Vibration while braking
Discussion in '1st Gen. Tacomas (1995-2004)' started by Deeman, Jun 30, 2020.
  1. Jun 30, 2020 at 10:40 AM
    Deeman
    Deeman [OP] Well-Known Member
    Columbus, Ohio
    2003 Toyota Tacoma RWD Base Model 5 Lug
    Nerf bars and topper
    Hi, I have a new to me 04 5 lug. When I apply the brakes I get a shake / pulsing felt mainly in the seat.
    I was taught that when you feel the pulsing on the steering wheel its the front warped rotors and when you feel the pulsing in the drivers seat it's the rear brakes. This advice has been accurate for me to date. However this 04 Taco has drum braked in the rear - can rear drums get warped?
    I only feel the pulsing when braking.
    Any suggestions on the culprit?
    Black DOG Lila likes this.
  2. Jun 30, 2020 at 10:46 AM
    andnyleswillriot
    andnyleswillriot Well-Known Member
    Nyles
    Breckenridge, CO
    2004 Tacoma TRD 3.4L
    kmc wheels w/duratracs. Bilstein 5100's. Rear firestone airbags. Jayco slide in camper
    Try getting your rear drums resurfaced. If that doesn't help maybe just do rotors/pads all around, vibrations can travel in weird ways even if you think it's one way or the other.
  3. Jun 30, 2020 at 10:47 AM
    djm228
    djm228 Professional Dumbass
    Dan
    Buffalo, NY
    1998 Tacoma SR5 V6 4x4
    While it's not very common for drum brakes to warp, it CAN happen. I would take a look at all four brakes just in case.
  4. Jun 30, 2020 at 11:50 AM
    Glamisman
    Glamisman Well-Known Member
    pull the parking brake out slowly while driving but keep the handle turned so that it doesn't lock in position... this way you separate the back brakes from the front.
    Black DOG Lila and Abeyancer like this.
  5. Jun 30, 2020 at 12:30 PM
    Deeman
    Columbus, Ohio
    Forgot about that trick. Thanks!
