vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Jun 7, 2020 at 7:04 AM
    #1561
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    There is more than one 91 Octane tune for a stock truck? I saw different tunes for people who have made exhaust modifications like removing catalytic converters, but I have no intention in that direction.
    87 octane with octane learning sounds like a good option. I am sometimes in remote areas where premium gas is not obtainable.
  2. Jun 7, 2020 at 7:11 AM
    #1562
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Yes there is the 91 base tune and the SFOB tune (performance) You would get the best benefit running a 91 version of the tune regardless. If you have to use regular gas for some reason your truck may run a little funny for a short while until the "octane learning" feature of the tune makes the correction.
  3. Jun 7, 2020 at 7:12 AM
    #1563
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    I'm partial to SFOB Reg with premium fuel in tank. You will hear a wide variety of recommendations. Which is why we generally recommend for people to try various tunes out for themselves and decide from there
    fatboyfirebass likes this.
  4. Jun 7, 2020 at 2:35 PM
    #1564
    SouthtownTaco
    SouthtownTaco Well-Known Member
    San Antonio, TX
    2016 TRD Offroad
    RCI Under Armor, Tailgate Lock, Bakflip F1, derped grill
    Hey guys. I returned my dongle so I can't launch PCMFlashUtility anymore. Selecting P5Flash Utility doesn't do anything. How can I identify my ECU ID?
  5. Jun 7, 2020 at 2:44 PM
    #1565
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    Make sure you turn off your anti-virus and/or add exception to ovtune's folder. P5f probably got quarantined.
    SouthtownTaco[QUOTED] likes this.
  6. Jun 7, 2020 at 3:03 PM
    #1566
    Markc1024
    Markc1024 Well-Known Member
    This worked much cleaner than the prior settings - fewer to change. I set base duty to 91.5 and that got me right at 14.1v (measured at battery), which is where I wanted to be as Northstar indicates it's sufficient for the battery to meet engineering specs. I don't run additional loads and just looking for battery longevity.
    e46_ema and Shellshock like this.
  7. Jun 7, 2020 at 3:13 PM
    #1567
    oldschool403
    oldschool403 ReloadOS
    2018 TRD Sport Long Bed
    SOS Front bumper with winch, Dual battery, RCI bed rack, Smitty built XL, 8112's in front, King 2.5 adj in back, Armor on the way.
    This may have been asked but I can't find it anywhere...Can we edit the tunes already created? I.e 1.05. It's a PF5 file under tunes but VFtuner opens with VFT files types. If possible how do I get it in VFtuner to edit? I bought the tune pack...want to add the alternator adjustment to the 1.05 tune in the end...
  8. Jun 7, 2020 at 3:16 PM
    #1568
    oldschool403
    Sorry P5F file not PF5
  9. Jun 7, 2020 at 3:26 PM
    #1569
    Markc1024
    Not yet, just the stock tunes provided. You'll need to wait for the tune packs.
  10. Jun 8, 2020 at 12:23 AM
    #1570
    houser1995
    houser1995 Well-Known Member
    Hunter
    Clarendon Pennsylvania
    2017 DCSB 6MT Trd Sport (Ovtuned)
    -Bds 6 in. lift, Fox factory 2.5 coilovers with dsc + remote res and factory 2.0 shocks with comp adjuster + remote res. -Fab fours front bumper -Method MR305 wheels -35/12.50 R18 Milestar Patagonias -Header back 2in. I.D. true duals with 2nd cat deleted (X pipe turbo muffler) -Af Dynamics Intake -Ovtuned running 2.0 SFOB Premium tune with @92ehatch and @tonered throttle edits (1st version with high tip in and sensitivity) -URD Stage 3 clutch (Ceramic/Kevlar) -Custom trail rash and dented bedside
    Just out of curiosity does anyone know why there are two rpm limiter settings? Is the second one the fuel cutoff?
  11. Jun 8, 2020 at 7:33 AM
    #1571
    Gametracker
    Gametracker Well-Known Member
    Fort Worth, Tx
    17 sport TRD 4x4
    SSO Hidden winch bumper, Meso puddle lights,
    What address do we send in our request for which tune packs we need? I now its on here in previous threads but have not found it. Is it the zen desk?
    Thanks
  12. Jun 8, 2020 at 7:47 AM
    #1572
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    support@ovtune.zendesk.com
    Gametracker[QUOTED] likes this.
  13. Jun 9, 2020 at 8:02 AM
    #1573
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    I've been doing more reading into battery charging profiles....
    I wonder how possible it would be to implement a 3 step charging cycle, something like Odyssey recommends.
    Edit: After reading through the technical manual Odyssey provides, charging over 13.6v for long periods can damage the batteries.
    I'm going to step back my charging voltage to 13.6-7 and use my trickle charger to top it off for now.
    I'll likely be doing some cheapo solar solution to get around this unless VF can do some sort of cool stepping with the charging system.
    Anyone else have updates?
    tonered likes this.
  14. Jun 9, 2020 at 8:07 AM
    #1574
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is for home charging specs. Even on big road trips, you are quite unlikely to have a single 8hr cycle, let alone any time for a float region. Realistically, at some point the battery is going to go from charge to drain when the motor goes to idle or a heavy load is requested. That charge current is also very specific to get that profile.
    Now for a solar setup, that could work, but that would not have anything to do with the tune.
    Just did a quick calc. A full tank of fuel will only last about 7hrs max. That's some iron butt, right there. :D
    ihatemytruck, wahoobie and Shellshock like this.
  15. Jun 9, 2020 at 8:13 AM
    #1575
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Good info sir!
    My batteries usually sit around 90-95%.. doing a 3 hour road trip @ 14.7v, i feel like, could, in some cases, possibly overcharge the batteries. I don't know that. With the Taco outputting the 13.6-13.7v it needs at float, the solar could always make up for the difference i would presume. I wonder what the affect of the alternator charging AND the solar charging would be on the battery... oh boy, this is a rabbit hole.
    I know it's not tune specific, but since there has been so much convo about the alternator settings, i just wanted to provide some useful analysis from my findings and hope others, like yourself, chime in :)
  16. Jun 9, 2020 at 8:18 AM
    #1576
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome.
    It would be interesting to know the charge voltage when the battery is topped up at that 3hr mark. Steady state stuff. Given the ECU controls, it is probably at a trickle rate, though not as smart as that home float setting.
  17. Jun 9, 2020 at 8:20 AM
    #1577
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Well, i have a 4 hour road trip to western ky this weekend - i'll keep an eye on it and report back.
    BTW i just got this from Odyssey....
    SOOOOOOOOOOOOO 14.6-14.7v is safe all the time i guess?
    back and forth and back and forth we go :)
    ihatemytruck, wahoobie and tonered like this.
  18. Jun 9, 2020 at 8:25 AM
    #1578
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :D
    I would have zero worries at 14.7 for an AGM. That is where my bike lives and has been happy for years. Replaced the 10Ah battery twice in 12yrs with plenty of abuse from turning over a cold 90deg twin.
    At home, I only let it charge for 4hrs/day. No sense in simmering it 24/7.
    Saeros and ihatemytruck like this.
  19. Jun 9, 2020 at 8:26 AM
    #1579
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Any reason to trickle charge it if i can put 14.7 volts at it?
  20. Jun 9, 2020 at 8:29 AM
    #1580
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Trickle at home and the Taco is a DD? Nope, IMVHO.
    Although, any modern vehicle that is sitting for two or more weeks regularly, then I would think about trickling.
    ihatemytruck likes this.
Thread Status:
