Vibrations after setting 5100's at 1.75 or .85?
Discussion in 'Suspension' started by TacomaGus, Jul 26, 2011.
Vibes after Bilstein 5100 Install?
Poll closed Aug 25, 2011.
  1. No Vibes at 1.75 or .85"
    15 vote(s)
    68.2%
  2. Vibes @ 1.75 or .85"
    7 vote(s)
    31.8%
  1. Aug 16, 2011 at 5:53 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    If it doesn't vibrate, it's not a truck!
    If the ride isn't harsh, it's not a truck!
    If your girl doesn't have to jump to get in, it's definately not a truck!
  2. Aug 19, 2011 at 1:30 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    No vibes when I was at 1.75" and TSB, then went to 2.5" and AAL and had a bad take off shudder/vibe, had the dealer look at it and they installed a 1" CB Drop and they significantly reduced the vibe, but you can still feel it occassionally
  3. Aug 20, 2011 at 11:12 PM
    DWreck
    Derek
    Las Vegas, NV
    Try the 3° shim. Personally, I would rather deal with the vibe than install shim.
  4. Aug 21, 2011 at 9:58 AM
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    I think I'm going to the same thing but get TSB rears. Sounds like most people with their fronts at less than 2" havent had issues at least not significant ones. My question is should I get the Eibach spring or just use the OEM TRD OR spring? I'll spring for the Eibach's if it will ride better (DD - mostly on the street but occasional wheeling).
  5. Sep 23, 2011 at 3:49 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    wat happened when u went down to .85??
  6. Sep 24, 2011 at 8:02 PM
    Koby
    Koby Well-Known Member
    Vancouver
    06 access trd
    2in OME suspension lift ARB bull bar 8000lb WARN 32`duratracs on 17 procomp 7033`s
    Haven't been on for a while but just a quick update for anyone still subscribing to this thread. My take off shudder was completely taken care of with the install of a one piece drive shaft. I had it fabricated at a local shop using part of my existing shaft and the total cost was only $240. Not bad. The other vibration I had was caused by some bad bearings in the front diff and those are now gone since I had a new front diff installed. Not cheap but well worth it. Oh, the double cardan on the drive shaft was not necessary.
  7. Sep 26, 2011 at 8:46 PM
    HB Taco
    Curt
    OP did you install the lift? If so how's it going? I've started to notice I may have the dreaded front end vibration. Its very slight but if I shut off the radio and drive on a smooth road 20-30 mph I can detect a kind of groan groan noise/vibe. The duratracs make some noise so its hard to detect but today I put it 4hi and back a few times and it does seem to go away when in 4hi! Right now it's not bad at all but is starting to bug me especially since I now want to bump the 5100's up a notch to the .85 setting with the Eibach spring for a 2.5" lift. This is to match the rear which now has the Deaver 3aal under the TSB pack (removed overload springs). It rides awesome now and doesn't bottom out anymore. The rear is amazing now but I have rake again - hence the need to move the front up a little. I think I also have a touch of the take off shudder coming from the rear cause its now about 2.25-2.5 lift but I do carry about 200lbs back there so its lowered a little. Damn these 2nd gens. I had my 99 4x4Taco lifted and didn't have any of this shit. I read about this crap but hoped I wouldn't have to deal with it. I may try the diff drop - most say that helps a bit but reduces clearance :(. then do the CB drop also. Just trying to work within the apparent limitations while getting some lift and not spending a fortune!
  8. Sep 27, 2011 at 9:30 AM
    dayNnite4
    Nick
    Southern NH
    '11 4x4 5-speed AC
    pic of the .85!!
  9. Sep 27, 2011 at 9:32 AM
    kulcat
    kulcat Well-Known Member
    Thomas
    Plano, TX
    I'm about to put 5100s all they way around with stock rear, no TSB with fronts at .85 to start. As far as I know, mine is bone stock and from about 50-65, my steering wheel vibrates some...faster than that, just fine.
  10. May 26, 2012 at 11:59 PM
    Patmac
    Patmac Well-Known Member
    Pat
    Chesapeake, VA
    14 TRD Sport
    20% tint, weather techs, icon stage 3. n-fab, bhlm, retrofits, SCS SR8, 285s
    did my 5100s yesterday, no tsb and i set it at 1.75. i do feel a vibe threw the floor. doing my research to find out what it is
  11. Apr 11, 2015 at 5:12 PM
    Desert Dave
    Desert Dave Member
    Apple Valley, Ca.
    Bilstein 5100's at .85 over stock, Relentless fabrication aluminum skid plate.
    .85 on a stock Taco regular cab, factory leafs, 265/75/16's....zero vibration.
