Vibration when slowing down...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Falcon86, Jan 3, 2011.
  1. Jan 3, 2011 at 12:59 PM
    Falcon86
    Falcon86 [OP] Well-Known Member
    Virginia Beachshire
    Bone-stock
    I originally thought it was the brakes, now I have a feeling it could be the tranny. 2k miles on my 2011 PreRunner. When I come up to a light and I'm either coasting or lightly braking, I can feel a vibration. I think it's coinciding with when the auto transmission is downshifting from 2nd to 1st gear.
    Any input?
    Seems to do it mostly when it's cold (when first starting in the morning until it's good and warm), but lately it's been doing it more and more anytime.
    Any input?
  2. Jan 3, 2011 at 12:59 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    is the vibs in the pedal..if they are then it is rotors
  3. Jan 3, 2011 at 1:04 PM
    Falcon86
    Virginia Beachshire
    Bone-stock
    Pedal and steering wheel. And if I had a passenger they'd probably be able to feel it too.
  4. Jan 3, 2011 at 1:07 PM
    bishtacova
    bishtacova Don't buy a Ford
    2009 DC PreRunner V6
    4 leaf TSB, reflash ECM, Eurostyle antenna, thule roof rack, bed extender
    I had the same thing, got the rear brake drums replaced as the vibe was in the seat. Took care of most of it but the main culprit appears to be the torque converter. You'll still get the downshift vibe, which sucks on a new vehicle!
  5. Jan 3, 2011 at 1:11 PM
    Falcon86
    Virginia Beachshire
    Bone-stock
    So everything's functioning as intended, this is just a terrible by-product? The only way to alleviate the problem (while it's happening), is to compress the brake pedal much harder (thus shifting into 1st sooner). Again, it could be the brakes or it could be the tranny, but it seems to always happen when slowing/downshifting from 2nd to 1st.
  6. Jan 3, 2011 at 1:21 PM
    juicedgsr95
    juicedgsr95 Member
    Raleigh, nc07
    07 PreRunner TRD Sport
    I have the exact same problem on my 07. Was hoping the ecu flash with the pedal recall would take care of it but it didnt. I thought I saw somewhere that there was a tsb for the 09+.
  7. Jan 3, 2011 at 1:33 PM
    Falcon86
    Virginia Beachshire
    Bone-stock
    So upon doing some research, it sounds like the "Driveline Vibration" TSB from a couple years back, but I can't find a TSB for newer years.
    Anyone know if the current years have the same problem?
  8. Mar 11, 2011 at 5:38 PM
    Mag16tac
    Mag16tac Well-Known Member
    2018 Ford F150 XLT 2.7 ecoboost!!!!
    I have a 2011 Prerunner 2.7 double cab auto that also has a vibration when slowng and does not appear to be the brakes. I had the same problem with a 2010 5 lug extended cab I traded for this one. The dealership service director has rode with me and felt the vibration. He says it's torque converter and called Toyota and they dispatched service techs to the dealer. They flushed transmission fluid twice but that was the extent of repair before saying those famous words "vehicle is operating as designed". Sure wouild like to solve this one too but many Tacoma's are doing this and their owners are just living with it.
  9. Mar 11, 2011 at 7:16 PM
    mcleod90
    mcleod90 150,000 miles and counting
    sean
    modesto ca
    05 double cab
    Ya I have the same problem. I feel a vibration under my seat. I've just learned to deal with it v
  10. Mar 11, 2011 at 9:41 PM
    stephenm
    stephenm Well-Known Member
    Stephen
    Socal
    Interesting. I can feel this too, though mostly from the steering wheel. the vibration is also much more intense as I am using the brakes (I thought it was due to my brakes as I can't recall this problem when I first bought the truck (3+ years ago)..
  11. Mar 13, 2011 at 1:31 PM
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    You should be under warranty if it's the drums. If it does it just coasting w/o the brake it might be U joints. (also under warranty) Good luck. At 120,000 mi my ass end EXPLODED. Sheared the pinion shaft in two!
  12. Mar 15, 2011 at 4:31 PM
    juicedgsr95
    juicedgsr95 Member
    Raleigh, nc07
    There is a tsb for driveline vibration between 15 - 25 mph, I think. Mine had the vibration from 35 all the way down to 20. Nothing to do with the brakes, Happened when slowing down (coasting or with brakes) or just general cruising around in that 20 - 35 mph zone I had a vibration that felt almost like the transmission was slipping/searching for gears. I was sure is was the transmission that was going bad. I bought the part described (im out of warranty) in the tsb $50 online, around $100 at the dealer. Installed it an the vibration is gone. I was skeptical when I was swapping it out because the new part looks EXACTLY the same as the old (no stamped numbers on either). Worth a $50 shot for any of you guys out of warranty. And something to bring up to your dealer for you in warranty guys.
    Part number is 12371-31240 from T-SB-0132-08
    Hope you guys get your problems figured out!
    Adam
  13. Mar 15, 2011 at 7:40 PM
    OH9
    OH9 Member
    Colorado
    09 dbl cab auto stock
    my 09 tacoma is doing this very same thing. The dealer says they cant find the problem. What part did you replace? I am under warranty so I would like to bring it to their attention.
  14. Mar 15, 2011 at 7:46 PM
    BryWi
    BryWi Psalm 109:8
    Earth
    2011 TRD off-road DC SB w/JBL
    5100s, black valance
    I thought my vibe (between 22-27) was a lift issue. I have 5100s at 1.75.
    Maybe not.
    Hopefully they come out with a TSB for the 2011...
  15. May 1, 2012 at 7:33 AM
    Allen102
    Allen102 Active Member
    I have the same vibration , the TSB is for 2008, I have a 2011, shouldn't they have fixed the problem by now ?
  16. May 1, 2012 at 7:37 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
  17. Sep 4, 2012 at 3:39 AM
    kalsop
    kalsop New Member
    My 2012 auto is doing the same thing during first mile when its cold then it goes away. 4000miles on it. Been doing it from the start.
  18. Jun 1, 2015 at 8:31 PM
    CTtaco08
    CTtaco08 Member
    Curtis
    Vancouver BC
    08 V6 SR5 4x4
    Hi fellow tacoholics,
    I have the same exact problem and reading the TSB posted it sound like an identical case for my 08 access cab. It does have a 3" OME lift with 33s and 137k KMs on it with front wheel bearings and hubs that have only 25k KMs on them. I do have ECP and I cant wait to march into my local dealership with this new found info but I just happened to notice something... On the very first page of the TSB "Market: USA"
    I live in Canada and as far as I know my Taco is a Canadian (wooo maple leaf love), but it was manufactured in Cali, according to the sticker on the rear door. My question is would this TSB still apply in my situation. Or is there a similar TSB for Canada I don't know about? All help is appreciated.
    Thanks!!
  19. Jun 2, 2015 at 5:51 AM
    karmatp
    karmatp Well-Known Member
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    Lets face it, a lot of the time it is. Look at the sigs of guys complaining, crappy lifts done in their neighbors garage, oversized mud tires, lug centric rims, etc. Then they wonder about vibes.
  20. May 11, 2017 at 6:50 PM
    G-$$$
    G-$$$ New Member
    2010 access cab 4x4
    I have 2010 access cab 50,000 miles I got a vibration or say out of round feel in ass end of truck when I accelerate .. when I decelerate I feel a shudder around 30 mph all the way down to 20mph . feel it in my seat tires have been road force balanced twice
