Vibration between 55 and 60
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bfmco7, Jan 8, 2008.
  1. Jan 8, 2008 at 7:03 AM
    Bfmco7
    Bfmco7 [OP] Well-Known Member
    Is anyone experiencing a vibration between the speeds of 55 and 60. It is a constant slight vibration that you can feel all the way up to the steering wheel. As soon as I let off of the gas the vibration stops. Any suggestions or anyone had this fixed and know what it is?
  2. Jan 9, 2008 at 7:01 AM
    missileman125fw
    missileman125fw Well-Known Member
    I have the same thing. When I first took delivery of my truck it was real bad. They put on 3 new tires and that pretty well fixed it (I have 255/50/20). But every once in awhile it will come back at 60 mph. I'm going to have the dealership look at it again.
  3. Jan 9, 2008 at 7:48 AM
    Bfmco7
    Yeah I talked to the dealer and they told me the same thing. I need to get my tires balanced.. Thanks for the info
  4. Jan 9, 2008 at 9:24 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I hear that the rear leaf TSB can cause this. Have any of you had this done?
  5. Jan 9, 2008 at 10:00 AM
    Bfmco7
    No I havent even went to the dealer yet
  6. Jan 9, 2008 at 10:48 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I heard that it can have something to do with the rear axle alignment. Has it always done the shimmy?
  7. Jan 9, 2008 at 5:48 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Check the fillings in your teeth!!!!!!!!!!!!
  8. Jan 10, 2008 at 4:56 AM
    Bfmco7
    Well that takes me to another deal. I had my truck aligned and the rear axle is off for sure!!! The only way to have this slight unalignment fixed is to have the entire rear axle replaced. Wow! Im going to have to take this thing in!
  9. Jan 10, 2008 at 7:24 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I'm pulling things out my butt now...there should be some adjustment available to align the rear axle. For the entire axle needing to be replaced seems really stupid.
  10. Jan 11, 2008 at 8:28 AM
    Don G
    Don G Old Goat
    Southern Tier New York
    "08" Tacoma Access Cab TRD Sport 4X4
    I'll have to go along with you on this one, replacement sounds kinda stupid! !!
  11. Jan 11, 2008 at 9:34 AM
    Bfmco7
    Yeah Im not sure what the deal is.. I'll find out through toyota and let you all know.
  12. Jan 11, 2008 at 12:30 PM
    dsds
    dsds Well-Known Member
    Calgary AB
    2008 DC TRD Sport - Black Sand Pearl
    TacomaWorld sticker, DRL mod, running boards, roof rack, remote start / security alarm, marker/turn signal mod, map light with dome light mod, TRD seat covers, rear spring TSB
    I had the same thing when I took mine for a test drive. Right at 55. Had service dept check it out. When I picked up truck days later and drove home it was gone and hasn't returned.
  13. Jan 11, 2008 at 12:37 PM
    surfsupl
    Gregg
    WestCoast
    Can you make thisa sticky???
  14. Jan 11, 2008 at 12:39 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    So all caps means that you're yelling. What does all bold mean?
  15. Mar 26, 2008 at 5:59 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if you dont mind getting a bit dirty.......loosen the u bolts for the rear,give it a good yank(or 3) then tighten everything back up........may align it correctly then......just my .02(especially since i kinda hate going back to the stealer)!!!
  16. Apr 13, 2008 at 8:48 AM
    04asphalt
    04asphalt Well-Known Member
    PreRunner
    is the spring tsb the cause of this defect or is it just making it more pronounced?
    somebody post up if you find a link to the class-action against toyota for this defect.
  17. Sep 10, 2008 at 3:49 AM
    mcmikey
    mcmikey New Member
    2008 Tacoma
    This vibration has been a nightmare for me. 2008 Tacoma 4WD, my sixth Toyota and first with any trouble. Steering wheel vibrates like mad above 55mph. Did it on first test drive with stock steel wheels & Dunlops. After one week, put a set of OEM alloy wheels and Les Schwab Toyos (same size as stock), and did the same thing. I've had the alignment checked & rechecked, the tires balanced 5 times, the rotors and drivelines measured for spec (all good), and it still does it. Getting worse. I've got 7K miles on it and want to get rid of it, but anyone test driving it would notice the shimmy. The dealer says it's the tires (despite the vibration being there with the original wheels AND the new ones). Schwab says it's the truck, which I believe it is. Am going to pursue it one more step with the dealer, then take it down the Lemon Law path (not excited about that). For a brand new $30K truck, this f*&cked up.
  18. Sep 10, 2008 at 4:36 AM
    cajun1_us
    cajun1_us Member
    Ponchatoula, la
    2007 TRD 4x4
    painted bumper, grile, handles, mirrors, added sport hood, tinted windows, smoked headlamps and taillamps.
    my 07 4wd did this, I also noticed that when I felt the slightest shake, around 40-45 mph, I could switch to 4h then back to 2h real fast and the vibration would go away. Dealer said the Frt axle bearings were not installed correctly at the factory. They replaced the complete assy. No more problems.
    So there is a class action on the leaf springs?
  19. Sep 10, 2008 at 12:48 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sorry about your problems!!! just wondering....you say the tires have been balanced 5 times, but were they balanced right?? were they road force balanced?? if not, that may be the problem.
  20. Sep 10, 2008 at 1:16 PM
    hoosiertaco
    hoosiertaco Well-Known Member
    Took delivery of my 08 DC TRD offroad yesterday. Same problems from 53-63mph and was told I needed 3 new tires. (egg shaped from setting on lot for long time?!?) You all have me scared now. Hope this isn't a 'here we go again'. Supose to put tires on tomorrow. Will pick up on Fri. I'll get back with the result.
