VSC Calibration Didn't Help, Still Get Problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomtn, Nov 22, 2011.
  1. Nov 22, 2011 at 1:35 AM
    tacomtn
    tacomtn [OP] Well-Known Member
    TRD OR,OME,Deaver AAL
    with it activating when not necessary and actually making it unsafe. The VSC kicks in when on mild turns, sometimes making it hard to keep the truck straight while the ABS goes to one wheel.
    I had the Toy dealer calibrate the VSC per instructions from this website, and still it happens. Damn right dangerous sometimes!!!!
    10crewcabgreytacoma likes this.
  2. Nov 22, 2011 at 8:33 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    This
    and if that does not help , look into Crom's ABS/VSC bypass threads
    Have you had an alignment since lifting ?
  3. Nov 22, 2011 at 8:40 AM
    T-Rex266
    T-Rex266 Moderator Moderator
    Elon
    I'd look at the alignment
  4. Nov 22, 2011 at 9:16 AM
    d12cons34
    d12cons34 Member
    dodge ram
    suspensions kits
  5. Nov 22, 2011 at 9:17 AM
    OZ-T
    Peter North
    British Columbia
    Yes , especially sensitive after lifting .
  6. Nov 22, 2011 at 9:17 AM
    T-Rex266
    Elon
    ^^ mine kicked in yesterday for the first time on a turn. I couldn't figure out why?
  7. Nov 22, 2011 at 10:13 AM
    OZ-T
    Peter North
    British Columbia
    As a stop gap measure , you can alway hold in the VSC ( car with squiggly lines ) button for 5 seconds while stopped , this will significantly reduce the sensitivity of the VSC system .
    It will reset each time the truck is turned off though .
  8. Nov 22, 2011 at 1:14 PM
    tacomtn
    Yep. Alignment, VSC calibration, wheel balanced...all done. It's downright scary trying to keep the truck from going off the road when it kicks in on one wheel. I fail to see how this is supposed to help in a real emergency.
    I'll look for that bypass thread...something. This is ridiculous, I mean I'm going like 25mph on a 35mph curve !!!!!
  9. Nov 22, 2011 at 1:18 PM
    OZ-T
    Peter North
    British Columbia
    I hear you , I have had the same experience .
    The skid control ecu thinks you are going into a tailspin condition and brakes the driver's side rear tire , actually forcing you into oncoming traffic . Not cool .
    Fredfifty likes this.
  10. Nov 22, 2011 at 3:19 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    Strange that your having this kind of problem with it. With my last lift it barely went off, now with this lift it goes off a little more but almost never actually kicks in unless I break the back end loose. Maybe its because of the supercharger ECU reflash I have. I have fox coils cranked way up with sway bar removed. What lift do you have, how much body roll do you get? Could be a combination of lift with excessive roll casuing this.
  11. Jul 19, 2015 at 12:10 AM
    10crewcabgreytacoma
    10crewcabgreytacoma 18crewcabTRDoffroad
    Va
    2018 tacoma crew cab 4x4 trd offroad
    33 m/t tires stock everything
    Did anyone know the fix to this mine is doing the same thing. I was pulling my boat last night and it about caused me to hit someone head on. When I hold the off button for 5 seconds then go in a curve and hit the break one front tire will lock up.
