Vibration at 60 goes away when I turn right
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jaysblazer, Jul 18, 2014.
  1. Jul 18, 2014 at 3:48 PM
    jaysblazer
    jaysblazer [OP] Member
    NH
    09 Reg cab 4x4
    Skyjacker soft ride leaf springs
    Thanks Bill! looks like I will be getting the bushing kit and a driviers side cv axle. I will be driving 400 miles on the high way tomorrow. I hope this problem wont cause any delays.
  2. Jul 18, 2014 at 6:54 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Hope all went, or at least is going, well by now. Have a good, safe trip Op. :cool:
  3. Jul 29, 2014 at 8:50 AM
    jaysblazer
    NH
    09 Reg cab 4x4
    Made it to Maine and back. The vibration is worse now. I feel it down around 30 mph and up to 70 mph. I'm going to order the bushing kit for the front drivers sdie. I will see if that makes this problem go away.
    Thanks for all your help guys!
  4. May 27, 2017 at 10:44 AM
    kksrunner
    kksrunner Well-Known Member
    Whit
    Havelock
    2018 tacoma TRDOR and 2014 4runner
    5th gen T4R -3" toytec -285 trails -18" XD Grenades -Total Chaos UCA 2018 TRDOR Front: 2.5” bilstein/OME, Total Chaos UCA, driver side shim Rear: 2” Toytec Boss shocks and AAL 285/70R17 trail grapplers 17” XD grenades Spidertrax spacers
    I know this post is 3 years old but I'm curious how it worked out for you.
    hoverlover likes this.
  5. May 27, 2017 at 12:20 PM
    Muddinfun
    Muddinfun Well-Known Member
    The OP was last seen Aug 5, 2014
  6. May 27, 2017 at 12:22 PM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    I thought I was reading something up to date!:annoyed:
  7. May 27, 2017 at 12:28 PM
    kksrunner
    Whit
    Havelock
    Sorry fellas. I'm having this same issue
  8. Feb 7, 2018 at 4:15 AM
    Mt.Sums
    Mt.Sums Member
    Mitch
    All Over, Oregon
    05 2.7 4x4 access
    5100 & Toytec coils, AAL, color matched grill bezel, fogs, aux reverse lights, satin black TRD sport wheels w/ TRD Center caps
    Ugh! This is the same damn thing my truck (05 4wd access cab 2.7. 5 spd stock suspension). I've changed both CV axles. Put in the ECGS clamshell bushing, changed all diff fluids, new rear driveline U joints. 0% success so far. Mine is an intermittent vibration, like pulses, and it's most noticeable at ~35 mph and at ~ 65 mph. Mine also goes away when I turn left. Somebody smart please help me!
    kksrunner and Alexely999 like this.
  9. Mar 20, 2018 at 2:07 PM
    kksrunner
    Whit
    Havelock
    Did you ever figure it out?
  10. Sep 30, 2019 at 2:51 PM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    Reviving an older post hoping for some resolve. I've got a good howl going between 40-75. Turning to the right makes it stop completely. New CV, fresh fluid, good U-Joints, etc. Any ideas?
  11. Jan 31, 2020 at 6:01 PM
    Dvolcan
    Dvolcan Member
    05 6spd dcsb 4x4
    Icon, GFC
    So just finally fixed my howl/roaring noise that would put a vibe in my steering wheel then disappear on a left turn.
    Everyone told me if it went away on a left turn then it was a driver side bearing. Switched out driver wheel bearing and pulled needle bearing and switched it out with ecgs clamshell bushing. In the end, no fix to the problem but now driver side is solid with new bearings and that clamshell bushing.
    So I then tore out my passenger side wheel bearing. Spun that thing and it sounded like shit. Put the original bearing that was on the driver side over to the passenger side and problem fixed. No sounds, no vibes.
    quick way to diagnose is pull the wheels off the front. If you hear a sound spinning the hubs that’s probably the problematic wheel.
    Hopefully that helps.
    Ts77 likes this.
