volant cold air intake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by myth01, Oct 31, 2010.
  1. Oct 31, 2010 at 9:34 PM
    myth01
    myth01 [OP] Well-Known Member
    south sf, ca.
    08 taco Trd sport
    eclipse nav.-w/ Bluetooth & iPod 3'' revtech add a leaf lift kit snug top ss truck cap dive tank racks in back Aux fuse box Aux back up lights, w/ interior fj cruiser stock switch Back up cam Turn signal cams Interior inverter -switched Aux audio/video inputs -RCA (including iPhone cable)w/ 4 input switch Mag light mount Tyredog stand alone tpms Spare tire extension hose Avid off road light bar(powder coated)
    ok so i installed the volant cai today. easy enough but the lack of directions was disturbing. the scoop was not a one size fits all application. i had to modify the opening where the radiator reservoir spill over was, as well as the scoop itself. the scoop was hitting the sheet metal above the radiator so i had to slot it. as far as performance. now there are those that say no real difference except a noise maker. i come from a performance background, i always had high hp cars and i was always messing and tweaking them. i did notice a difference on the bottom to mid range in throttle response which is what i was looking for. could this of been achieved by removing the secondary carbon filter? perhaps, but i got the setup on craigs list for 150.00 to me it seems worth it
    1cleanFG likes this.
  2. Oct 31, 2010 at 9:39 PM
    myth01
    south sf, ca.
    08 taco Trd sport
    so far no check engine light, the only reason i could see for the cel. would be not seating the maf good enough, or the small vacuum line pops off
  3. Oct 31, 2010 at 9:46 PM
    myth01
    south sf, ca.
    08 taco Trd sport
    funny thing was the guy i bought it from i used to work with him. didn't know it was him till i asked him if he ever got a check engine light, lol
  4. Nov 1, 2010 at 5:21 AM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    I've had mine on for two years with no trouble yet!
  5. Nov 1, 2010 at 7:12 PM
    myth01
    south sf, ca.
    08 taco Trd sport
    ok so if it would throw a code, how long after install does it typically pop up?
  6. Nov 2, 2010 at 6:30 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    BTW, I plumbed the Volant Air Ram scoop into my stock filter. My scoop also had some rub issues around the coolant overflow area. It would seem "normal".
  7. Dec 18, 2010 at 9:02 PM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    sorry to bump an old thread, but pics avail of this? did you hack up the resonator hose?
  8. Dec 18, 2010 at 9:08 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    I've had the Volant CAI since i bought my truck, i tend to get a check engine light form time to time. much better throttle response. not too sure what to do about the light though, not a big issue, just an annoyance.
  9. Apr 6, 2011 at 7:28 AM
    k2jacob789
    k2jacob789 Member
    hey guys i installed a volant system on my 2008 tacoma, and my check engine light came on, the next day. any advice on what i should do. is there any problems that can happen in the long run
  10. Apr 6, 2011 at 8:47 AM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    get rid of it and buy a better one, they are notorious for that.
    haven't seen any long term effects yet on mine.
  11. Apr 6, 2011 at 9:06 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    i've had mine since 2006 and have not seen a check engine light come on for that...:knockonwood:
    maybe you have your sensor in wrong? or loose wire?
  12. Apr 6, 2011 at 9:16 AM
    babbott
    babbott Foxtrot Uniform Charlie Kilo
    Tooele, Utah
    08 off road speedway blue
    I didn't get a CEL until I put a Unichip in, then I would get a CEL quite often when lightly pressing the throttle. I ended up rotating the intake tract and got the MAF sensor as vertical as possible. I have not had a problem since.
  13. Apr 6, 2011 at 10:55 AM
    KalamaKid
    Oregon
    Could of installed your MAF backwards
  14. Apr 6, 2011 at 11:14 AM
    K1992f
    K1992f Well-Known Member
    Kanon
    Dirty Hanover pa ...
    2012 tacoma TRD sport fully loaded
    6" fabteck 20" fuel hostage 33" nitto MTs
    I would like to see pics of it OP if u could ?? I was looking same intake
  15. Apr 6, 2011 at 11:17 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    pic of my volant scoop
  16. Apr 6, 2011 at 11:23 AM
    K1992f
    Kanon
    Do you like it intake with scoop ??? NYCO
  17. Apr 6, 2011 at 11:32 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    i do...my thoughts on the scoop was why do i have this CAI when it pulls the air from the same spot as the original intake, so i grabbed the scoop to get more of an effect that the URD true cold air systems have where it pulls the air from the front, not side...i'm waiting to pay my taxes next week and see if i can pony up for the URD MAF calibrator to fully utilize the intake with my exhaust, but i like it....more air makes me think my engine is happier...whether or not it actually does anything? i have no idea, i've been hearing alot of bad things about CAI in general recently and whether they actually give our tacomas any added benefits, but i feel that my throttle response is better...i have never had my truck dyno'd and have too many other mods to know whether or not the intake actually adds anything, but i'd like to think that it helps at least at the higher rpms...
  18. Apr 6, 2011 at 11:32 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    are the gains worth the $$ for the CAI and scoop...probably not, but until i see proof otherwise, i think it's worth it...
  19. Apr 6, 2011 at 11:44 AM
    K1992f
    Kanon
    Ok I'm a dumb ass on this so tell me what is URD MAF ???
  20. Apr 6, 2011 at 12:31 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
