Vibrations after setting 5100's at 1.75 or .85?
Discussion in 'Suspension' started by TacomaGus, Jul 26, 2011.
Vibes after Bilstein 5100 Install?
Poll closed Aug 25, 2011.
  1. No Vibes at 1.75 or .85"
    15 vote(s)
    68.2%
  2. Vibes @ 1.75 or .85"
    7 vote(s)
    31.8%
  1. Jul 26, 2011 at 7:21 PM
    TacomaGus
    TacomaGus [OP] Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    I will be installing the 5100's on my 2008 double cab 4x4 in the next week or so and want to set them at 1.75", but i have read many horror stories about the front diff bearings going after lifting the fronts on the 2nd gens as little as the .85" setting. I had the 5100's on my first gen at 1.75" for over a year and never had any vibe issues until i put on bigger tires and wider wheels (i think the increased weight and distance from the truck with the BS was the culprit on the small 4 banger).
    So who all has had good and bad experiences with putting the 5100's at the 1.75" or .85" settings?
  2. Jul 26, 2011 at 8:10 PM
    TacomaGus
    Gus
    Morgantown, WV
    Also it's not like I didn't search...this thread is a result of searching! Haha
  3. Jul 27, 2011 at 4:40 AM
    TacomaGus
    Gus
    Morgantown, WV
  4. Jul 27, 2011 at 1:12 PM
    Koby
    Koby Well-Known Member
    Vancouver
    06 access trd
    2in OME suspension lift ARB bull bar 8000lb WARN 32`duratracs on 17 procomp 7033`s
    My 2" OME lift has resulted in plenty of driveline vibration. I've done everything to remedy it to no avail. I'm going to a specialty shop tomorrow to have a fabricated one piece drive shaft installed. If you do the lift and have vibrations, check your working angles first, and then just get a one piece. I'll let you know tomorrow how I made out! The 7105's should be available by mid September. I'm just settling for the 7033's. If you don't mind waiting, get the 7105's for sure!
  5. Jul 27, 2011 at 1:29 PM
    thebottomline
    thebottomline Well-Known Member
    Pac NW
    11 sport
    1.75 inch installed and no vibration at all. Had a bit of a hassle getting it properly aligned, but overall it did well.
    I also had the toytec 1/4inch spacer installed on the driver side, which leveled the front.
    I posted awhile back on my experience with the installer in clarksburg, who did a good job but customer service was poor.
  6. Jul 27, 2011 at 1:58 PM
    hamNswiss on rye
    hamNswiss on rye ¡Yo Quiero Taco World!
    Nick
    Scottsdale, AZ/Portland, ME
    '07 4x4 Access Cab
    OME 885's and billies all around, allpro apex front bumper, Nfab tire carrier, black magic rallye 1000 driving lights, custom back to the future light rack, KC LED Daylighters, PIAA 510 fogs, bed lights, satoshi, 285/70/17 Duratracs
    added 1.75'' with little to no vibration, but then went up to a 265/75/16 tire from the stock 245s and have a pretty substantial vibe at 65-70mph. im thinking they had a harder time balancing the 265s or they werent as easy to align
  7. Jul 27, 2011 at 3:20 PM
    TacomaGus
    Gus
    Morgantown, WV
    did you lift the rear as well? thats prob where your vines are coming from which shims or a carrier bearing drop could prob alleviate most of that...i'm more interested in ppl that developed the vibes from front lift only. and prob won't be able to get the wheels till the fall so i will have forced patience for the 7105's haha.
  8. Jul 27, 2011 at 3:23 PM
    TacomaGus
    Gus
    Morgantown, WV
    the 265s shouldn't be that hard to balance unless you have like d or e rated tires. Just go for the road force balancing at a shop that knows what their doing and that should help out tire problems. I'm gonna run down my stock 265/65/17 yokos and i will only go up to a 265/70 sometin, had 32x11.5 R15 on my first gen and that much tire is pretty hard to balance especially when its C rated but road force balancing alleviated most balance issues. I just had other issues develop cuz i think that combo was too hard on the little 4 cyl haha
  9. Jul 28, 2011 at 9:46 AM
    TacomaGus
    Gus
    Morgantown, WV
    bump, getting them put on tuesday so i need some more input please
  10. Jul 29, 2011 at 9:10 AM
    TacomaGus
    Gus
    Morgantown, WV
    Gotta be more people on here with the 5100s at these settings...
  11. Jul 29, 2011 at 12:03 PM
    harley70
    harley70 Active Member
    Dave
    Fort Worth
    11 PreRunner
    2011 Taco TRD, JBL, 20% Tinted Windows, HID 55W 5000K Headlights, HID 55W 5000K Fog Lights, 55w HID 5000K Hella 500s - behind the Grill, Mesh Grill, AFE High Flow Filter, Bed Cover, Tail Gate Lock,
    I had a 3" lift on my 2011 Prerunner and have had a vibration when I take off since. I am having it taken back off. I talked to some others that have done a lift and they all say the same thing. You will start getting a vibration and then it will start getting worse and then it will start squeaking.
  12. Jul 29, 2011 at 12:13 PM
    TacomaGus
    Gus
    Morgantown, WV
    Did you lift the rear as well?
  13. Jul 29, 2011 at 7:45 PM
    TacomaGus
    Gus
    Morgantown, WV
  14. Jul 30, 2011 at 7:28 AM
    harley70
    Dave
    Fort Worth
    11 PreRunner
  15. Jul 30, 2011 at 7:45 AM
    Fletcher007
    Fletcher007 Well-Known Member
    Fletch
    Phoenix,AZ
    17 Access cab 4x4 4cyl 5spd Magnetic Grey
    Fox 2.0 coilers, Fox 2.0 rear shocks, 17" 4Runner Trail Edition 7 spoke rims, 255/75 17 Yokohama All Terrains. Secondary air filter removed and AFE pro Dry S installed. Lower Air valance removed. Secondary smog pump mod done. Cali Raised ditch lights and amber fog lights installed with On off switches installed in 2 of 3 factory blank slots!
    i have the 5100's lifted to 1.75. And the tsb leafs in the rear. I don't feel any vibes, but then again i hav mud tires, so i can't hear a damn thing either!!
  16. Jul 30, 2011 at 2:51 PM
    TacomaGus
    Gus
    Morgantown, WV
    thanks for your input fletcher thats what i am looking for just responses from ppl with front lifts only. Most ppl responding on here have done a rear lift as well which IS NOT what i'm doing haha. w/o a cb spacer, shims, etc most if not all are gonna have vibes with the rear lifted as well since the driveshaft is all out of whack
  17. Aug 8, 2011 at 11:50 AM
    Koby
    Vancouver
    06 access trd
    I read a post some time ago where someone had done a complete 3" lift to his tacoma and of course ended up with vib issues. He tried everything and nothing worked until he took out his dakar leaf springs and brought the rear back down to stock, or near stock, height. After that he said his truck rode better than stock! So, I'm thinking if you are only going to lift the front, it should be no problem.
  18. Aug 11, 2011 at 7:50 AM
    Izzapac
    Izzapac Member
    St. Robert, MO
    2007 TRD Sport Silver Streak
    Bilstein 5100s front (1.75") & rear
    I had 5100's installed all four corners in July. No TSB or anything in the rear, and set the fronts at 1.75. Driving away from the shop I could feel that the ride was SIGNIFICANTLY IMPROVED. I no longer felt every bump in the road. However, I do feel a slight vibration, starting around 30mph and fading out around 65mph. It's not a terrible vibration, but noticeable in the floor, pedals and steering wheel. From what I've read in many threads here, it is a strong possibility that lifting the truck has uncovered (or aggravated) an existing problem with the front differential bearing. Apparently, (fingers and toes crossed) this is an issue more because it's irritating, and NOT so much because it is unsafe or could cause a catastrophic failure. Sometime next week, I think I may drop the front to .85 and see if that alleviates any of the problem, or at least lessens the vibes. Other than that, no real issues after the level. Hope this helped.
  19. Aug 11, 2011 at 7:57 AM
    Iakopa84
    Iakopa84 Well-Known Member
    Jake
    Escondido, CA
    05 PreRunner TRD Off-Road
    Aries Grille Guard, PIAA 520 xtreme ATP lights, K&N high-flow intake, 2.5" velocity front leveling kit
    I'm wanting to get the Toytec lift for my truck soon.... Is the vibration issue a problem only for 4x4's or is does it also occur on 2wd's as well?
  20. Aug 15, 2011 at 10:44 PM
    Koby
    Vancouver
    06 access trd
    I recently figured out that my vibration was caused by a bearing problem in my front diff. The tech told me that it wasn't going to hurt anything and certainly was not a safety issue, just annoying. There is a tsb out on certain years of tacomas and tundras. Just not my year(2006), so I'll be paying out of pocket. Oh, and a good way to tell if that is your problem is to put it in 4hi and see if your ride smoothes out through the rough speeds.
