Vibration issue help please
Discussion in '1st Gen. Tacomas (1995-2004)' started by Akruspe, Jun 26, 2020.
  1. Jun 26, 2020 at 4:22 PM
    Akruspe
    Akruspe [OP] Well-Known Member
    02 pre runner sr5 v6
    So i bought the truck from my unlce and am waiting on the new title in the mail so while ive been waiting i replaced the rear diff. And put on new wheels and tires and now when im at about 60-65mph the whole truck vibrates. Where should i start to try and resolve this issue. I figured could be a drive line vibration from taking off and putting back on the driveline where it meets the diff and maybe its out of balance or as simple as an alignment. Just looking for advice please
  2. Jun 26, 2020 at 4:28 PM
    tcjacado
    tcjacado Well-Known Member
    Where does the vibration start, before the whole truck shakes.. front, middle or rear?
  3. Jun 26, 2020 at 4:35 PM
    Akruspe
    I feel it in the steering wheel. But also the truck does vibrate a little when i start it at idle but not bad
  4. Jun 26, 2020 at 6:54 PM
    tcjacado
    How many miles are on it?
    Check the front tie rods and upper/ lower ball joints.
    Could still be the drive shaft rear assembly not put exactly right. Did you lift it at all?
  5. Jun 26, 2020 at 7:18 PM
    Akruspe
    No stock suspension i checked the tie rods and them seem fine. No lift ... yet.. and 200k on it
    tcjacado likes this.
  6. Jun 26, 2020 at 7:19 PM
    tcjacado
    Ball joints on upper and lower control arms? Have they ever been replaced?
  7. Jun 26, 2020 at 7:19 PM
    Akruspe
    Im guessing i should start with an alignment because they are after market wheels on it now since i did the rear diff and also it didnt do this before the new wheels and diff
  8. Jun 26, 2020 at 7:20 PM
    Akruspe
    Im not sure because i bought the truck from my uncle so ill have to ask him and get all the recipts for everything thats been done to it
  9. Jun 26, 2020 at 7:22 PM
    tcjacado
    Lug nuts torqued properly? Check those first
  10. Jun 26, 2020 at 7:48 PM
    Akruspe
    Ok i will start with that then in the meantime.
  11. Jun 26, 2020 at 8:13 PM
    CNCist
    CNCist Active Member
    Tony
    I'll only ask cause it wasn't stated. Before installing new wheels and tires did a shop balance them?
    If so, lift the front of the truck up with the wheels on and check if you can wiggle them from top and bottom and side to side.
  12. Jun 26, 2020 at 8:20 PM
    tcjacado
    9 times out of 10 it's going to be those pesky lug nuts if the wheels were just changed or rotated.
  13. Jun 26, 2020 at 9:01 PM
    CNCist
    Tony
    It's always tough to help when we are only texting. I just want to cover the first thing you do with a set of wheels and tires. From there it would be lug nuts, my OEM lugs are not tapered, therefore I had to buy new lugs for my new wheels.
    tcjacado[QUOTED] likes this.
  14. Jun 26, 2020 at 9:03 PM
    tcjacado
    Honestly, I missed the part about new wheels and tires in op's post.:anonymous:
  15. Jun 27, 2020 at 6:47 AM
    Akruspe
    Yes they were balanced and everything and they are also the oem lugs and i have new black ones on the way to match the wheels so when those come in hopefully it will be something as simple as that. Never would have thought lug nuts could cause such a problem.
  16. Jun 27, 2020 at 6:54 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I would swap tires front to back and see if the vibration moves. If it does, its the tires, if it doesn't, its something suspension or axle. If you're feeling it more in the steering wheel than your butt, that says front end to me, but that isn't necessarily a guarantee.
    High Noon and cruiserguy like this.
  17. Jun 27, 2020 at 7:03 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I'm thinking the rear prop shaft could be an issue, possibly out of phase, especially if it was removed/and or seperate and you didn't know to keep it in phase.
  18. Jun 27, 2020 at 7:04 AM
    Glamisman
    Glamisman Well-Known Member
    are the wheels aftermarket? if so and you have the wheels and tires that were on it when your uncle owned it swap them out and go for a drive. when you pulled the driveshaft off the differental did you just lay it off to the side or did you pull the shaft apart?
  19. Jun 27, 2020 at 7:04 AM
    Akruspe
    Ok i will try that as well. Ive put a ton of money into this thing already but what can i expect with 200k on it. Still runs and drives decently other than this issue so really cant complain too much
  20. Jun 27, 2020 at 7:05 AM
    Akruspe
    I knew about it possibly being unbalanced so i marked it and thought i put it back on the same way although the mark kind of wore off so it was hard to tell. And i just moved it out of my way a little didnt fully disconnect
