vibration when hard braking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by samsung, Dec 31, 2011.
  1. Dec 31, 2011 at 1:24 PM
    samsung
    samsung [OP] Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    hey guys, has anybody had any issues with brake pedal vibration when hard braking only? I don't know if it's coming from my OME lift or when i switched to my duratracs. It's not anything getting worn out, i only have about 2k miles on my truck. i've had my ome lift for about 5 or 6 months now and haven't really noticed any vibration until i had to hard brake today. i also have the DSM uca's any input?
  2. Dec 31, 2011 at 1:29 PM
    BARTRD
    BARTRD Well-Known Member
    Brian
    Monroe, Ga
    '07 RR TRD Sport
    Volant CAI with optional skoop, Magna-Flow exhaust, K&N drop-in air filter, WeatherTechs, Wet Okole, kenwood navigation head unit, de-badged, 15% tint all around, factory roof rack fitted with Thule fairing, billy 5100 on all 4 corners, ICON AAL, n-fab light bar with 4 hella 500s, rear lights mounted under bumper
    warped rotor? if so, its very common. mine does it a little bit from time to time. it may gradually go away on its own. or you may have to have them machined down.
  3. Dec 31, 2011 at 1:30 PM
    samsung
    George
    Sugar Land, Texas
    i don't think so. the brake pedal actually vibrates pretty badly. it was kinda wet this morning when it happened tried again this afternoon when it dryed up and samething. it feels like something is loose in there. it only does that when i get on the brakes pretty hard.
  4. Dec 31, 2011 at 1:31 PM
    samsung
    George
    Sugar Land, Texas
    my truck only has about 2k miles on it.
  5. Dec 31, 2011 at 1:34 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    This. My sister's 4Runner had bad rotors and did the same.
  6. Dec 31, 2011 at 1:35 PM
    tacoman_KC
    tacoman_KC Hurray for Zoidberg!
    John Zoidberg
    Arizona
    Subaru Outback
    I get a vibration when I brake too, Everything seems to be mechanically sound so I think in my case its just from my duratrac tires.
  7. Dec 31, 2011 at 1:36 PM
    BARTRD
    Brian
    Monroe, Ga
    '07 RR TRD Sport
    very easy to warp. all it really takes it getting on the brakes hard one good time. try driving it easy and braking easy for a little bit and see it if fades away. warp is caused by the heat build up. my buddy who drives like a bat out of hell drove my truck the other day, now i have the same issue u do. but it has faded over the past week.
  8. Dec 31, 2011 at 2:55 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's, Pioner AVH-2300NEX w/backup camera, SCT X4 Tuner.
    Overheating and improper lug nut torque can cause premature rotor warpage.
  9. Dec 31, 2011 at 3:27 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    warped rotors will not fix them selfs.if there warped....there warped until they get turned down
    correct....torque is very important,and it wont take long(2000miles)to develop vibs on your peddle
  10. Dec 31, 2011 at 3:55 PM
    samsung
    George
    Sugar Land, Texas
    it's seems to happen after i put on my duratracs on. I haven't really had that problem with my bfg's or maybe i just didn't brake hard enough with the bfg's
  11. Dec 31, 2011 at 4:01 PM
    YotaMark
    YotaMark Well-Known Member
    Mark
    Mentor, Ohio
    08 Tacoma 4 cyl 5 speed 4X4
    Rear Gate security Mod (although I seldom take my eyes off it) "Harsh Ride" Shocks and Springs TSB performed by "Me" New Cooper Discoverer AT3s 265/75R16s (fit well) Front "Tacoma Mike" light mod! Rugged Ridge floor mats. Bought another set of D rings and installed them in my wheel well. Perfect! Just hit the big 6000 Miles 12/19/11, Installed an alarm system to go with my factory power door locks 1/21/12
    +1 resurface the rotors.
  12. Dec 31, 2011 at 4:18 PM
    samsung
    George
    Sugar Land, Texas
    hard to believe it's the rotors, since truck only has about 2k miles on them? what caused rotors to warp?
  13. Dec 31, 2011 at 4:43 PM
    MrsPib
    MrsPib Well-Known Member
    Angie
    Texas
    '09 SWB 4.0 6-speed semi-debadged
    clear DTRLs, AMO Buckshots, factory upgrades, lifted
    Rotors can warp at any mileage. A common way for rotors to warp is taking a hot rotor and cooling it too quickly, such as riding your brakes right before a puddle. Think about taking a hot pan and throwing it into the dish water. The pan will warp and won't sit flat on the stove afterwards. Having faulty rotors won't help either.
    Take it to any brake shop to have the rotors, pads and calipers checked. A good shop will provide a free brake inspection and will be able to tell you exactly what's going on.
    edit: judging from your signature pic, you have a lot of weight up front too. The force your brakes need to exert to stop that weight/momentum will cause them to heat up quicker than normal while braking too. Couple that with the abundant rain we had a couple weeks ago and you have yourself a likely suspect (of warped rotors).
  14. Dec 31, 2011 at 4:46 PM
    samsung
    George
    Sugar Land, Texas
    just noticed you're a chick. i'm taking advise from a girl? JK
    thanks for the advise will take it to a brake shop and have them check it out. if it's the rotor, it should be covered under warranty?
  15. Dec 31, 2011 at 4:56 PM
    MrsPib
    Angie
    Texas
    No, it's a wearable/consumable part. Only if the rotor material is found to be faulty and Toyota begins seeing a trend in warping rotors at low mileage could you hope for a TSB and compensation.
  16. Dec 31, 2011 at 5:54 PM
    Bosmob
    Bosmob Well-Known Member
    Kevin
    San Diego, CA
    '11 Access Cab SR5 I4 4AT
    Fat Bob's 2.75" front spacers Magnaflow Muffler Doug Thorley Header ImMrYo Mirror Bracket
    Try this to see if it fixes the pedal pulsation. It's a trick I learned when my friend and I use to, shall I say "hustle" cars...
    Take a garden hose with no attachments on the end and run water straight on to the front brake calipers for a good five minutes. Then shut the water off and go for a drive.
    It should temporarily fix the pulsation but if it returns within a couple hours, your rotors are warped...:D
  17. Dec 31, 2011 at 6:22 PM
    Toyotaguy
    Toyotaguy Active Member
    Bill
    NY
    TRD Offroad
    Sockmonkey decals - cold air intake - tanneau - window vent - bug shield - seat covers - yellow fogs - fog anytime mod
    It was wet when you hard braked and vibration happened? Do you have ABS?
  18. Dec 31, 2011 at 6:45 PM
    Maticuno
    03 F250 CCSB
    If it happened after you got your Duratracs, then it probably means the shop who installed them over-torqued the shit out of your lug nuts when re-installing the wheels. Combined with a couple of hard stops, that is a recipe for warpage.
  19. Dec 31, 2011 at 6:53 PM
    samsung
    George
    Sugar Land, Texas
    yes it was very damp when it happens.
  20. Dec 31, 2011 at 6:56 PM
    samsung
    George
    Sugar Land, Texas
    i will check my lug nuts tomorrow and see how tight they are on there. Discount tires put those on there for me. i've been going to them for a while and never had an issue with their work but i'll check them out tomorrow. thanks
