Vled V3 Triton
Discussion in 'Lighting' started by rossk35, Nov 27, 2013.
  1. Nov 27, 2013 at 11:44 PM
    rossk35
    rossk35 [OP] Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Been wanting to find a good led bulb that was really bright for some time now. A friend of mine got these for his truck and told me about them. My lens was starting to melt from the DRL's, so I disable them a while back. Got them in the mail today and installed them. Very impressed. They are so bright! I didn't take any pictures since is hard to capture the light output.
    http://www.vleds.com/v3-triton.html
  2. Nov 28, 2013 at 6:01 AM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    can you shoot a photo that shine on an object or the road?
  3. Nov 28, 2013 at 3:20 PM
    rossk35
    hawaii
    Got some pics today.
  4. Nov 28, 2013 at 3:40 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I had the same problem with mine after I installed the OEM DTRL kit and I also got rid of it cause of some melting. That kit you got looks really good and you can tell they are really bright!! Looks like they cost a bit of money but good LED's will cost you a pretty penny but its worth it. :)
  5. Nov 28, 2013 at 7:04 PM
    zoopla
    zoopla Well-Known Member
    Calgary,Canada
    2011 tacoma trd dbl cab
    K&N cold air intake FXR retrofit/Vleds Avid front bar/side steps 3" Eibach lift
    Humm, i wonder if i should do the same when i do my retrofit. but i was thinking to do the swithching color one's. white as drl's and amber as turn signal.
  6. Dec 3, 2013 at 4:57 PM
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    I installed the V3's DTRL 5K Switchback lights..they are almost bright enough to run as headlights alone..I also installed the 5K parking lights to run at the same time..looks killer...DTRL's will reduce 50% output if spliced into the Headlight harness when your headlights are on..Only bad side is that the LED's make the OEM headlights look yellow and weak....I'm currently on the build list for a pair of these..
    http://www.tacomaworld.com/forum/2n...fs-fx-r-mini-retrofits-bhlm-no-down-time.html
