Vibration on acceleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ehky, Sep 19, 2008.
  1. Sep 19, 2008 at 2:29 PM
    ehky
    ehky [OP] Member
    I have read several posts about vibration during acceleration and have a similar problem with my 09 Tacoma (6 cyl auto, 4WD, 1000 total miles.)
    When I accelerate at a normal rate in first gear, I can feel a vibration in the steering wheel/center console as I go through about 2000 rpm or 10 mph. It does not happen in any other gear or at any other speed.
    I cannot notice it when I let the vehicle idle down a hill and then slowly accelerate. It is also not very noticable when accelerating up a very steep hill. It is pretty minor and you must be on a smooth road to notice it...it is almost as if the back tires are going over a series of very very small speed bumps.
    Any of you Tacoma gurus have any thoughts on this? Should I have the dealer look at it? One of the salesmen told me it was the result of "loading up very tight leaf springs with no resistance (weight in the back.) It will get better."
    ChadsPride likes this.
  2. Sep 19, 2008 at 3:12 PM
    LDrider
    LDrider Well-Known Member
    New England
    2019 SR 2.7 Access Cab 4x4 (sold to Carvana!)
    My truck has been doing that since new and it has never gone away. In fact, I now have a vibration between around 42 and 48mph in addition to the 18mph vibration. Have about 13,000 miles on my truck and as soon as I pay it down a little bit more I will off it...not a happy camper at all.
  3. Sep 19, 2008 at 5:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    First, Salesmen are stupid.
    Second, Its probably the carier bearing. Mine does the same thing, and has since it was new. No biggy in my eyes, but if you want, you can try and use an axel shim inbetween the leaf pack, and drive shaft to help. Or, you can install a one peice drive shaft. :)
  4. Sep 19, 2008 at 5:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    42 to 48 mph vibes sound like a tire out of ballance.
  5. Sep 19, 2008 at 5:40 PM
    weihenstephaner
    weihenstephaner Well-Known Member
    Atlanta, GA
    2009 4x4 TRD OR DC SB Mag Grey (SOLD)
    Bought a Tundra
    i've got the same thing on my 09. first gear only. it doesn't really bother me, so as long as it's not causing any problems i'll probably just live with it. unless they come out with a TSB for it, which seems unlikely.
  6. Sep 19, 2008 at 7:48 PM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    The only vibration I get is when I get into the 1800-2000RPM range.
    Seems normal enough.
  7. Sep 20, 2008 at 10:20 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    to me it doesnt really seem like a vibration but more of a "shudder" through the truck. mine does it all through 1st, up to about 22mph and it is magnified when towing heavy loads. it seems its most definitely the center carrier in the 2 piece rear drive shaft, the cross member just isnt rigid enough. swapping to a one piece shaft sounds like the best solution but is there a real reason that toyota made it the way they did?
  8. Sep 20, 2008 at 10:45 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    ehky go for a road test with a tech to show him the vibration you are feeling then ask him about this tsb they have an updated rear trans mount for driveline vibration between 15-25 mph.http://www.tacomaworld.com/forum/at...acoma-auto-v6-access-cad-trd-t-sb-0132-08.pdf
    TacomaMike37 likes this.
  9. Sep 20, 2008 at 11:09 PM
    RelentlessFab
    Eric
    Sparks, NV
  10. Sep 21, 2008 at 6:25 PM
    Tacoberry
    Tacoberry Member
    Richmond, Kentucky
    2004 Prerunner V6 Double Cab
    Lots of dog hair
    Great News! Thanks for mentioning this Beef! I've beat my head on the service manager's desk several times over my 'shimmy' at 15MPH. I've even had a tech ride w/me and had them 'document' the issue....now I have the goods.
    I'm on the phone tomorrow to set this up. :proposetoast::proposetoast:
  11. Sep 21, 2008 at 7:06 PM
    ehky
    ehky [OP] Member
    beeftaco,
    I think that I'll do that. I appreciate the info. Just one question, though: If in fact it is a faulty carrier bearing, wouldn't the shudder/vibration get much worse with increasing RPM's? As I said, the only time I feel it is between 10-15 MPH in first gear only.
  12. Sep 21, 2008 at 7:21 PM
    BeefTaco
    The TSB is for replacement of the rear trans mount the shudder is not in the drive line itself according to Toyota.
    I think it might balance its self out at higher rpms or your just not feeling it. I have a shudder right around 12 13 mph but haven't changed the mount to see if it goes away or not I am blaming it on the tires right now.:p
  13. Sep 22, 2008 at 4:06 PM
    Tacoberry
    Tacoberry Member
    Richmond, Kentucky
    Lots of dog hair
    Not to keep beating this horse, but has anyone has this TSB done to their ride yet? Driveline Vibration between 15-25 MPH 0132-08. It came out in mid July.
    Curious to see if this actually solved anyone's problems...
  14. Mar 20, 2009 at 8:28 PM
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    I get this same vibration, did you ever get it fixed, it cant be normal, only at 1800- 2000 rpm+ in every gear at this rpm ...
  15. Mar 20, 2009 at 8:54 PM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    For 2005-2008 Tacomas see this TSB, I am not sure if this carries into the 2009's. You will usually see this shudder and light load and throttle like going up a hill and just accellerating enough to keep speed. I hope this helps
  16. Apr 14, 2009 at 7:48 PM
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
    I have a 2009 and jsut recently had an OME read spring pack installed with new shocks. I had the front done too. I had the front done a few weeks ago and did not notice any change. They just finished the rears today and now the thing vibrates like hell in the low RPM and speed range. DAMN IT! i woudl say yes, looks like it carried over. The odd thing about it... I either did not notice it at all during the first 4000 miles of driving or it came about as a result of the rear leaf pack... thoughts?
  17. Dec 8, 2016 at 10:24 AM
    zrosales
    zrosales New Member
    07 TACOMA 4X4 TRD
    NONE, YET.
    On my '07 Tacoma TRD it was the Carrier bearing causing a severe vibration when accelerating, most noticeable from 20-40 mph. All 3U-joints were replaced since they were in bad shape also after 144,000 miles.
  18. Dec 8, 2016 at 12:53 PM
    badger
    badger Well-Known Member
    07 SR5
    My guess: It's happening in first gear because of the torque delivered to the rear axle, causing axle wrap. This changes your pinion angle for a brief time and sets the u-joints out of phase. The weak stock rear springs are the cause, and if your drivetrain alignment is a little off to begin with, then you get exactly what you described. Look here: https://www.youtube.com/watch?v=r-qy0qzdl6E Start at 1:25 and you will see how far the pinion nose lifts during takeoff. That momentarily changes the driveline angles.
    Chopperrescue likes this.
  19. Dec 8, 2016 at 2:13 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Now this was one hell of a thread revival!
  20. Jun 15, 2017 at 9:59 AM
    Tacobot14
    Tacobot14 Heep Recovery Vehicle
    Ty
    North Carolina
    2015 TRD OR White Tacoma 6MT
    OME BP-51, JBA UCA, SOS Streamline Bumper, SOS Sliders, Toyo AT2 tires, many more.
    Is anyone else getting a very quiet hum with this aswell? I have one that's consistent with my speed and has the described vibes here
