Vibe after lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by infernoTaco423, Jul 11, 2021.
  1. Jul 11, 2021 at 7:18 PM
    infernoTaco423
    infernoTaco423 [OP] Well-Known Member
    17 TRD Sport
    Did the 5100 lift on middle perch with a 1” block in the back. Now when stopping I get a slight vibe from 2000-1500 rpms. Do I need a shim for the rear or is this the ECGS bearing. In my searches I can’t find a definitive answer.
    2017 DCSB
    thanks
  2. Jul 11, 2021 at 7:25 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Gonna be trial and error. No clear cut way to diagnose driveline vibes. Could be a needle bearing, could be carrier bearing, may need a diff drop, may need a shim.
    Junkhead likes this.
  3. Jul 11, 2021 at 7:25 PM
    AtomAnt
    AtomAnt Well-Known Member
    Adam
    South Cackalacky
    2019 TRD Sport
    Mine did the same after a similar lift. It threw off the driveline angle just enough to cause vibrations. Just the weight of my Diamondback bed cover was enough to make it completely go away. Throw an 80# bag of sakrete in the bed and see if it fixes it. If it does, it’s the driveline angle. You could correct it with a shim. There’s a huge thread here somewhere about measuring and correcting driveline angles.
    Mark77 likes this.
  4. Jul 11, 2021 at 7:38 PM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
  5. Jul 14, 2021 at 2:15 PM
    Chris1121555
    Chris1121555 Well-Known Member
    East Coast
    2017 Infeno TRD OR Manual
    -Toytech BOSS 2.0 Aluma Series lift w/ AAL (2") -265/75R16 BFG AT KO2's -Plastidipped TRD OR Wheels w/ Red TRD Center cap -LED Head/Fogs -Interior LED lighting -Rigid Industry Ditch Lights -Black OEM Grill (Painted) -Westin Grill Guard -Copy Polymer Shfit Knob (M/T) -Tonneau Cover, Tri-Fold. (*Looking to sell or trade for Rollup*) -Kicker CS speaker upgrade -Kicker Hideaway 8" subwoofer
    If you put it in 4WD and vibe goes away, replace your bearing with ECGS one
    Aqualoon and 71tattooguy like this.
  6. Jul 14, 2021 at 2:23 PM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Wouldn't that be the other way around? Like if it was the needle bearing shouldn't the vibe go away in 2wd since the front diff wouldn't be engaged any longer? I could be completely off base here.
  7. Jul 14, 2021 at 2:27 PM
    Chris1121555
    East Coast
    You'd think so. But with that front diff engaged the vibe will go away (if it's the needle bearing) not exactly sure why but It's a pretty known problem on our trucks when it's lifted. That's the first thing I'd check. Flip that bad larry in 4hi and see if the vibration goes away or not
    Aqualoon and skeletron like this.
  8. Jul 14, 2021 at 2:29 PM
    Chris1121555
    East Coast
  9. Jul 14, 2021 at 2:29 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    Thanks for clearing that up bro
