Viair Automatic Mod (VAM)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Aug 13, 2020.
  1. Aug 15, 2020 at 7:33 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Dou. (Being slow tonight). Thanks, that explains it.:thumbsup:
    dilbert[QUOTED] and tonered[OP] like this.
  2. Aug 15, 2020 at 7:36 PM
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    It is also that the Viairs can hit high pressures more quickly than I was expecting.
    That said, with tools and supplies purchased, I am probably darn close to the 400P Automatic price.
    But, I have needed this stuff for a while and it was fun.
    dilbert likes this.
  3. Aug 15, 2020 at 8:54 PM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    When using the @Shellshock "fill all 4 at once" mod, do all the pressures match on the TPMS display? I can't stand when they're a PSI or 2 of from one another. Any pics of the whole setup with the digital gauge?
    tonered[QUOTED][OP] likes this.
  4. Aug 15, 2020 at 8:59 PM
    Shellshock
    Iowa
    I did mine for 2 at once but that’s exactly why I did it - so they match.
    tonered[OP] and dilbert[QUOTED] like this.
  5. Aug 15, 2020 at 9:01 PM
    dilbert
    dilbert AI Member
    PNW
    Mmmmmmm... Matchy matchy.
  6. Aug 15, 2020 at 9:03 PM
    Shellshock
    Iowa
    I got real tired of 33 34 35 34
  7. Aug 15, 2020 at 9:17 PM
    tonered
    tony
    Lynnwood, WA
    I did the two tire option. Yes, though. They do match and fill quickly.
  8. Aug 17, 2020 at 7:58 AM
    tonered
    tony
    Lynnwood, WA
    Hey, Folks.
    I updated the 2nd Post with the full details.
    Lemme know if you have any questions.
    :cheers:
    Freegolf likes this.
  9. Aug 17, 2020 at 9:26 AM
    tonered
    tony
    Lynnwood, WA
    Sorry. I missed this last bit.
    These are the pics that I currently have:
    dilbert[QUOTED] likes this.
  10. Aug 18, 2020 at 11:43 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    What is the purpose of this mod? If I read correctly, this will just turn on the compressor on for you when you hook it up to your tires and turn off when you disconnect. Is it just to save time going to and from the compressor to manually turn it on and off? I am just a little confused but intrigued.
    Does this mod make it turn off after hitting a certain PSI?
    tonered[OP] likes this.
  11. Aug 18, 2020 at 11:47 AM
    tonered
    tony
    Lynnwood, WA
    Yes. That is exactly it. I am overjoyed with @Shellshock 's deflator / inflator. The Viair gauge and valve stem connector that comes with it is not so good. The problem was that there is no air relief in the deflator / inflator setup like there is with the supplied parts. So yeah, this keeps me from doing suicide sprints when checking all of the fams tires.
    Also, when disconnecting the new line, it will just run continuously like stock.
    Shellshock and Technique[QUOTED] like this.
  12. Aug 18, 2020 at 11:52 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Duuuuuuude tell me more about this wire trickery?! I wonder if @MESO can 3d print a back cap to clean it up some. It's already pretty clean though
  13. Aug 18, 2020 at 11:54 AM
    Technique
    Alex
    Utah
    I like that......you should build some of these and sell them for us, non-electrical noobs.
  14. Aug 18, 2020 at 11:55 AM
    tonered
    tony
    Lynnwood, WA
    Thanks!
    It is a bit messier than I would like. A larger switch cover might contain it all. I may add something to allow the relay to be mounted vertically instead of angled.
    It does completely fit in the bag with all the hoses can connectors.
    mac_2_nite likes this.
  15. Aug 18, 2020 at 11:57 AM
    #35
    Shellshock
    Iowa
    without this, the compressor will just keep compressing. when you have a closed line (detached from tire) thats not a good thing. So you are supposed to turn the compressor off, then detach the line, attach the line, turn the compressor on.
    This mod gets you the features of the automatic compressors, without the additional cost (or maybe its the same cost, idk).
  16. Aug 18, 2020 at 11:58 AM
    #36
    tonered
    tony
    Lynnwood, WA
    Thanks!
    Haha! I'm typically letting the smoke out of electrics. Just like mechanical stuff, it seems that having the proper tools does help.
    I will see if I can source something to make the tee joints in the wire easier.
    Shellshock likes this.
  17. Aug 18, 2020 at 11:59 AM
    #37
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Sup widdem wire clamps?
  18. Aug 18, 2020 at 11:59 AM
    #38
    tonered
    tony
    Lynnwood, WA
    With the crimpers, terminals, and connectors, it was close to the additional cost of the 400P Automatic. Just parts? Less than $30.
  19. Aug 18, 2020 at 12:00 PM
    #39
    Technique
    Alex
    Utah
    I feel like I could do this with my very limited tools, I'd just need to see a better picture of the wiring laid out and where/how you tied into the oem harness. It is the one thing I wanted this compressor to have, the automatic shut off at a certain PSI.
  20. Aug 18, 2020 at 12:01 PM
    #40
    tonered
    tony
    Lynnwood, WA
