www.anytimebackupcamera.com/products/2020-kit 3TPAM powered dash mount https://expeditionessentials.com/collections/frontpage/products/toyota-tacoma-3rd-gen-usb-powered-accessory-mount Fieryred 13k synthetic winch https://fieryred.com/collections/winch/products/12v-13000lbs-synthetic-rope-winch-kit Meso Customs stealth pro 2-button shift knob https://mesocustoms.com/collections/toyota-tacoma-3rd-gen/products/stealth-pro-shift-knob?variant=21433407438961 Meso/Morimoto collab Ultimate Tail Lights https://mesocustoms.com/collections/toyota-tacoma-3rd-gen/products/ultimate-tacoma-tail-lights-full-led AJT key fob https://www.ajtdesign-llc.com/online-store/V1-Fob-Case-c69661004 Victory 4x4 center console molle panels https://www.victory4x4.com/product/VTCC.html Desert Does It Seat Jackers https://desertdoesit.com/collections/toyota/products/2005-2019-toyota-tacoma-1-1-4-front-seat-spacer-lifts-front-of-seat + multi mount panel on passenger seat https://desertdoesit.com/collections/toyota/products/front-multi-mount-panel RXT leaf pack https://iconvehicledynamics.com/accessory/15947/icon-accessories-05-up-tacoma-multi-rate-rxt-leaf-pack-w--add-in-leaf/ Redline hood quicklift elite https://www.redlinetuning.com/2016-Toyota-Tacoma-Hood-QuickLIFT-ELITE-p/21-27015-03.htm Hypertech speedometer calibrator https://hypertech-inc.myshopify.com/pages/product-result?rq=yr_2020~mk_toyota~md_tacoma~wa_3-5l-v6-gas Kicker speakers all around https://www.crutchfield.com/p_20646CC674/Kicker-46CSC674.html https://www.crutchfield.com/p_20646CC693/Kicker-46CSC6934.html Kicker Key 500.1 https://www.crutchfield.com/p_20647KEY50/Kicker-47KEY500-1.html Wireless CarPlay adapter https://cplay2air.com/ Duro bumps front and rear https://durobumps.com/product/3rd-gen-toyota-tacoma-front-bump-stops/ https://durobumps.com/product/3rd-gen-tacoma-rear-bump-stops-3-5-2016/ K&N CAI https://www.knfilters.com/63-9039-performance-air-intake-system 285/75/17 Falken wildpeaks a/t3w https://www.discounttire.com/buy-tires/falken-wildpeak-a-t3w/p/26812 KMC Grenade 17x9 -12mm offset wheels https://www.kmcwheels.com/kmc-grenade-off-road AVS bugflector 2 hood shield https://www.autoventshade.com/bugflector-ii/2020/toyota/tacoma AVS low-profile window visors https://www.autoventshade.com/low-profile-color-match-ventvisor/2020/toyota/tacoma Cheap+effective Amazon front&rear dash cam https://www.amazon.com/dp/B08M9JD55C/ref=cm_sw_r_cp_api_i_5K49S7WFCC5XMAPDDY3E Tailgate lock https://www.amazon.com/dp/B07ZL2WCLD/ref=cm_sw_r_cp_api_i_KYY3FYH3ZS06DYZVDAHT Fumoto valve(easier oil changes) https://www.amazon.com/dp/B085RBL4KW/ref=cm_sw_r_cp_api_i_GPBZJTJ0NTAA85R3G2DY?_encoding=UTF8&psc=1 K&N Premium Oil Filter https://www.amazon.com/dp/B0067ED49C/ref=cm_sw_r_cp_api_i_D5DHE5F27G5CW8HHCC31?_encoding=UTF8&psc=1 Raptor-lined fender flares and rocker panels https://www.amazon.com/dp/B07DGVMWS9/ref=cm_sw_r_cp_api_i_KQXFHYDEVNH49SKTA9P4?_encoding=UTF8&psc=1 Supreme Suspensions D-Ring Shackles https://www.amazon.com/dp/B082PDV9KR/ref=cm_sw_r_cp_api_i_EGX04F00SXJ6MBMCR3NW Heritage grill with lights CMC Arizona Toy Pros Needle bearing -> bushing swap Arizona Toy Pros OTT tune with Mild>Medium throttle by Eddie Erosa/AZC Edge/me!
    Hmm. All I can think of is the recent server outage, but that's really odd that it's not just simply showing your ECU ID. May be a new bug?
  2. Apr 24, 2021 at 4:49 PM
    OVTune
    OVTune Well-Known Member
    OVTune
    9999999 percent of the time this happens because the file you're trying to flash doesn't match your ECU ID.
    Does KD/Paparee REQUEST IDs before sending files? I ask because we see this happening so often with his files (people emailing us about it).
    This isnt server related, bugs etc
  3. Apr 24, 2021 at 4:52 PM
    redskinz10
    redskinz10 Member
    16 TRD offroad
    Just checked on my truck and it's showing now. I reinstalled current vf and it's good to go.
  4. Apr 24, 2021 at 4:53 PM
    OVTune
    OVTune
    Verify your ECU ID matches the file you are trying to flash if it isn't working.
    SaBiN's Blue Bandit likes this.
  5. Apr 24, 2021 at 4:54 PM
    redskinz10
    redskinz10 Member
    16 TRD offroad
    They send you the ID that you requested
  6. Apr 24, 2021 at 5:38 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Those are the Stock files that are available and supported in the installation folder. Not updated Tune Packs.
  7. Apr 25, 2021 at 4:39 AM
    Adventure OffRoad
    Adventure OffRoad Member
    2020 TRD Tacoma
    No, but I'll past it along to him and see what I can find. Thanks for the info.
  8. Apr 25, 2021 at 6:32 AM
    OVTune
    OVTune
    Server maintenance this morning, adding some things to prevent future interruptions
  9. Apr 25, 2021 at 6:45 AM
    SubaruTheTacoma
    SubaruTheTacoma SubaruTheTacoma
    Rhys
    USA
    2017 STI Off Road
    HELLA Horns BP-51 ARB Summit SCS Ray 10 And many many others
    @OVTune when do you think it will be back up? I have a 0700 pst appointment to tune
  10. Apr 25, 2021 at 6:47 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Just gonna have to past the word to customer it's outta your hands
  11. Apr 25, 2021 at 6:50 AM
    SubaruTheTacoma
    Rhys
    USA
    2017 STI Off Road
    Ya this is correct I was just wondering if it’s like a oh hey hang out 20 min or a oh hey sorry we need to reschedule for a few hours from now
  12. Apr 25, 2021 at 6:55 AM
    shotgunbilly420
    Yeah I would tell em exactly what's going on server issues and reschedule sorry for the inconveniences
  13. Apr 25, 2021 at 6:56 AM
    SubaruTheTacoma
    Rhys
    USA
    2017 STI Off Road
    Ooooofffff
  14. Apr 25, 2021 at 7:04 AM
    SubaruTheTacoma
    Rhys
    USA
    2017 STI Off Road
    I dunno I guess a heads up last night or a time frame on down time.
    kinda hard to reschedule with 30 minutes notice when some of my clients come from far away.
    I do understand why this is happening and I am happy it is just a warning would have been cool
  15. Apr 25, 2021 at 7:06 AM
    shotgunbilly420
    Yeah a heads up is always nice
  16. Apr 25, 2021 at 7:18 AM
    OVTune
    OVTune
    If it's for VIN registering only it should work fine right now, but if it's registering master keys it won't at the moment.
    Easy to test just connect to your own truck.
    And this is being done just to help prevent future interruptions, even though our server is very rarely offline.
  17. Apr 25, 2021 at 7:26 AM
    SubaruTheTacoma
    Rhys
    USA
    2017 STI Off Road
    Yes it works thank you!!!
    kibo, shotgunbilly420 and tonered like this.
  18. Apr 25, 2021 at 7:30 AM
    Adventure OffRoad
    2020 TRD Tacoma
    Here's a screenshot of what I'm seeing. The ID does not match.
  19. Apr 25, 2021 at 7:31 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You need to flash the TSB to get to 04B81. You cannot flash an 04B81 tune on to an 04B80 ECU.
    G8R_Taco and shotgunbilly420 like this.
  20. Apr 25, 2021 at 7:32 AM
    Adventure OffRoad
    2020 TRD Tacoma
    Looking through the forum post about the instructions to update now...
    tonered[QUOTED] and ktbell444 like this.
Thread Status:
