vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. May 29, 2021 at 8:46 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I do not remember that one. Deleted thread?
  2. May 29, 2021 at 8:53 AM
    Shellshock
    Iowa
    ihatemytruck and RushT like this.
  3. May 29, 2021 at 9:41 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Is there anyone with dump tubes, and has vF and the means to edit their own tune who has codes for o2 sensors who is willing to test this? Or just anyone at all who has codes for the sensors.
    My code is intermittent with catted downpipes and o2 sensor spacers with mini cats from Fabspeed.
  4. May 29, 2021 at 10:01 AM
    trdquoc
    trdquoc Well-Known Member
    "Q"
    2020 Cement DCLB TRD-Offroad
    I beg to differ... that’s just my opinion. You have to factor in rolling mass of tires and what not as well even with gear ratios.
    Rotational mass calculations are very different and you can’t just up size gear and down size tire. Even though the rolling distances might be the same with gear/tire combinations you can’t disregard spinning a 60-70 pound tire versus a 30-40 pound tire.
    Whatever makes you happy, I don’t judge.
  5. May 29, 2021 at 10:04 AM
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Run a base tune first: then run the remaining.
    @DownhillDragon run the stocker and yours on the same tune to see what 5.29s really do for you. Similar tires if ya can. Always wondered how much more gets to the ground with gears.
    Bastek and TermLimits like this.
  6. May 29, 2021 at 10:09 AM
    Shellshock
    Iowa
    @tonered is talking about stock mt vs stock at
    An AT needs 5.29 to have similar final drive ratio as MT. Just accounting for the drivetrain.
  7. May 29, 2021 at 10:37 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I said stock tires? Literally: ". . . 5.29s and stock tires. . ."
    To be clear, for comparison purposes, the diff gears don't matter that much.
    Beyond that, lighter wheels and tires will show more subtle changes in the curves.
    Regardless, I don't judge either.
    I was talking about an AT with 5.29s and stock tires versus a stock MT.
    With 5.29s, the overall ratios are close to the MTs.
  8. May 29, 2021 at 10:40 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  9. May 29, 2021 at 11:02 AM
    Shellshock
    Iowa
    Yeah I was thinking 4.88 for some reason. It’s 5.29 to be equal ish
    tonered[QUOTED] likes this.
  10. May 29, 2021 at 11:10 AM
    trdquoc
    "Q"
    You know my mind completely farted... I was thinking all terrains and mud terrains... and didn't realize you meant Auto Trans vs Manual Trans lol
    C41n, tonered[QUOTED] and Shellshock like this.
  11. May 29, 2021 at 1:42 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It's all good!
    :hattip:
    Hahahaha! Dammit. We need different names for this shit!
    :cheers:
  12. May 29, 2021 at 4:45 PM
    DownhillDragon
    DownhillDragon Well-Known Member
    Brody
    Austin, TX
    2017 Tacoma TRD Pro AT Cement - POWERTHIRST v2.4 Tuned
    POWERTHIRST Tuned - My Custom OVTune SSO Slimline Bumper with Stage 2 Kit + BajaDesigns 20" Light bar with Amber Backlight + Smittybilt Winch x2o 10,000lb Synthetic CaliRaisedLED Step Edition Rock Sliders SUSPENSION FRONT A.D.S. - 2.5 Adjustable Dampening Remote Resi Fronts Dirt King Upper Control Arms SUSPENSION REAR A.D.S - 2.5 Smoothie Piggy Back "Rear" Shock With Compression Adjuster Deaver Leaf Pack Cab Mount Relocate by Triple-C Chop Shop, Lago Vista, TX Nitro Gear 5.29 BFG KM3 35x12.5x17 Fuel Rebel6 17" Wheels + Full-size Spare + Rhino-Rack Spare Wheel Strap 4x Rigid Cube Ditch Lights + Cali Raised Ditch Light Hood Mount Brackets + Cali Raised Ditch Light Extension Brackets + 3x Cali Raised Switches + Light Switch Mount Bracket Snugtop Camper Shell with Carpeted Ceiling and Mounting Tracks Prinsu Top Rack and Cab Rack Hi-lift Jack + Hi-lift Jack Mount on roof DEFEND INDUST Recovery Traction Tracks (knockoff Maxtrax) Trimax ST30 Trimaflex Spare Tire Cable Lock (Round Key) 36" x 12mm K&N Intake Canvas 270 RV Awning Rooftop Sun Shelter + Prinsu Awning Brackets Fire Extinguisher w/mount Campbell Hausfeld FP209499AV - 3 Gallon Air Compressor
    I got confirmation, I WILL have a bone-stock TRD OR to do the official pulls. I will ALSO bring two of my old wheels/tires (Pro wheels with 33" BFG K02s) to throw on the rear and do a run of my truck to have a baseline, since I will be ditching my K&N warm-air intake and swapping to a Volant intake w/ram air, and want to be able to compare, and tune for the new intake. Then soon... I'm going to get the Magnusson SC and start really going off the deep end.
  13. May 29, 2021 at 4:51 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Still willing to throw Coyoza into the mix if you want. Up to you.
    Regardless, I recommend jumping between two stock trucks for as many dyno runs as you appear to plan to do, to try to let the trucks cool a bit between runs, swapping back and forth. And documenting run number and ambient temp and other data for each run. Smoothing factor, elevation, octane...
  14. May 30, 2021 at 9:01 AM
    Soobieajax325
    Soobieajax325 Member
    Anyone having trouble unlocking an ecu id? I have sufficient credits and never had a problem unlocking id’s before
  15. May 30, 2021 at 9:06 AM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Are you on the latest version?
    tonered likes this.
  16. May 30, 2021 at 9:06 AM
    Shellshock
    Iowa
    And online
    tonered likes this.
  17. May 30, 2021 at 9:06 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's kinda hard to test with spending credits.
    If you click on one of your Unlocked ECU IDs, you can get a download option. I have no idea what the DL is, but I am assuming it is a good way to test that the Credit Server is solid.
  18. May 30, 2021 at 9:31 AM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    still 1.2.9.9.9 ? looking for that extra 0.0.0.0.1 to make 1.3.0.0.0 please.
  19. May 30, 2021 at 9:43 AM
    Shellshock
    Iowa
    Current is 1.2.9.9.901
    C41n and GoldenBrew[QUOTED] like this.
  20. May 30, 2021 at 12:18 PM
    DownhillDragon
    Brody
    Austin, TX
    I'm on the super-secret 1.2.9.9.9.9.9.9.9.9.9.9.9.9.9.9.9.9.9.9.9.9.9.9.9.9.9.9.9.9.9
    C41n and Mooseditty17 like this.
Thread Status:
