Vibration in driveline after 3" lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by NWTacoma95, Jun 19, 2012.
  1. Jun 19, 2012 at 5:27 PM
    NWTacoma95
    NWTacoma95 [OP] Member
    Bellingham, WA
    95 Tacoma LX Ext Cab
    3" suspension lift
    Put a three inch suspension lift on my 95 tacoma. Now at about 10-20mph there is a vibration. bought a carrier bearing drop bracket from streetacos.com. Anyone had the same experience? and how was the outcome?
  2. Jun 19, 2012 at 5:34 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    are all your u joints in good shaped? they have been rotating at a particular angle before and are rotating at a different angle now. greased everything? the rear shaft has 6 grease zerks.
  3. Jun 19, 2012 at 5:55 PM
    NWTacoma95
    Bellingham, WA
    3" suspension lift
    Good point about the different angles. I'll put some more grease in the zerks to see if that makes a change in vibration. my question is: would dropping the carrier bearing put the driveline back into (or closer into) the original angle?
  4. Jun 19, 2012 at 6:26 PM
    2000GTacoma
    Snow Hill NC
    sometimes yes sometimes no. its hard to say
  5. Jun 19, 2012 at 6:49 PM
    NWTacoma95
    Bellingham, WA
    3" suspension lift
    Will try these suggestions and hope for the best... doesnt seem like theres any sure way to get rid of it completely. Thanks again
  6. Jun 19, 2012 at 8:44 PM
    GLD01
    GLD01 Well-Known Member
    Jamie
    Denver, CO
    Tacoma SR5 TRD
    Toytec lift coils w/Bilstein 5100's; OME Dakars w/Bilstein 5100's; Camburg UCA's; Gray wire mod; Deck plate mod; Cooper Zeon LTZ 265/75 R16 tires
    I'll be watching this thread. I just installed my lift a month or so ago and have picked up a vibration at 50-60 mph. Installed some spacers for the center bearing with no luck, thinking along the same line as some others here. I'm meticulous about greasing my entire driveline every time I change my oil, so I'm fairly certain it's not a lack of maintenance there.
    I'll update if I get it figured out. Please do the same.
  7. Jun 19, 2012 at 9:15 PM
    NWTacoma95
    Bellingham, WA
    3" suspension lift
    Sounds good GLD01. Like I posted earlier I have a carrier bearing bracket coming from www.streetacos.com that people have said some very promising things about. It will be a week or so before it arrives, but as soon as I put it on I'll post the results
  8. Jun 19, 2012 at 9:37 PM
    OmahaStylee
    OmahaStylee Beating Anorexia since 1976
    Omaha, NE
    01 DC TRD
    FRONT: Toytec CO's & diff drop BACK: AllPro standard leaf kit with Bilsteins and axle shims
    I put a 3" RevTek lift in my 96 (spacers in front, AAL in back) and I also had the vibes pretty bad at low speed - like when down-shifting for a corner.
    I greased my driveshafts all the time - didn't change anything.
    Here's what I did though:
    Earlier this year I bought an 01 double cab, and I had to sell the 96.
    While acquiring parts to lift the 01, I came across the axle shims from ToyTec > <. I ordered two sets of these, one for me and one for the guy who bought my 96. I'm just assuming these would help. :notsure:
    I've got all the makings of a good 3" lift ready to go on my truck, just don't have the time to DO it.
    I'm gonna look up this carrier bearing drop bracket you speak of 'cause I've never heard of such a thing
    (not doubting you, I'm just ill-informed)
  9. Jun 19, 2012 at 10:47 PM
    2004tacoprerunner
    2004tacoprerunner Well-Known Member
    byron, mn
    2004tacoprerunner
    I seem to remember the axle having to be re angled slightly(not sure on terminology) after a certain amount of suspension lift. This was a long time ago so thing might be different.
  10. Jun 20, 2012 at 9:05 AM
    Hoyle
    Hoyle Well-Known Member
    Cookeville TN.
    2014 DCSB 4x4 Black
    A lot of stuff.
    I just installed the drop bracket from streetacos.com, I was having issues with what I thought was "axle wrap" .. after speaking with my toyota tech friend he told me to install the bracket to put the axle back in align..
    One problem I have been dealing with since I had the truck was this Axle Wrap, I lifted the truck with new suspension, springs, shocks.. etc... No change to Axle Wrap, new brakes all around, rotors, calibers, drums, cables.. etc... Axle Wrap still still there... replaced with new Leaf Springs from AllPro.. still no change...
    Granted I'm no mechanic.. all these things needed to be replaced anyways..
    My "Axle Wrap" was comming from the last part of the drive shaft that goes in and out... ( I don't know what it's called), after installed the bracket.. it almost completly is gone.. I think that piece is worn out...
    The Axle Wrap problem I was having is every time I came to a stop.. I had a "thump, jerk" not smooth stop...
    I think about replacing that axle piece.. but my mechanic friend said it won't make a difference...
  11. Jun 20, 2012 at 10:15 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    After lifting I had vibrations at 2 different speeds. The low speed (15-20 mph) vibe was 'fixed' by lowering the carrier bearing about a 1/2" with washers.
    The 2nd vibe occurred at higher speeds, usually over 50 mph. The fix for it was lowering the front a little bit. I had cranked up my COs so I was at or slightly above 3" of lift in front. Unfortunately, with that much lift in it the inner CV boot fins were touching each other slightly. In fact, a slight groove was forming between 2 of the fins on each axle. I have adjustable COs so I could lower it enough so the fins no longer touched and the vibe went away. So far the boots have not torn where that groove is but that is the risk.
    If your inner boot fins are touching and a mark or groove is forming, that is likely where your vibe is coming from and eventually that boot is going to fail.
  12. Jun 29, 2012 at 11:20 PM
    NWTacoma95
    Bellingham, WA
    3" suspension lift
    Haven't received my cb drop bracket from streetacos. Hope to get it and install next week. will report back with results when i do.
  13. Aug 8, 2012 at 4:59 PM
    NWTacoma95
    Bellingham, WA
    3" suspension lift
    So, I finally got my cb drop bracket yesterday, and it was worth the wait! installed it today (took about 20 minutes) and poof!! the vibration is gone. My vibration was at speeds between 15 - 25 mph. streetacos.com! highly recommended, except for the long ass wait.
    Xrs-fsho likes this.
  14. Aug 9, 2012 at 10:30 AM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    FWIW, A handfull of washers will get the same affect.
  15. Aug 9, 2012 at 1:01 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Good to hear. Keep am eye on your U joint though. Mine went out completely after a year of being lifted. I have a CB drop amd axle shims now for a perfect strait driveline :cool:
  16. Aug 9, 2012 at 5:20 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    I bought brians CB drop bracket, and drove around with it for a while. It did okay, but didnt solve the problem
    So i removed it and started to add a washer every week, until it went away.
    6. washers is all i needed. about 3/4 the drop that brians bracket had.
  17. Aug 14, 2012 at 10:42 AM
    Coolidge
    So Cal, Ca
    2003 Pre Runner
    ....cool!
  18. Apr 21, 2019 at 2:31 PM
    trdproven
    trdproven Well-Known Member
    Old thread, but can someone explain how this drop bracket works, since some of the vibrations could need adjustments by a washer at a time, how does this bracket for 4" and below universally take care of all the angles?
  19. Apr 21, 2019 at 2:55 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    This only lessens the extreme angle of your cardan joint by lowering your carrier bearing. The carden joint is usually the cause of vibration after a lift. Because driveline angle is out of spec.
    They add washers to lower the carrier bearing to adjust the CB to fix the vibration. Sometimes 4 washers won't fix it, they keep adding more until the vibration is resolved.
    The problem with a CB drop is it puts undo stress at the transmission/transfer case and also at the pinion and rear driveshaft universal joint. And that's why adding shims under the leaf pack to correct driveline angle is the ideal way to go.
    A carrier bearing drop is a band-aid and really doesn't address the complete problem.
  20. Apr 21, 2019 at 3:22 PM
    trdproven
    Is this a hit or miss thing? I dont hear of anyone with that issue and almost everyone where I'm from lifts their trucks. Some doing 3" over. Is it less likely with a 2" drop or is it truly shackle caused?
