Vibration MEGA THREAD!!!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lonecountryboy, Apr 4, 2012.
  1. Apr 4, 2012 at 4:27 PM
    lonecountryboy
    lonecountryboy [OP] Well-Known Member
    Welcome to VIBRATION NATION
    So it seems there are more and more threads on vibration problems so I did a search for everybody to go through and posted the link below, thought it would be helpful to put this out there. If you have a take off shudder or a speed related vibration especially around 20-30 mph this thread is for you.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/153050-just-fixed-driveline-vibration-free.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/212814-vibrations-observations-conclusions-etc.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/187518-2012-stock-tacoma-driveline-vibration.html
    Oops first thread didn't work here are some starters.
    Discuss and post your fixes and problems
  2. Apr 4, 2012 at 8:29 PM
    seric007
    seric007 Well-Known Member
    I dub this, the official 10 stages of Stock Driveline Vibration
    good luck (my advice, jump to step 10) :D
    1. first your going to go in and the dealership will tell you its normal
    2. then your going go back and say its not, they will look at it.. test drive it and tell you they cant feel the vibration
    :argue:
    3. you will drive for several more days as the vibration gnaws at the core of your very soul.
    :frusty:
    4. you will go back, again and now their "master tech" will say, "o yeah its a problem but, we call it a characteristic of the vehicle".. again you will leave
    :censored:
    5. a couple days and 4000k shudders later you will escalate it to Toyota customer service in a rage-frustration fit....
    :rant:
    6. then you will go back toyota and the dealership will "drop your axel and put you in 4hi" to confirm its the rear driveshaft, then they will promptly replace your rear driveshaft
    :wink:
    7. you will leave happy...
    :yay:
    thinking problem gone
    but its not.....
    :facepalm:
    9. you will go back and toyota will send out a 50 man team of "engineers" out that will do nothing more then spend days with your truck scratching their head....
    :pray:
    10. you will inevitably get frustrated and give up after spending the equivalent of 10 days of your time and skipping out early on work several times to "drop the truck off", learning to deal with the vibration/shudder.
    :proposetoast:
    OR (Secret step 11) Design you own Custom solid 1 piece drive shaft with a CV joint (sorry prerunners) from a 1999 4runner and call it a day. ;)
  3. Apr 4, 2012 at 8:32 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
  4. Apr 4, 2012 at 9:41 PM
    seric007
    c'mon thats :rofl:
  5. Apr 4, 2012 at 11:10 PM
    TacoMaster83
    TacoMaster83 Member
    2012 MGM 4.0V6 DCSB Prerunner/TRD Off
    ^^^LOLOL
  6. Apr 5, 2012 at 9:03 AM
    lonecountryboy
    LOL how many have heard its normal for your teeth to rattle at 20mph?
  7. Apr 5, 2012 at 9:46 PM
    seric007
    seeing a lot more questions today, figured worth a bump :bananadance:
  8. Apr 5, 2012 at 10:33 PM
    SOMDTACO
    SOMDTACO Well-Known Member
    Sean
    Southern Maryland
    96 Extended Cab 4x4 2.7 MT
    New Taco: 96 DLX Extended Cab 4x4 2.7,MT, Bilstein 5100s at 2.5 and HS 3 Leaf AAL Old Taco: 11 Prerunner Maxtrac Spindles in the front, 2'' AAL with Bilstein 5100 extended in the back. 18'' Milanni Stellars wrapped in 265/70/18 General Grabber tires.
    Why do you say "Sorry Prerunners"? Prerunners can't utilize a one piece drive shaft???
  9. Apr 5, 2012 at 10:37 PM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    I am guessing that since we dont have a x-case, our drive shafts are too long to use a 1 piece? Hence the need for a carrier bearing.....
  10. Apr 5, 2012 at 10:51 PM
    hitmans.army
    Myrtle Creek, OR
  11. Apr 6, 2012 at 6:35 PM
    seric007
    Yup that is 100% , ask me how i know :(. lol i am a prerunner
    but in all seriousness it is too long sans transfer case :(
  12. Apr 6, 2012 at 6:36 PM
    seric007
    Correct,
    the option for prerunners is to add a CV joint at the front of the 2nd axle..... :spy:
    but....
    this will cost you nearly the amount of a solid 1 piece drive shaft, so you might as well buy that instead.... but we cant use it, DAMMNIT! so this option becomes way to much $$$ for what you get. :evil:
    so just get yourself some M10 bolts, a stack of washers and figure out the exact drop for your carrier bearing. :cheers: (don't drink and drive while making test runs)
    +1 CHEAPNESS! :woot:
  13. Apr 6, 2012 at 6:54 PM
    lonecountryboy
    So anybody out there measure there t-case mount yet? Maybe over the weekend we could get some measurements posted up to compare the rear height if you don't know what I am talking about read the second link in the first post.
  14. Apr 6, 2012 at 7:06 PM
    seric007
    im a prerunner, so im sure its different but out of the million times i've been under the truck i always keep coming back to i need to RAISE my transmission to drop the angle at the 2nd driveshaft.. but i never thought about the shudder coming from the 1st.. BACK TO THE ANGLE FINDER BATMAN!
  15. Apr 6, 2012 at 7:16 PM
    lonecountryboy
    So the pre-runner has a CB and without the t-case it is a slip yoke into the transmission?
  16. Apr 6, 2012 at 8:47 PM
    wado66
    wado66 Well-Known Member
    Maybe mine is a different issue. But with 100 miles on my Tacoma DCLB When I get in it a start going down the road I get a lot of steering wheel wobble/vibration. It will fade out some as I drive. And as I get about 7 miles on them the vibratoin is minimal. But still there slightly.
    I'm hearing a lot of issues on this site on vibration. But for mine i am suspecting the roundness of the tires. Or a balancing issue. And I really hope that is all it is. Seems like the colder the tires are the more they vibrate, And as they warm up the vibration just about goes away.
    Anybody eliminate their issue by concentrating on the tires?
  17. Apr 6, 2012 at 11:20 PM
    seric007
    if you pay attention its easy to tell the difference. yours is def tire related. ours you can feel in the body/rear.. not in the wheel
  18. Apr 7, 2012 at 2:44 PM
    seric007
    you, sir are 100% correct
  19. Apr 7, 2012 at 3:55 PM
    lonecountryboy
    interesting will the 4runner fix work for that?
  20. Apr 7, 2012 at 5:21 PM
    mondexyota
    mondexyota Well-Known Member
    Beau
    Titusville, FL
    2010 Barcelona Red DC SR5 4x4
    3" Toytec spacer lift, 285x70x17 Nitto Terra Grapplers on 17x9 XD Misfits
    Ive heard of Tom Woods one piece drive shaft? Anyone have any input on this? Here is a kink to the site...http://www.4xshaft.com/
