Viper 5901 command center
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blaise22, Apr 29, 2012.
  1. Apr 29, 2012 at 9:36 AM
    Blaise22
    Blaise22 [OP] Well-Known Member
    Blaise
    California
    09 prerunner trd offroad
    Camburg 4.0 race spindles, coilovers, 285/75/16 Yokohama Geolanders mounted on 16" KMC Hoss wheels, Aero Turbine 2525
    Im trying to adjust the crank time on my viper 5901 but I lost the sheet that shows you all the different settings and how to get to them when using the command button. Can someone help me out and tell me how to get to the crank time adjustment and what increments it increases by?
  2. Apr 29, 2012 at 9:44 AM
    rexel
    rexel Well-Known Member
    Unless you have a DEI bitwriter you have to take it into a DEI dealer to have them change the crank time...it cannot be done from the remote.
  3. Apr 29, 2012 at 9:49 AM
    Blaise22
    Blaise
    California
    Ive done it before, I have a button on my antenna that I can adjust all of those settings myself. I just lost the paper that shows me how many flashes go with what setting.
  4. Apr 29, 2012 at 10:01 AM
    akhermit
    akhermit Well-Known Member
    Anchorage Alaska
    12 DCSB Magnetic Gray Metallic TRD Offroad
    PM me your email, and I will send you a copy of the install manual. Or you can go to 12volt.com and find it there.
    Edit: It is on page 16, and yes you can change it without the bitwriter.
  5. Apr 29, 2012 at 10:02 AM
    NEAScott
    NEAScott Well-Known Member
    Scott
    Toledo, Oh
    2014 Chevrolet Impala Limited
    A thought here, and I am by no means a professional in the starter/alarm world or on the starting mechanics of a Tacoma ... would adjusting the crank time even effect the truck??
    The reason I ask is that I have a DEI starter on my Pontiac and it refuses to start cold. I was told by my installer (DEI certified genius guru) that although crank time can be adjusted on the unit, it would not effect the car. My Pontiac cranks for a set time regardless if I hold the key or barely tap it, thus the same crank time when pushing the remote button.
  6. Apr 29, 2012 at 10:12 AM
    Blaise22
    Blaise
    California
    When using the remote start it definetly cranks longer than when im starting it with the key, im not sure it will work but figured its worth a shot.
