VF tuning collaboration and BS
Discussion in 'Performance and Tuning' started by uploadadventure, Nov 5, 2020.
  1. Mar 26, 2021 at 8:33 PM
    #2941
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I love a good meme!
  2. Mar 26, 2021 at 8:34 PM
    #2942
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    I'm too dumb to figure out how to insert a gif... Back to modifying an expensive vehicles ecu....
  3. Mar 26, 2021 at 8:38 PM
    #2943
    RushT
    North Texas
    Now there’s some irony. But keep on doing what you do well. :thumbsup:
  4. Mar 26, 2021 at 8:39 PM
    #2944
    Chadr7858
    Chad
    Colorado
    .... NSFW
    RushT[QUOTED] likes this.
  5. Mar 26, 2021 at 8:39 PM
    #2945
    Chadr7858
    Chad
    Colorado
  6. Mar 26, 2021 at 8:40 PM
    #2946
    Rodchester
    Rodchester Well-Known Member
    Baton Rouge
    2017 Quicksand SR5 DCSB V6
    Weather tech mats, LED interior lights and reverse lights, tube steps, bed extender, bed mat, folding bed cover, TRD Pro grill, blacked out badges and wheel center caps. Kicker speakers(all 6). Front bed rail header. Under hood LEDs. Tufskinz door and interior foam inserts. Chrome interior door handles. Fumoto drain valve. Aluminum oil filter canister. Rear view mirror with Homelink. Quick charge USB charging ports. TRD badge on grill. MESO fuse box cover. Redline Tuning hood struts. Ceramic coating. Pop & Lock auto tailgate lock. LED bed lights. Lower bumper LED light that bar. MESO coin holder. TRD cat back exhaust. Hikari Ultra LEDs high and low beams. 2020 TRD Sport wheels and TRD center caps. RSC Nano dashcam. DSM from the Taco Garage. Blue Sea dual USB outlet on back of center console. KDMax7.0
    Transmission braking does reduce wear on the brakes but increases the wear on the transmission. Brake pads are a lot cheaper than transmission repairs.
  7. Mar 26, 2021 at 8:44 PM
    #2947
    Shellshock
    Iowa
    Everyone says this (same with clutches) but they seem to far outlast how long anyone has their truck..
  8. Mar 26, 2021 at 8:47 PM
    #2948
    Chadr7858
    Chad
    Colorado
    Correct
  9. Mar 26, 2021 at 8:50 PM
    #2949
    RushT
    North Texas
    :rofl::rofl:
    uploadadventure[OP] likes this.
  10. Mar 26, 2021 at 9:20 PM
    #2950
    TermLimits
    TermLimits Owner of Valley Tuning
    Jeff
    Cleveland, Ohio
    2016 QuickSand Tacoma TRD OR
    ValleyTune.com Current Tunes: Valley Runner
    Yes it does but I'm getting trans braking to work better by rev matching the downshifts. Keeps it from jolting the rpms up with each drop, 4 out of 5 shift points if you were to coast through them are nearly unnoticeable with the tune. The only changes you feel are the truck slowing down gradually then receiving a small section of increased decel before mellowing out again.
    Coupling that with normal braking has made the truck even without add ons feel like you can stop it with minimal brake pedal as opposed to needing to push it to the floor
  11. Mar 26, 2021 at 9:26 PM
    #2951
    TermLimits
    Jeff
    Cleveland, Ohio
    I never trust Toyota when it comes to transmission service intervals. Its a sack of horseshit to me.
    My truck used to shudder and bounce when the transmission tried to shift up 3 to 4 around 24-28mph with light throttle. The dealership wanted to change the leaf springs for $4k before looking into the transmission. All this prior to tuning the thing, was going to tune around the issue so it never bothered me again lol.
    Truck had 88k on it... Yet the service manual says that you need to "check" the fluid level and top off if needed essentially forever with normal driving. But towing and off roading trucks would mandatory get a fluid exchange at 60k, 120k, 180k and so on...
    $140 fluid exchange at valvoline and 20min later, it ran perfectly again.
    If you change the fluid in the transmission once before you get rid of the truck it'll be better than before...
  12. Mar 26, 2021 at 9:30 PM
    #2952
    Shellshock
    Iowa
    Yup. People should definitely be changing fluid (at least a drain and fill). I’ve seen it solve tons of issues but for some reason people think it won’t help or it’s too hard..
    my 2016 was over a half quart low from the factory..
  13. Mar 26, 2021 at 9:34 PM
    #2953
    TermLimits
    Jeff
    Cleveland, Ohio
    At 88k mine was definitely not shiny red colored... It was slightly darker than new but it definitely played a role in the trans not shifting properly
  14. Mar 26, 2021 at 9:49 PM
    #2954
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Man now I gotta get off my ass and change that. I hesitated because I kinda wanna do the flush along with it but don't wanna spend that much on fluid. Just have enough to drain and replace. Is it about as easy as the diffs?
  15. Mar 26, 2021 at 9:51 PM
    #2955
    TermLimits
    Jeff
    Cleveland, Ohio
    Full flush takes forever to do yourself. Drain and fill is easy like the diffs.
    It costs 130 for the 11qts of fluid from autozone and then the pain in your ass to do it yourself.
    Find you a valvoline instant oil change place, call and make sure they can do a transmission fluid exchange (they all should be able to).
    They'll hook it to the pump and in 20-30min pull out all 11 qts and replace it. Costs 140-160 depending on the area...
    It was worth it to me
  16. Mar 26, 2021 at 10:01 PM
    #2956
    Shellshock
    Iowa
    Don’t bother with a full flush. Just do a drain and fill.
    you just drain it. Fill it. Get to temp check mode. Then open overflow to a trickle.
  17. Mar 26, 2021 at 11:13 PM
    #2957
    CAG Gonzo
    2018 OR DCLB BarRed
    Already got the ATF for a replacement. Overcoming my nervousness, that's another thing. But I was nervous about swapping the diffs and it doesn't seem I've fucked that up. No explosions. Yet.
    TermLimits likes this.
  18. Mar 27, 2021 at 2:34 AM
    #2958
    TermLimits
    Jeff
    Cleveland, Ohio
    Another late night (early morning) update.
    Once again I completed an ECU conversion of Valley Runner at 5:30am haha. The VA doesn't pay me for insomnia for nothing.
    As of now Valley Runner 2.0.2 is available 100% tested on 2016-2017 AT 04B04.
    It is also conditionally available for the following ECU IDs:
    2018 AT - 04A61
    2019 AT - 04B33
    Once testers have run this tune long enough without issues, these IDs will move to 100% available. As of now they are only available with the caution that updates and bugs may occur.
    Next I am moving to convert 2020 AT followed by 2020 MT
    Mr. Nobody and ry18Tac like this.
  19. Mar 27, 2021 at 3:45 AM
    #2959
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    You're not wrong. I do feel strongly about knowing what I'm flashing to my truck. We paid good money for these things. I was just a little butt hurt I guess from others making $ off my time and efforts. It pisses me off being exploited. I've shared DOZENS of unlocked tunes. I'm fairly certain I started the trend. Others first said to me, why do all the work so people can just mooch off what you're doing? I did it because I wanted to share my experience with others in hopes they'd do the same, and that's exactly what happened. I didn't care, until people starting throwing the root of all evil into the equation. F*ck it I guess, if someone wants to be an @$$hole they will, whether my sh*t is locked or not.
    https://www.tacomaworld.com/threads/vf-tuner-for-the-3-5l-tacoma.662948/page-201#post-24135905
  20. Mar 27, 2021 at 5:22 AM
    #2960
    Frank_Zuccarini
    Frank_Zuccarini Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    You were, indeed, the pioneer. Most here recognize that, and if the world were fair, Mat would have been paying you for the interest and utility you brought to his fantastic product.
    Some people are jerks, and will exploit your skill and generosity of spirit. Not much you can do about it.
    On the behalf of myself and MANY others here, thank you for your many contributions to the TacomaWorld community.
    Frank
    TacoNesian, kibo, dunlap837 and 14 others like this.
