Vibration/Shuddering problems 06'tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hop6669, May 8, 2011.
  1. May 8, 2011 at 10:31 AM
    hop6669
    hop6669 [OP] Member
    San Jose, CA.
    06' Tacoma Prerunner
    Experiencing virabrations/shuddering at take-off and while excellerating. Seems to be getting worse as time goes by! What is causing this?
  2. May 8, 2011 at 10:40 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    bad u-joints, do you have a lift of some sort? could need a axle shim or carrier bearing drop.
  3. May 8, 2011 at 11:19 AM
    hop6669
    hop6669 [OP] Member
    San Jose, CA.
    I installed air bags on rear suspension to help with rear-end sag
  4. May 8, 2011 at 11:51 AM
    08pretaco
    Oliver
    az
    Is that all your truck has done to it?
  5. May 8, 2011 at 12:37 PM
    hop6669
    hop6669 [OP] Member
    San Jose, CA.
    Went to a taller tire from 245 to 265 that's it
  6. May 8, 2011 at 1:10 PM
    08pretaco
    Oliver
    az
    It might be the tire balance. Did you make sure they did a dynamic instead of just a static?
    Did you go to a mud terrain by chance?
  7. May 8, 2011 at 1:38 PM
    hop6669
    hop6669 [OP] Member
    San Jose, CA.
    No, 10 ply highway tire
  8. May 8, 2011 at 1:39 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    My truck had the same problem and it was a u joint . It only happens when you press the gas not when it's just rolling. Right???
  9. May 8, 2011 at 1:46 PM
    hop6669
    hop6669 [OP] Member
    San Jose, CA.
    Really pronounced at take-off and while turning, and while driving 45 mph or faster
  10. May 8, 2011 at 1:47 PM
    08pretaco
    Oliver
    az
    Try doing a tire balance first as thats the easiest to go about, then I would try a u-joint.
  11. May 8, 2011 at 1:48 PM
    stevenstaco
    stevenstaco B A N N E D
    steven
    sacramento ca
    o7 trd sport sr5 4x4/06 4runner sr5 4x4
    1.5 aal,Tacomaworld sticker,Blacked out tail lights,bhlm,.dumped exhaust,relocated 7 pin ,rear diff breather mod,bed lights,hella 500s behind the grill,plastidipped lower vallance,mag light mod,debadged,black billit grill,bedmat mod,airaid intake,vynil armrests and back rests,tailgate theft mod, ipod interface,backseat cargo mod,front 5100s
    subbed mine has a similiar problem
  12. May 8, 2011 at 1:49 PM
    Erll
    Erll Well-Known Member
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
  13. May 8, 2011 at 1:51 PM
    hop6669
    hop6669 [OP] Member
    San Jose, CA.
    I heard that it could be anything from the drive line center bearing to changing differential gear oil to drive line out of balance to possible tranny problems
  14. May 8, 2011 at 1:54 PM
    08pretaco
    Oliver
    az
    it can be a whole list on things, start with the things that are the easiest to fix so you can get those off the list and move on to the more expensive possible fixes.
  15. May 8, 2011 at 1:54 PM
    Sigi
    Sigi
    Sfv ca
    You can remove your driveshaft and inspect your u joints. I did and that's how I found the problem. It's not that hard to do. Took me about 20 min.
