Vibration issues !!
Discussion in 'Suspension' started by steve r, Jun 20, 2009.
  1. Jun 20, 2009 at 5:41 PM
    steve r
    steve r [OP] Well-Known Member
    buford ga
    06 tacoma
    @ 25mph under acceleration im gettin a slight vibration .I feel it in the drivers seat.I do have a fadtech 6'' lift.Could it be the drive shaft somehow.It only happens @ 25mph ,no other speeds.If i let off the accelerator at 25mph it stops,so it makes me think drive shaft .
    Any ideas .Carrier bearing maybe .how do i check it ?
  2. Jun 20, 2009 at 5:46 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    Sounds like you need a tom woods drive shaft.
  3. Jun 20, 2009 at 5:52 PM
    steve r
    buford ga
    06 tacoma
    okay who do i contact for tom woods drive shaft?Ive read all the issues with vibration in search.it may be springs too .Guess ill have to replace it all .
  4. Jun 20, 2009 at 5:55 PM
    FlawedXJ
    Paul
    NorAla
    I'd check little things like alignment, tire balance, u-joints, and wheel bearings first. I think you may be right on the drive shaft though. I've got a a 3 inch lift and have a low mph vibration in the rear due to axle wrap.
  5. Jun 20, 2009 at 5:58 PM
    steve r
    buford ga
    06 tacoma
    all mentione is perfect .had it checked last week.Got new wheel bearings last week also .Everything is tight so far.I did goodle tom woods and found the site .Ill order a shaft monday
    I just have a gut feeling its the ddrive shaft>
    Thanks
  6. Jun 22, 2009 at 12:10 AM
    Dare_n
    Dare_n Member
    Hawaii
    08 D-Cab 4x4 SB
    5% tint N-FAB STEPS WET OKOLE SEAT COVERS AFE INTAKE AFE THROTTLE SPACER
    How much you paid for the Tom Woods drive shaft? Does this only happen with fabtech lifts?
  7. Jun 22, 2009 at 6:39 AM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    tom woods driveshafts are around 400-500 and vibrations could happen with any lift, i have 3" in front and 2" in rear and have vibrations below 5mph.
  8. Jul 10, 2009 at 12:24 PM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    Are you just going to live with it? Or are you going to try to fix it? I might have the same on mine (hard to tell), it feels just like I have REALLY knobby tires for a quick moment under normal acceleration from a stop.
  9. Jul 10, 2009 at 12:30 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Toytec sells a carrier bearing drop kit for about $11. Cheap, easy thing to try before dropping hundreds on a new driveshaft. For many people it fixes the issue by lessening the driveline angles.
  10. Jul 10, 2009 at 12:33 PM
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2016 Limited DCSB 4x4 Blazing Blue
    Silly thought but I know when they installed that 6" lift you had to have a drop differential bracket installed. That is still in place right.
    Truck looks good by the way. Im going to get mine back from the shop here soon. Finally got that rear bumper installed and went up 2 more inches to get passed those tires rubbing.
