Vibration after new wheels and tires and numerous balancing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Armygreen, Sep 25, 2020.
  1. Oct 2, 2020 at 2:18 PM
    #61
    Armygreen
    Armygreen [OP] Active Member
    It appears that we're experiencing exactly the same issue:
    My brakes were totally fine before the Ray10's
    I don't have ECGS and feel the grinding on the steering wheel. But that has been there and it's not really a vibration/shaking...
    I have driveshaft carrier drop and I know what a driveshaft vibration is...it's not this one.
    Discount has ordered a new set of Toyo at3's but I really don't know if it's a fix. I'm going to get a set of TRD 17" wheels and possibly go back to them again.... it's not worth the time and effort.
    Phich[QUOTED] likes this.
  2. Oct 2, 2020 at 2:24 PM
    #62
    Phil4200
    Phil4200 Well-Known Member
    2018 Tacoma SR5 DC 4x4
    3.5 RC Vertex coil overs, SPC uppers, rear blocks\RC V2 monotubes CVC tune 3.0 mbrp exhaust
    Maybe adjusting your caster settings might help a bit?? Possible water in the tire from air compressors?? Only takes a little. Mess with tire pressure. I’ve had KO2 on a tundra and never could fix it. I got lucky on my Tacoma though. Try running them at 35-36 cold. Good luck this issue is frustrating.
    Phich likes this.
  3. Oct 2, 2020 at 2:54 PM
    #63
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    Good suggestions but my caster, camber, etc is fine - alignment 2 weeks ago.
    Messing with tire pressure helped a little but I think is just a tweak that minimizes the symptoms of a problem of which the root cause is a still a mystery.
  4. Oct 3, 2020 at 7:03 AM
    #64
    Phich
    San Antonio
    Six Demon Bag
    After the third balancing and setting cold psi at 28, the vibration is still present. It's a tenacious bastard.
    I have ordered Cooper AT3 LT's that will be here on Wednesday. Hopefully it works. If not, my next best guess is leaf shims.
    I will report back on Wednesday.
  5. Oct 3, 2020 at 10:36 AM
    #65
    Sungod
    Sungod Well-Known Member
    St Augustine
    If you avoided every shop that someone had an issue with, you would have no where to go. Discount is one of the largest independent tire dealers in the country. Tires is all they do. Consequently you are more likely to hear about them than moe, manny, and jack or any of the other players out there.
    Armygreen[OP] likes this.
  6. Oct 3, 2020 at 10:41 AM
    #66
    Sungod
    St Augustine
    Ahh, seeing that you are following more bad advice with the best intentions. Air pressure is not a solution for a vibration. Don't waste your time.
    You need to separate your braking vibration from your driving vibration. They are by no means related.
    It sounds like your balance issue is corrected. It isn't uncommon for tires to run a little rough when cold. Especially if they have nylon or any of the fibers similar to that in their family. They get stiff when they are cold and take a few miles to warm up. I'm guessing that is why it smoothed out and was smooth on your way home.
    Armygreen[QUOTED][OP] likes this.
  7. Oct 3, 2020 at 11:35 AM
    #67
    Armygreen
    I informed the tech and he thinks this is now a brake issue. But it’s also happening without braking... there really isn’t a pattern or routine to it. Yesterday it vibrated all day with braking (severely) and without braking (mildly). Also there’s vibration in the seats which makes the ride uncomfortable.
    anyway i have a TRD big brake kit which I had purchased for the 4runner, I think it should fit Tacoma as well. ( it doesn’t list Tacoma for some reason but I checked the dimensions and it should fit with 17” wheels). I’m going to put it on and rule the “warped rotor “ scenario out as well. See what’s next... anyone know if there are sny incompatibility issues with the TRD bbk and Tacoma? Hope it doesn’t nose dive afterwards...
  8. Oct 3, 2020 at 11:42 AM
    #68
    Bishop84
    Bishop84 Well-Known Member
    Ive had an out of round rear drum that made the wheel shake like a bent axle shaft. Was warranty lucky for the customer.
  9. Oct 3, 2020 at 11:45 AM
    #69
    Armygreen
    I’m sure mine is not a drive shaft vibration as I had that when I lifted the truck and fixed it using carrier drop shim. Moreover it’s a totally different type of vibration. And didn’t shake the steering wheel at all.
    I guess you can try and put some heavy load in the bed and see if the vibration goes away. That could then be the drive shaft angle issue.
    when I first lifted my truck I had put all the old suspension in the bed to take it to my storage. It was there for a few days until I put tge in the storage. Going back from the storage unloaded is where I first noticed the vibration accelerating from a stop to about 20 mph.
    put some load back there and it was gone. I think it’s a good way to verify.
  10. Oct 3, 2020 at 11:46 AM
    #70
    Armygreen
    How did it end up getting out of round?
    BillsSR5 likes this.
  11. Oct 3, 2020 at 11:49 AM
    #71
    Bishop84
    No idea but moving it left to right made the other side wobble. First and only I've seen. Possibly dropped during a previous inspection.
  12. Oct 3, 2020 at 12:02 PM
    #72
    Phich
    San Antonio
    Six Demon Bag
    I would totally agree that braking vibration and driving vibration are not related, however this fact remains:
    My truck was vibration free since I bought it through a few configs.
    Follow my chain of wheel/tire combos:
    0. Stock config. Leveling kit. No vibration. 2k miles
    1. Lifted 2.5" Bilsten 5100. Stock wheels with 285/75 Pathfinder AT's. No vibration. 18k miles
    2. Same lift. 16" Level 8 MK6 0 offset wheels with same pathfinders. No vibration. 16k miles
    3. Fox 2.0 lift. Same wheels, but with 285/75 Cooper AT3 XLT. No vibration. (Heavy tires killed MPG, went for larger wheel and smaller tire) 7k miles
    4. 17" Level 8 MK6 -12 offset with 265/70 Toyo tires. Vibration at high speeds 60-70ish and while accelerating and while braking at and around those speeds.
    The only variables that changed were the wheels and tires.
    I have very little steering wheel vibration, but very noticeable seat/floor/body vibration and I can hear it. Sounds like I have mud tires at those speeds.
    Not a brake/rotor issue. Not an air pressure issue.
    The Truck did drop 1" in height due to the new tire wheel setup. It was aligned.
    Could possibly be the new angle of the driveshaft is simply an angle that the truck doesn't like. I ordered 2 degree leaf shims to experiment with if after the new Coopers are installed on Wednesday I still experience the vibration.
    I'm getting to the bottom of this fucker.
  13. Oct 3, 2020 at 12:02 PM
    #73
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Sometimes the larger more aggressive all terrain tires can enhance the vibration that may have been there prior to the lift. I would find a friend or see if someone would swap out the factory wheels and tires just to eliminate your wheels and tires for being the issue. I would try some et lugs or re torque to spec. Do you have a rear carrier bearing drop? What's the type of lift do you have?
  14. Oct 3, 2020 at 12:12 PM
    #74
    Armygreen
    I have a 4Runner as well and I swapped out my front wheels and tires with the 4Runner’s and the steering wheel vibration was gone.
    Again maybe there’s nothing wrong with the large tires and wheels but they’re just amplifying the problem/vibration from whatever it’s causing it
  15. Oct 3, 2020 at 12:13 PM
    #75
    Armygreen
    try filling the bed with a couple hundred pounds of load. If vibration is gone then the carrier drop or angle shim will help.
  16. Oct 3, 2020 at 1:16 PM
    #76
    Phich
    San Antonio
    Six Demon Bag
    Interesting you mention that, I actually just drove my previous 16" wheels/285 coopers that I sold to the freight company yesterday so there was about 250lbs in the bed (3 wheels/tires in bed, one in the back seat.)
    The truck did drive noticeably smoother, but still felt the vibration I think. Honestly I wasn't paying specific attention. Now I wish I was - I just think I would have noticed if it was suddenly a smooth ride after a month of vibrations.
  17. Oct 3, 2020 at 1:21 PM
    #77
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    ok
    is that work......mall......hooters then home
    or is that daytona for the races
    or any NFL town for Super Bowl
    miles of interstate at 70mph ot there about
  18. Oct 4, 2020 at 1:27 AM
    #78
    VaToy
    Parts Unknown
    I have a new Limited 4Runner, well my wife does. It was certified used at my friends Toyota dealership with 22k miles. Its so smooth but I detected a slight vibration after they did new tires. The cause was the back pass side wheel was not torqued to spec, in fact all were loosened and re torqued which did the trick. 4runners are sweet!
    alegerlotz likes this.
  19. Oct 8, 2020 at 11:13 PM
    #79
    Armygreen
    Hi, any updates with the new tires?
    Discount replaced my Toyo AT3’s yesterday. Drove it for 20-25 miles it was perfect. After that it started mild vibration in steering wheel while braking. No body vibration.
    This morning started the truck and there was vibration in steering wheel without even braking. At 55-65mph. Dropped it off at Toyota checking rotors as well as every other possibility...
    wondering if you had any luck?
  20. Oct 9, 2020 at 6:17 AM
    #80
    Phich
    San Antonio
    Six Demon Bag
    Still waiting on my tires! Hopefully today.
    Bummer man, I bet the smile faded from your lips after that first 25-30 miles.
    What a tease!
    Hopefully Toyota can get to the bottom of it.
    I’ll update ASAP after the new tires are installed and have a few miles on them.
