virbration from take off at about 5 mph
Discussion in 'Suspension' started by uspset, Sep 17, 2010.
  1. Sep 17, 2010 at 10:43 AM
    uspset
    uspset [OP] Member
    alvin
    kentucky
    05 dcab 4x4 trd
    3 inch left and leveled
    I have a 2005 TRD 4x4 d cab. I have about a 3 inch lift. Moto Metal rims 17 inch. I have tried shims in the rear, carrier bearing shims and front diff. drop, Any info on this problem would be of great help, and I have read a lot of threads on vibtations on the Tacoma.
  2. Sep 17, 2010 at 10:45 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Could be your tires need to be balanced or aligned...
    Or a U-joint is bad
  3. Sep 17, 2010 at 2:08 PM
    tacos
    tacos Well-Known Member
    Andrew
    NKY
    05 A/C Off Road 4x4
    BHLM,5100's set 2.5,Toytec 2" aal,FJ TRD wheels,AFE pro-dry, Duratracs
  4. Sep 17, 2010 at 9:02 PM
    uspset
    uspset [OP] Member
    alvin
    kentucky
    05 dcab 4x4 trd
    I have had the tires road forced balanced.
  5. Sep 17, 2010 at 9:03 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    carrier bearing shims or drop? if not check out beefed tacos carrier bearing drops
  6. Sep 17, 2010 at 9:07 PM
    uspset
    uspset [OP] Member
    alvin
    kentucky
    05 dcab 4x4 trd
    what is a beefed up tacos carrier bearing drops?
  7. Sep 17, 2010 at 9:11 PM
    malander
    max
    01 limited trd 4x4
  8. Sep 17, 2010 at 9:31 PM
    uspset
    uspset [OP] Member
    alvin
    kentucky
    05 dcab 4x4 trd
    Will give him a call, has anyone heard if this works ?
  9. Sep 17, 2010 at 9:34 PM
    uspset
    uspset [OP] Member
    alvin
    kentucky
    05 dcab 4x4 trd
    By the way if I put the truck i 4 wheel drive the vibration is gone
  10. Sep 17, 2010 at 9:40 PM
    malander
    max
    01 limited trd 4x4
    beefed taco makes some pretty good products...they are beefy and as far as i know he is the only vendor that makes a carrier bearing drop thats solid and doesnt use washers but that is also a quick fix. im pretty sure hes fixed quite a few tundras and a couple 1st gens with it. hopefully he'll fab up some for the 2nd genners
  11. Oct 4, 2010 at 11:06 AM
    uspset
    uspset [OP] Member
    alvin
    kentucky
    05 dcab 4x4 trd
    Ok I installed the carrier bearing drop made by streettaco and it worked, I now have no more take off vibs. Install was easy only took 15 minutes. If you have this kind of problem give it a try.
  12. Oct 4, 2010 at 11:09 AM
    tacosupreme54
    tacosupreme54 Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    that's good to hear. i was waiting on getting mine from him until i knew for sure it worked on a 2nd gen
  13. Oct 5, 2010 at 9:35 PM
    uspset
    uspset [OP] Member
    alvin
    kentucky
    05 dcab 4x4 trd
    Just a bump, this does and is working for me 250 miles all smooth.
