Vibration when accelerating
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DrewM0419, Aug 28, 2024.
  1. Aug 28, 2024 at 6:08 PM
    DrewM0419
    DrewM0419 [OP] Member
    Hi. New to the group. Just bought a 2013 reg cab 4x4 with a 2.7 auto trans and have a vibration problem. I read a bunch of TW threads but still can’t find one that exactly describes my issue. The truck vibrates when I accelerate from a dead stop and lasts for maybe 1 second. It’s always in first gear and starts vibrating a few feet after moving. Kind of like the rumble strip description and definitely feels like it’s coming from the back. I don’t get the vibration at any other time but it’s consistently there on every acceleration. I also have what I feel is excessive clunking when putting the truck into drive after backing up and vise versa. Not sure if these two issues are related. I greased the front and rear ujoints and no change. Anyone have this same issue(s)?
  2. Aug 28, 2024 at 6:56 PM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    Driveshaft, bearings seized
  3. Aug 28, 2024 at 8:57 PM
    Dawnland Roller
    Dawnland Roller New Member
    I've got a 2012, and the same thing happens. Not all the time, but regularly. It's a bit embarrassing when it happens because it must seem to onlookers that I don't know how to drive a stick!
  4. Aug 28, 2024 at 11:14 PM
    javajunk-e
    javajunk-e Well-Known Member
    So. Cal
    '09, Super White, DCLB, 4x4, Sport.
    Tacoma all weather floor mats, N-Fab Prerunner light bar w/ Hella 500ff lights, mag-lite mod, Hi-lift jack, Wet Okole seat covers, Revenge Fab sliders, ARE MX shell with Thule racks, and a Bed Rug.
    Had a vibration like this about a year ago. I don’t think it was first gear, but it always happened between 25 or 30 mph. Once the truck shifted, the vibration stopped. It steadily got worse and more consistent at the same speed. Turned out it was my torque converter in the trans… When was the last time you changed your transmission fluid? I don’t mean to sound judgemental, because I hadn’t given any thought to change my fluid and ended up paying for it. For your sake, I hope it’s not this particular issue…. How many miles do you have? Mine started doing this around 120k miles.
  5. Aug 28, 2024 at 11:42 PM
    javajunk-e
    So. Cal
  6. Aug 29, 2024 at 4:52 AM
    DrewM0419
    SethM yeah I’ve been leaning toward the driveshaft. Thanks
    SethM[QUOTED] likes this.
  7. Aug 29, 2024 at 4:53 AM
    DrewM0419
    Thanks for this but this one’s an auto
  8. Aug 29, 2024 at 4:55 AM
    DrewM0419
    I just bought the truck about 2 months ago and not sure when/if the trans fluid was changed. I was thinking about doing that at regardless just to eliminate that as a cause
    javajunk-e[QUOTED] likes this.
  9. Aug 29, 2024 at 4:56 AM
    DrewM0419
  10. Aug 29, 2024 at 5:25 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I was chasing a vibe like that for 2 years. Turns out my driveshaft was out of balance. $35 fix. But also check your ujoints
  11. Aug 29, 2024 at 6:47 AM
    Peter603Taco
    Peter603Taco Well-Known Member
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    I know you said you greased your u joints but did you check them too with rear wheels up in the air? Sounds exactly like when I've had a bad u joint. Also probably a good time to grease the slip yoke on the driveshaft with the blue PTFE grease if you haven't, there's some threads on that.
  12. Aug 29, 2024 at 9:18 AM
    Knudsen
    Knudsen Well-Known Member
    Jon
    2008 Access Door TuRD
    To bet installed: bling grill, headlights, fog lights.
    Also ensure those u-joints are in phase. In other words, in the same orientation.
  13. Aug 29, 2024 at 2:45 PM
    DrewM0419
    Hey thanks for this advice. I did not put the truck in the air but I’ll try that next
  14. Aug 30, 2024 at 5:01 AM
    Peter603Taco
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    No prob it's worth just getting the rears a bit off the ground. Didn't realize it made much of a difference until my mechanic caught one that was going that you couldn't tell with wheels on the ground and let me know
  15. Aug 30, 2024 at 9:27 AM
    SethM
    Seth
    Los Angeles ca
    Anytime, check that rear diff ujoint
  16. Sep 14, 2024 at 5:05 PM
    DrewM0419
    Update- I swapped the driveshaft and the rear trans mount. I still have this vibration, which I’m now calling a wobble. Trying to upload a vid to see if anyone out there has an opinion of what is causing this. Any help is appreciated!
    https://youtu.be/_JN61FrwxKc
  17. Sep 15, 2024 at 12:39 PM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    Was having a similar issue and it ended up being my drive shaft. Should hopefully have it fixed this week :fingerscrossed:
  18. Oct 1, 2024 at 6:44 PM
    DrewM0419
    Oh man. Well, I’m now into this vibration for a new driveshaft, rear trans mount, and just replaced the rear leaf springs with icon rxt’s. My vibration, or wobble, is still there. Trans fluid is full and I added lubeguard shutter fix. Not sure where to go next. Thinking maybe the motor mounts? Any ideas are welcome
  19. Oct 2, 2024 at 9:51 PM
    Bosco369
    Bosco369 Active Member
    Russ
    Temescal Valley
    2006 Tacoma 4x4 TRD
    Replacement drive shaft, OEM or after market? Could be out of balance. Replaced my drive shaft at 90k with OEM and was balanced. Solved vibration.
  20. Oct 2, 2024 at 10:19 PM
    TacoJoeBro
    TacoJoeBro Well-Known Member
    Not Joe
    Midwest
    12 DCSB OffRoad
    6112/5160 Icon RXT JBA KO2
    Was the truck lifted when you bought it?
    Have you checked/measured you driveshaft angles? Since it only happens on take off and it’s lifted, it’s the first place I would look
