vF Tuning for Manual Transmission 3rd Gens
Discussion in 'Performance and Tuning' started by tonered, Oct 1, 2020.
  1. Oct 15, 2020 at 9:02 AM
    #361
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I don't know what your secret sauce is, but I've NEVER been able to brush the throttle and get a consistent blip response. This goes all the way back to the Ginger and every tune file I ever flashed either truck with. Sometimes it's great, other times the engine just won't bother. Even 'hatch's file wouldn't do what I wanted in that regard. I suspect the answer is at least partially in the PTTT map. I'm not willing to fuck up other driveability aspects chasing it too far though. Engine braking and smooth acceleration for example.
    tonered[OP] likes this.
  2. Oct 15, 2020 at 9:03 AM
    #362
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Are you guys down for calling these V4? With that, I can update the 1st Post and keep stuff in order?
    MOC221_ likes this.
  3. Oct 15, 2020 at 9:03 AM
    #363
    MOC221_
    Frank
    Yes I know.
    ..and then I altered them for a specific purpose.
  4. Oct 15, 2020 at 9:04 AM
    #364
    tonered
    tony
    Lynnwood, WA
    On the engine braking, I am fairly certain that we have that nailed down to the starting, negative PTTT values? Say, -5 or less?
    Can we make that an agreed 'rule,' or are there still outliers?
    MOC221_[QUOTED] likes this.
  5. Oct 15, 2020 at 9:05 AM
    #365
    MOC221_
    Frank
    Have at er..
    tonered[QUOTED][OP] likes this.
  6. Oct 15, 2020 at 9:08 AM
    #366
    su.b.rat
    su.b.rat broken truck
    i understand. over & over i come back to the speculation that my open exhaust let's it breathe forward without backpressure restriction. low tq at low rpm this little motor. it's subjective but makes sense and everything i experiment & play with seems to validate. i mean, i barely brush the throttle to rev match, super easy, totally consistent.
    truck goes into the shop next week for a front end tweak, solid motor mounts, and ATM I'm planning on hooking up the OV catted dumps finally. should be another step in [hopefully] validating that again.
    and no I'm not ever sitting back here saying you guys should go open exhaust... not for everyone, i get it.
  7. Oct 15, 2020 at 9:11 AM
    #367
    tonered
    tony
    Lynnwood, WA
    :hattip:
  8. Oct 15, 2020 at 9:13 AM
    #368
    tonered
    tony
    Lynnwood, WA
    That was my experience with the unedited 04B14 SFOB Prem on 92, except it was probably only 85% consistent?
    Now, I'm getting into it deeper, but it is 98% or better?
  9. Oct 15, 2020 at 9:17 AM
    #369
    su.b.rat
    i guess that's a little hard to say. what i experience, as far as i can see, is that my truck is setup with a pretty narrow window for spot-on functioning, and it's my game to get it right everytime. so, if i miss a blip, or get dogged going into second for example, that's because i didn't get it right with my use of the throttle. i would be the inconsistent one, not the truck, motor, or tune.
  10. Oct 15, 2020 at 9:19 AM
    #370
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    The sensitivity went away when I removed your PTTG1 map and when I changed PTT column 1 from -5 to -7.5 (simultaneously)
  11. Oct 15, 2020 at 9:20 AM
    #371
    MOC221_
    Frank
    Just personal preference on my end. I don't want to have that "free wheeling" feel when I lift. The stock engine braking is weak as it is lol.
    I have a lot more experimenting to do on the PTTT map. I'm not in the "make a whole column the same value" camp just yet, I may start small with additional duplicated values in specific areas, but retain the two axis taper. We'll see. Honestly right now my only bitch is the blip response for daily driving.
  12. Oct 15, 2020 at 9:25 AM
    #372
    tonered
    tony
    Lynnwood, WA
    Oh yeah. The problem is that most times, a goof up is definitely me. I am not the most motor-controlled person, but my muscle memory has done me a lot of favors. There are those times when I know that something on the Taco side was off. Defo with Stock! Each OV iteration and edit (that I keep!) gets better.
    Oh yeah. I felt that free wheeling with the '0' starting value. The other ALC issues just overshadowed it. LoL!
  13. Oct 15, 2020 at 9:42 AM
    #373
    tonered
    tony
    Lynnwood, WA
    The 1st Post here and in the ALC thread have been updated to note the V4 info.
    MOC221_ likes this.
  14. Oct 15, 2020 at 9:46 AM
    #374
    MOC221_
    Frank
    Just so everyone is aware, V4 is not "my" map. I took Tony's Airload V3 maps and altered just the two control maps for my specific purposes. I made it clear in earlier posts what I did and where the originals came from, but that info might get past someone who hasn't kept up lol.
    tonered[QUOTED][OP] and su.b.rat like this.
  15. Oct 15, 2020 at 9:48 AM
    #375
    tonered
    tony
    Lynnwood, WA
    I will add that to the ALC.
  16. Oct 15, 2020 at 9:49 AM
    #376
    mZiggy
    mZiggy Honey badger
    Marc
    Nah man, that's your map, you can't change my mind lol
  17. Oct 15, 2020 at 10:06 AM
    #377
    MOC221_
    Frank
    Well shit..
    mZiggy[QUOTED] and tonered[OP] like this.
  18. Oct 15, 2020 at 11:00 AM
    #378
    Karminski
    Karminski Well-Known Member
    Virginia
    2016 Tacoma D/C M/T TRD Off-Road
    Any chance you might post the excel for V4? Or am I best off modifying the table with the instructions on post 1 (ALC)?
  19. Oct 15, 2020 at 11:01 AM
    #379
    tonered
    tony
    Lynnwood, WA
    @MOC221_ is the V4 guru. :D
    For now, the best bet is to follow his instructions. You should get identical values.
    MOC221_ likes this.
  20. Oct 15, 2020 at 11:13 AM
    #380
    Karminski
    Virginia
    Not sure it's what you are looking for, but I have been happiest with this PTTT so far. I'm still playing/hacking like everyone else, but I keep coming back to this PTTT.
    The data values are here if you wanted to see the details.
    MOC221_[QUOTED] and tonered[OP] like this.
