VF tuning collaboration and BS
Discussion in 'Performance and Tuning' started by uploadadventure, Nov 5, 2020.
  1. Nov 7, 2020 at 7:51 AM
    #61
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    If you've also raised shift points I'd do both. Raise the lock and lower the unlock. Try +10 for the first two and +5 on the rest for lock. -3 or 4 on all unlock.
  2. Nov 7, 2020 at 8:05 AM
    #62
    rpete67
    rpete67 Active Member
    Rod
    2018 Cement Tacoma TRD 4x4
    I'll give that a
    Thx, I do have modified shift points, maybe I got lucky with adding 10 to the lock maps. I'm really liking the way it drives with the delay of the unlock. Just not sure what state the TC is in when the values are adjusted between lock an unlock. Sure don't want to overheat the transmission.
  3. Nov 7, 2020 at 8:08 AM
    #63
    Mooseditty17
    AJ
    WI
    as long as it reaches the Locking position it should stay locked until you get to the unlock values you entered. Going up 5 miles an hour where you use your throttle the most, the middle values, really ain't going to make two s**** a difference. I stay under 205
    n2xlr8n likes this.
  4. Nov 7, 2020 at 8:12 AM
    #64
    rpete67
    Rod
    Cool thx, I'll keep an eye on things for the next few days.
  5. Nov 7, 2020 at 8:22 AM
    #65
    Ron1965
    Ron1965 Go Bruins.......
    Ron
    Socal
    2018 Cement TRD ORSB PREMIUM/TECH
    OVtune Mooseditty Custom;DD Exhaust;Nitro 5.29’s;SCS Brushed Copper;AFe Custom CAI
    MD recently did a tune for me and it’s great. Truck has never run like this. Shift points are perfect and a lot more power and torque. He does a great job.
  6. Nov 7, 2020 at 8:24 AM
    #66
    uploadadventure
    uploadadventure [OP] It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    If y’all have tunes to post please tag me so I can put them on post 1. Keep the thread as simple as it can be.
    thanks y’all!
    LstMinutePanic and Mooseditty17 like this.
  7. Nov 7, 2020 at 8:28 AM
    #67
    Mooseditty17
    AJ
    WI
    One other thing to note that I personally did. However much you raise your lock values do the same to your unlock values. Then subtract 3 to 5 mph from them. otherwise you're going to end up with a huge gap between your unlock values from your lock values especially at the lowest two points
  8. Nov 8, 2020 at 8:04 AM
    #68
    LstMinutePanic
    LstMinutePanic Well-Known Member
    Colorado
    2018 Black Tacoma OR DCLB AT
    Hey, @uploadadventure, this post links to four different tunes for 04A61. Can you add them to the first post in this thread?
    Let me know if I can help.
    uploadadventure[OP] likes this.
  9. Nov 8, 2020 at 10:53 AM
    #69
    Golo808
    Golo808 New Member
    Oscar
    2016 Black Tacoma TRD Off-Road
  10. Nov 8, 2020 at 11:08 AM
    #70
    DownhillDragon
    DownhillDragon Well-Known Member
    Brody
    Austin, TX
    2017 Tacoma TRD Pro AT Cement - POWERTHIRST v2.4 Tuned
    POWERTHIRST Tuned - My Custom OVTune SSO Slimline Bumper with Stage 2 Kit + BajaDesigns 20" Light bar with Amber Backlight + Smittybilt Winch x2o 10,000lb Synthetic CaliRaisedLED Step Edition Rock Sliders SUSPENSION FRONT A.D.S. - 2.5 Adjustable Dampening Remote Resi Fronts Dirt King Upper Control Arms SUSPENSION REAR A.D.S - 2.5 Smoothie Piggy Back "Rear" Shock With Compression Adjuster Deaver Leaf Pack Cab Mount Relocate by Triple-C Chop Shop, Lago Vista, TX Nitro Gear 5.29 BFG KM3 35x12.5x17 Fuel Rebel6 17" Wheels + Full-size Spare + Rhino-Rack Spare Wheel Strap 4x Rigid Cube Ditch Lights + Cali Raised Ditch Light Hood Mount Brackets + Cali Raised Ditch Light Extension Brackets + 3x Cali Raised Switches + Light Switch Mount Bracket Snugtop Camper Shell with Carpeted Ceiling and Mounting Tracks Prinsu Top Rack and Cab Rack Hi-lift Jack + Hi-lift Jack Mount on roof DEFEND INDUST Recovery Traction Tracks (knockoff Maxtrax) Trimax ST30 Trimaflex Spare Tire Cable Lock (Round Key) 36" x 12mm K&N Intake Canvas 270 RV Awning Rooftop Sun Shelter + Prinsu Awning Brackets Fire Extinguisher w/mount Campbell Hausfeld FP209499AV - 3 Gallon Air Compressor
    Hey, I followed that link to the post, but didn't see any 04A61 tunes uploaded there? Where should I be looking?
  11. Nov 8, 2020 at 11:09 AM
    #71
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    The post has quotes for the people who uploaded tunes. Click on the up arrow in the quote to go directly to the quoted post that will have the tune for download.
    LstMinutePanic likes this.
  12. Nov 8, 2020 at 11:39 AM
    #72
    LstMinutePanic
    Colorado
    As @CAG Gonzo mentioned above, it's a bit of some contact tracing to find the tunes. He explained the process, and the linked post itself has a description about how to find the tunes as well.
  13. Nov 8, 2020 at 3:52 PM
    #73
    uploadadventure
    Dixon, Mo
    I was off grid this weekend. I’m going to try to fix post 1 this week with tunes by ECU
    PapaRee likes this.
  14. Nov 8, 2020 at 3:56 PM
    #74
    uploadadventure
    Dixon, Mo
    Got you updated. Thank you for making it easy
  15. Nov 8, 2020 at 6:54 PM
    #75
    DownhillDragon
    Brody
    Austin, TX
    Gotcha! Thanks @LstMinutePanic and @CAG Gonzo.
    My next project will be helping some buddies with the 04C20, since I don't think anyone's done it yet, so I'm going to port over MD's Mild and Wild starting.... NOW!
  16. Nov 8, 2020 at 7:09 PM
    #76
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Is the 04C20 the 2021 Manual Transmission?
    @uploadadventure --Might be a good thing to add to your first post-- A list of updated ECU's with their year and transmission.
    Edit-
    Here you go:
    2016-2017 A/T -- 04B04
    2016-2017 M/T --04B14
    2018 A/T----------04A61
    2018 M/T--------- 04A71
    2019 A/T----------04B33 (Most-04B31)
    2019 M/T--------- 04B41
    2020 A/T----------04B81
    2020 M/T--------- 04B91
    2021 A/T----------04C00 & 04C20
    2021 M/T--------- 04C30
  17. Nov 8, 2020 at 7:28 PM
    #77
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    Yeah, this is some good first post content
  18. Nov 8, 2020 at 7:34 PM
    #78
    DownhillDragon
    Brody
    Austin, TX
    04C20 is the 2021 AT, you're thinking of 04C30 which I believe is the 2021 MT that isn't quite supported yet.
    PapaRee likes this.
  19. Nov 9, 2020 at 4:50 AM
    #79
    uploadadventure
    Dixon, Mo
    Added. Good idea
    G8R_Taco and PapaRee[QUOTED] like this.
  20. Nov 9, 2020 at 9:50 AM
    #80
    AbnMP13
    AbnMP13 Well-Known Member
    Shelby
    2020 TRD Crew Long Bed
    And of the 04B81 with stock gears and tires flavor.
    TacoNesian likes this.
