Vibration between 110 - 120 kms/hr
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alquimista, May 29, 2017.
  1. May 29, 2017 at 12:04 PM
    Alquimista
    Alquimista [OP] Active Member
    México
    2012 TRD Sport 4x4 Double Cab
    Hi,
    I have a 2012 4x4 Tacoma TRD; at 94,000 kms, transmission had a normal maintenance (oil change, etc). Now its 113,000 kms, and yesterday I perceived that between 110 - 120 kms/hr, there is a vibration felt only with acceleration pushed. If I release accelerator, vibration is not there. So, is not related to tires... Its something mechanical resonating at those speeds. At 130 Kms/hr or more, no problem.
    What can it be?
  2. May 29, 2017 at 12:13 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    spark plugs, wheel bearings, shaved pinon gears, axle shaft yaddayadda. honestly could be so many things. I would just go get it checked out.
  3. May 29, 2017 at 1:08 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    That's kind of weird. Especially since it is not showing up until you get that fast.
  4. May 29, 2017 at 2:01 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Have you checked your carrier bearing?
  5. May 29, 2017 at 6:53 PM
    Lthompson
    Lthompson Well-Known Member
    try to determine if its exactly that speed sensitive or if its Rpm sensitive. put it in fourth and see if it does it at the same relative rpms. I have something very similar, but its rpm sensitive, It does it in all gears at about 1800 to 2200 rpms. But is most noticeable in 5th. So to me that rules out any driveshaft issues. Driveshaft issues should be speed sensitive I would think. so far haven't found a fix, and nobody seems to have a clue.
    Alquimista [OP] likes this.
  6. Jun 3, 2017 at 7:07 PM
    Alquimista
    México
    Yesterday I tested it on road; seems to be speed sensitive; I better sensed it and vibration starts around 90, peaks at 100-110, and after 125-130 it vanishes. Releasing accelerator in vivration speed range, it disappears. If I push a bit the accelerator, vibration clearly comes back.
    A friend that had a Tacoma 2008, mentioned that he perceived something similar, After changing transmission and differential oils, problem fixed. In mine, I changed transmission oil not long ago; differential, had never maintained it, and don'rt know if previous owner did it (I have had this truck for about 2 years).
  7. Jun 26, 2017 at 5:08 PM
    Lthompson
    any updates?
  8. Jun 26, 2017 at 6:22 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    What's a kilometer?
  9. Jun 26, 2017 at 7:12 PM
    Alquimista
    México
    This part (Center Bearing - Toyota (37230-0K030)) was broken:
    https://www.amazon.com/Genuine-Toyota-37230-0K030-Support-Assembly/dp/B00GHK6Y0C
    The center rubber was broken. The whole traction tube (sorry, don't know the name of that part in English; in Spanish its named "flecha" (arrow) and goes from the transmission gear box, to the back traction), was loose.
    The part was changed by Toyota Dealer (kind of expensive component) and... the vibration changed a bit; was less, but still there... My hypothesis is that, something was affected in the transmission, because of that broken support, having the tube loose. The vibration is similar to the one I used to feel before transmission maintenance was done, 20K kms ago; after the maintenance, the vibration was gone.
