VIAIR 450PA 12volt Portable Air Compressor
Discussion in 'Product Reviews' started by Canazes9, Jun 9, 2012.
  1. Jun 9, 2012 at 10:27 AM
    Canazes9
    Canazes9 [OP] Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    After burning up a 1/2 dozen or so cheap portable air compressors over the years I decided to upgrade. I wanted something that would inflate the tires quickly for both my truck and my son's truck (and anyone that happened to be with us) without taking forever and without having to worry about it burning up and dieing at an inopportune time.
    I checked a lot of different models and specifications. I am certain I would have been well served by a lot of different compressors, but in the end, the 100% duty cycle of the VIAIR 450PA won me over! Yes, I know this is major overkill for my application - I like that:D. Hoping I won't ever have to buy another....
    http://viaircorp.com/450P-A.html
    I didnt' do a lot of comparison shopping for this model on the internet - I found Suspension Connection's website easy to use and informative, so I bought it there. $284.95 total price delivered to my home. Compressor arrived 5 days after I placed my order.
    I just took it out and performed a test run on my truck in the driveway.
    Pump as delivered, it comes with hose, fill nozzle w/ gauge and valve, power clamps & carrying bag:
    I deflated my Mickey Thompson ATZ 265/75R16 from 31 to 15 psi. I don't usually run pressure this low, 20psi seems to work fine for me, but still I wanted to give the compressor a run. For comparisons sake, total deflation time from 31 to 15 psi was 1 minute 50 seconds.
    Next I started the truck (so as not to put undue draw on the battery) and attached the power clamps. Clamps fit easily, securely:
    I did a quick check to see how far the hose would stretch. Between the power cable's length and the air hose you have ample reach, even to reach airbag fittings at the rear of the truck. Note in the picture that I did not even turn the compressor so that it was pointing the hose connection to the rear or try to stretch the power cord, which is connected to the battery on the off side:
    I turned on the pump and and it pressurized the line to it's automatic shut-off point (~100psi I think) in about 3 seconds. I was surprised by how quiet and smooth the pump was. Connected the fitting to the tire and activated the valve. 93 seconds later my tire was reading 31 psi again. The gauge supplied is large and easy to read - it also matched exactly the pressure readings from my digital air gauge.
    The compressor is a little large, don't think it will fit behind the seat in my double cab without mashing the hose. It could be made to fit by stowing the hose separately. Not a big deal for me - I've got to keep a bunch of work stuff back there normally, will add the compressor along w/ my hi-lift and assorted other recovery gear when I go wheeling.
    David
    Governor likes this.
  2. Jun 9, 2012 at 11:50 AM
    Canazes9
    David
    Texas
    Follow-up
    Yes it will fit behind the Driver's seat in a double cab if put the hose in the main compartment on top of the compressor instead of in the front hose compartment:
    David
  3. Jul 2, 2012 at 12:44 PM
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    Got the same set up. Love it.
    Stig likes this.
  4. Jul 2, 2012 at 12:48 PM
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    3" Lift Three leaf add and Bilstin 5100"s in back and Donahoe coilovers in front, Tinted Windows, Blackened parking light, tinted brake lights, clear bumper lights, Blacked out turn signals, AVS vent visors, Electric Fan mod, K&N CAI
    x2
  5. Jul 2, 2012 at 1:38 PM
    tmreyes1
    T-Rey
    TX
    2017 TRD
    does anyone know if they sell an adapter to use with 110v?
  6. Sep 18, 2013 at 9:42 AM
    Fivespeed
    Fivespeed Well-Known Member
    Tualatin, Oregon
    '12 TRD Offroad w/ Entune
    Old thread bump..
    Anyone figure out a way to keep the lever pressed on the inflation gun without having to hold it?
    Thanks!
  7. Sep 18, 2013 at 8:26 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
  8. Sep 19, 2013 at 3:31 AM
    penguins_cc
    Will
    Bellevue, WA
    ^^^ Correction. I think a regulator is not the ideal solution because it would essentially slow down as you reached pressure. Let me retract that statement about the regulator.
  9. Sep 19, 2013 at 12:37 PM
    Fivespeed
    Tualatin, Oregon
    Appreciate the reply. I was thinking of getting a big beefy rubber band and seeing if somehow I can just wrap that around the lever or something.
  10. Sep 19, 2013 at 12:47 PM
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
  11. Sep 19, 2013 at 9:46 PM
    penguins_cc
    Will
    Bellevue, WA
    OK - maybe that was a bit overkill on my part :rolleyes: Got me thinking though!
  12. Sep 20, 2013 at 5:08 AM
    tmreyes1
    T-Rey
    TX
    2017 TRD
    What about this. Still need a pressure gauge, but these fill pretty fast
  13. Sep 20, 2013 at 2:24 PM
    Fivespeed
    Tualatin, Oregon
    Haha.. Good thinking though!! I like the gun the Viair comes with
    I looked into one of those but I want the pressure gauge. Lol
  14. Nov 8, 2013 at 4:28 PM
    Canazes9
    David
    Texas
    The gun the Viair 450P comes with has a pressure gauge. Its ready to go out of the box. That's what is shown in this picture:
    http://i15.photobucket.com/albums/a388/Canazes9/2012/03366530.jpg
    David
  15. Nov 9, 2013 at 7:42 AM
    Fivespeed
    Tualatin, Oregon
    Yeah I know I own the 450p as well. I was mainly curious if anyone found a quick and easy way of keeping the lever pressed without having to hold it.
    Brian
  16. Nov 9, 2013 at 9:55 AM
    Canazes9
    David
    Texas
    David
  17. Nov 9, 2013 at 10:00 AM
    Large
    Large Red
    x3. Hasn't let me down.
  18. Nov 9, 2013 at 4:06 PM
    Fivespeed
    Tualatin, Oregon
    Post 9
    Brian
  19. Dec 22, 2015 at 11:01 PM
    misanthropicalme
    misanthropicalme FNG
    Mitch
    SW Washington
    2015 Charcoal Grey Tacoma TRD Off Road 4DSB
    BFGKO2, Slid-plate, BAMF Sliders, Rigid Industries Lighting, Plasti-dip wheels, GT Seat Covers, dreams.
    Old thread revive bump, just bought this set up, it's absolutely amazing.
    Has anyone ever had a heat issue with this compressor?
    I'll post pictures soon
  20. Dec 23, 2015 at 10:44 AM
    penguins_cc
    Will
    Bellevue, WA
    Mine has aired three vehicles consecutively during summer without overheating. It is a 100% duty rated pump so it should not be an issue. My gun has a sticky trigger button that I need to keep lubricating (referring to the little button that gets pushed when you pull the trigger) and it doesn't seem to be the fastest pump in the world but it's a workhorse.
