vibration issue...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marksgrampa153, Apr 28, 2010.
  1. Apr 28, 2010 at 5:46 PM
    Marksgrampa153
    Marksgrampa153 [OP] Joe Pac
    Joe
    South Jersey
    08 TRD Sport
    K&N air filter, Helix Throttle Body spacer, led lights in the bed
    ever since i put my 3" spacer lift on my truck, i have had a vibration that is irritating the crap out of me....got it aligned the day i put it on....what could it be??? does anybody have the answer because it is stressin me out!! 0-25mph is the worst and it vibrates at all other speeds too P.S. got my wheels balanced too
  2. Apr 28, 2010 at 5:48 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    get the ds spacer and shims, that should help
  3. Apr 28, 2010 at 5:50 PM
    Marksgrampa153
    Joe
    South Jersey
    08 TRD Sport
    got the one inch spacers installed
  4. Apr 28, 2010 at 5:50 PM
    08pretaco
    az
    1" spacer?? what do you mean by the 1" spacer?
  5. Apr 28, 2010 at 5:52 PM
    Marksgrampa153
    Joe
    South Jersey
    08 TRD Sport
    for the front diff...what did you mean by ds?
  6. Apr 28, 2010 at 5:54 PM
    08pretaco
    az
    drive shaft. toytec sells them. you place it where the carrier is and its drops it about 1/4" i think and the shims have also been known to help
  7. Apr 28, 2010 at 5:58 PM
    Marksgrampa153
    Joe
    South Jersey
    08 TRD Sport
    sweet....im definitely gonna try that
  8. Apr 28, 2010 at 6:02 PM
    08pretaco
    az
    you could even make your own driveshaft spacer. just get some material thats however thick you want, drill a hole and get a longer bolt. i used the extra bolts from when i took off my sway bar...theres a kinda sorta diy here if you search
  9. Apr 28, 2010 at 6:08 PM
    Marksgrampa153
    Joe
    South Jersey
    08 TRD Sport
    researchin right now lol....what exactly does it extend,or drop?
  10. Apr 28, 2010 at 6:09 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    ^carrier bearing drop
  11. Apr 28, 2010 at 6:12 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    looks like this
  12. Apr 28, 2010 at 6:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  13. Apr 28, 2010 at 6:14 PM
    Marksgrampa153
    Joe
    South Jersey
    08 TRD Sport
    gonna put one on because the vibes are really buggin me...i feel like its my front end vibrating tho...i can feel it in my steering wheel...the driveshaft would have that kind of effect?
  14. Apr 28, 2010 at 6:24 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    the vibes due to improper pinion angle can be felt in the steering wheel and in your seat
  15. Apr 28, 2010 at 6:25 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
  16. Apr 28, 2010 at 7:42 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    thats what they are there for man!:D
  17. Apr 29, 2010 at 11:50 AM
    black_magic2010
    black_magic2010 Well-Known Member
    South Texas
    10 Tacoma TRD Sport DBL Cab
  18. May 19, 2010 at 5:05 PM
    taco157
    taco157 Active Member
    Brian
    Nova Scotia, Canada
    06 D-cab White
    2.5" Lift
    i have this vibration, even after i installed the Driveshaft drop spacers and the axle shims... Mine vibration is noticeable at 40mph... any ideas?
  19. May 19, 2010 at 7:01 PM
    raiders
    raiders New Member
    Sport
    I have tried all these fixes for this same issue! carrier drop diff drop rear axle shims. NONE OF IT HELPED!! Is their anyone running front billies @ 85 with rear tsb and not having vibes ? I installed rancho quick lift W tsb truck is level front shocks lifted front 2 inchs fighting vibes ever since !! . Dealer said only thing that will fix it is returning to stock ride hieght. Hoping billies @85 would be close enough
  20. May 20, 2010 at 10:03 AM
    black_magic2010
    South Texas
    Well it may also be that you bent an axle if you ever hit a curb or went over a bad pothole. Or it may be that one of your rims is bent or may also be your tires need to be rebalanced. Those are the only things I can think of that may be giving you vibrations.
