Vinyl wrapped
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thegreatwall23, Jun 8, 2013.
  1. Jun 9, 2013 at 8:07 AM
    thegreatwall23
    thegreatwall23 [OP] Well-Known Member
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    Armor Shrockworks front bumber Shrockworks Rock Sliders Brute Force Rear Bumper XRC8 with synthetic rope Relentless Full Skid Pack Suspension Icons 2.5 extended travel all around with King 14" 700# Springs Icon Tubular UCA's All Pro Standard Leaf Pack 3 degree axle shims Wheelers front bumpstop U bolt flip kit Timbren rear bumpstop Mods rear diff breather fog light anytime ABS Disable TPMS disable Door Chime disable Seat Belt Chime Disable Cab Mount Chop Pinch Weld Mod BHLM Other 4.56 Nitro gears FX-R Retrofit HID's with Halos PIAA fogs and driving lights Wet Okole seat covers Weather-Tech floormats Access LiteRider bed cover AMP bed extender Viair 450P-A Rocky Clutch SD mounts Pop-n-lock tailgate lock Aux rear lights Rear sliding window security bar B.A.M.F Light Bar Ultragauge 48" Hi Lift Jack with Bed Rail Mount Bushwacker Fender Flares ECGS PTFE Bushing SS Brake Lines Brembo Blanks Hawk HPS In cab winch control (12voltguy) Tint
    From what I have read... If you are in a hot environment, like Texas or somewhere like that and it isn't in a garage, about 7 years. My truck is only driven as a second car and stays in the garage and I live in TN, so I think it will last me double that.
    It is supposed to stop rock chips, etc... Not sure about scratches, I am going to test a spare piece later today.
  2. Jun 9, 2013 at 8:25 AM
    thegreatwall23
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    I just placed a spare piece of vinyl on a piece of metal and did some scratch tests. I scratched deep enough to scratch the metal and went across the vinyl. It scratched just like the metal, but when I peeled back the vinyl if protected the metal completely. I then tried some keys and it scratched the vinyl, but not underneath. I then cleaned the vinyl and the scratches weren't as visible, but still there. So, it will definitely protect the paint. Probably depends on the finish you get on how visible scratches are on the vinyl.
  3. Jun 9, 2013 at 8:26 AM
    NvrSumR
    NvrSumR Well-Known Member
    Jeff
    Colorado
    That's longer than I expected. Very cool!
  4. Jun 9, 2013 at 10:32 PM
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    dam great job man! looks great! I've been wanting to do this myself as my truck is scratched up bad.
  5. Jun 9, 2013 at 11:24 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Looks great!! I've done 5 car roofs myself and my roof on my double cab twice. I want to wrap the whole truck a different color at the end of this year
  6. Jun 10, 2013 at 4:47 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    what color was it before? and if not grey, i assume u have to change that at the dmv as well right? did u do under the hood where all the cross brace stuff is or is it still original?
  7. Jun 10, 2013 at 5:17 AM
    thegreatwall23
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    The original color was Silver Streak Mica. I haven't done anything with the dmv. lol... I didn't even really ever think of that. Not sure what I need to do there. I will probably just roll with it and explain if something happens.
    No, you don't do the underside... You just cut a little past the edges and tuck and fold under and stick to the bottom side.
    I didn't do behind the cab further than my hand could reach. You could take the bed off and do that, but I didn't do it. Each panel was a piece of vinyl. So, I would measure one panel, say the fender, then cut a sheet that size and put it on. Some people do over lay the entire side of the truck then cut in the creases and tuck, but I wanted to get the gaps better, so there wouldn't be any of the old color showing threw. It is very tedious... I am not sure how many hours it took me, but it was several. You just have to take your time if you want it too look good. Then again, this was the first time I had ever messed with vinyl, so someone that knows what they are doing would be much better at it I'm sure.
  8. Jun 10, 2013 at 5:21 AM
    fbj913
    fbj913 Member
    KC MO
    08 TRD
    looks killer. do they offer other colors? i did a little searching already but cant find much.
  9. Jun 10, 2013 at 5:23 AM
    thegreatwall23
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    Yeah, tons of colors and finishes...
  10. Jun 10, 2013 at 6:02 AM
    black_magic2010
    black_magic2010 Well-Known Member
    South Texas
    10 Tacoma TRD Sport DBL Cab
    Did you remove the door handles, headlights, grill, or fenders flares to wrap the area around or behind these? Also did u wrapp the inside of the doors with the same piece used for the outside of the doors. I've seen a few videos where this is done so that none of the original color is showing.
  11. Jun 10, 2013 at 6:05 AM
    Robotoco
    Robotoco Well-Known Member
    Roberto
    NC
    looks real good form hear man i love that color
  12. Jun 10, 2013 at 6:06 AM
    fbj913
    fbj913 Member
    KC MO
    08 TRD
  13. Jun 10, 2013 at 6:10 AM
    thegreatwall23
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    I did remove the door handles, but not the headlights. I was able to cut around the edge and tuck them around the headlights. I have an aftermarket grill and bumpers, so I only had the truck panels to do. I only wrapped the inside of the doors where it would be visible to the outside of the truck. But all of those pieces were used to cover a panel and then tucks and formed to the inside of the doors. If you open a door, you will see the old color and the vinyl line where it stops. The line isn't really straight either, I thought about going back and straightening that out to make it look a little better with the door open.
  14. Jun 10, 2013 at 6:11 AM
    thegreatwall23
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
  15. Jun 10, 2013 at 8:53 PM
    #35
    black_magic2010
    South Texas
    bump..just cause I think this such a cool mod for the truck. Sure others have done it and hopefully they chime in. Photos of your wrapped truck greatly appreciated. I plan on doing this sometime before the summer is over.
  16. Jun 11, 2013 at 12:24 PM
    #36
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    09 dcsb Super white 4x4 sr5.
    Bilstein 5100 at 2.5 inch OME dakars with the big overload removed 265/75/16 on stock wheels 290,000 miles and counting
    I use my truck in the oil field and I think this would be an awesome mod to save the paint on our trucks. Thanks for the info. I'm going to give it a shot on mine.
  17. Jun 11, 2013 at 12:27 PM
    #37
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    2012 Tacoma TRD T|X Baja
    Pelfreybilt IFS Skid, Mid Skid and Plate Bumper, Rigid Industries Dually's, ARB CKMA12 On Board Air, Kenwood TM-281A Radio, Rear view mirror relocation bracket, Wheelers SuperBumps, Toytec Baja Spacer
    AWESOME!!! I was also thinking about a vinyl wrap, I got a quote from a local comapny with a great reputation and they wanted $2700. Needless to say I didnt go through with it. But for what you paid and some time and a buddy I would LOVE to tackle this. Your truck looks great. How do you wash it, or do you just spray it off?
    Alex
  18. Jun 11, 2013 at 2:47 PM
    #38
    thegreatwall23
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    Yeah, same thing for me. My quote was 3k, you can do it for about 600 yourself. You wash it like a normal car. If you end up with matte or carbon fiber finish, you can't wax it! It will leave a white residue. They said any detail spray is fine on it.
  19. Jun 12, 2013 at 11:00 AM
    #39
    thegreatwall23
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    I have had several people interested and asking a lot of questions, so I thought I would post this up... The place that I got my vinyl is running a 10% off sale right now on Ebay. So, it would save you 50-60 depending on how much you buy or if you have a single vs double cab. Here is the link to his store.
    http://stores.ebay.com/AutoVinylSolutions
    #39
  20. Jun 13, 2013 at 6:14 AM
    #40
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Nice job! I see quite a few mods similar to mine on this truck too :cool:
