Vibration Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hatchet, Oct 15, 2013.
  1. Oct 15, 2013 at 3:15 PM
    hatchet
    hatchet [OP] Member
    Jeremy
    Newton, Iowa
    07 Prerunner
    wheels n' tires carbon filter delete
    I have a 07 prerunner and it doesn't have a carrier bearing. I did notice a one of the bearings on my u-joints was missing a sleeve but not convinced that is the source. Mine makes a vibration mostly when I let off the accelerator and gets worse when letting off going down hill. but I can't feel it in the floor, on the steering wheel, or even in the shifter. recently changed oil, trans fluid, and rear end with no evidence of wear and no change in vibration. Haven't heard any noise to do with axle wrap as described on the site. but the rear does sit lower than the front.
    and just to clarify I own a 2007 Prerunner, regular cab, 5spd. 2wd. 55k miles, no lsd
  2. Oct 15, 2013 at 3:18 PM
    Large
    Large Red
    I don't think they make PreRunner reg cabs, in the US anyway. I would get your tires rotated and balanced first.
  3. Oct 15, 2013 at 8:18 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Why are you convinced it isn't a U Joint? Esp since one is missing the seal. It doesn't take a lot of water to wash out the bearing grease and then, Rust and bearing failure.
  4. Oct 15, 2013 at 11:06 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    they def make prerunner reg cabs
    not sure if this helps at all, i'd take a look at those u joints anyway, but when 1 of my 3 u joints went bad, i'd have lots of vibs while accel, it would go away when letting off the gas, and switching in neutral, just my findings....
  5. Oct 16, 2013 at 11:21 AM
    hatchet
    hatchet [OP] Member
    Jeremy
    Newton, Iowa
    07 Prerunner
    I guess it cant hurt, anyone know of a quality brand to get. my local stores seem pretty limited to selection
  6. Oct 16, 2013 at 11:37 AM
    nammer
    Nam
    Bradenton, Florida
