VSC light will not switch off, and.......
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Appalachian13, Sep 16, 2016.
  1. Sep 16, 2016 at 11:22 AM
    Appalachian13
    Appalachian13 [OP] Active Member
    Curtis
    SW PA, USA
    13 BLACK DCSB TRD SPORT
    Lifted the truck about a week ago, light did not come on. Truck put inline, no light. Yesterday the light comes on. Hit the switch and doesn't go off. Now what's screwy is my inflation light isn't on. I have steel wheels on with no valve stem indicators. Now the stock wheels with the stem indicators are in my garage ten feet from where I park my truck. Now I am not the brightest bulb in the pack, BUT are those stock wheels interfering with a signal and throwing everything outta whack?
    And how do I get that light to switch off?
    Thanks in advance!
  2. Sep 16, 2016 at 11:26 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
  3. Sep 16, 2016 at 11:28 AM
    Appalachian13
    Curtis
    SW PA, USA
    Thanks Sub, I will check into it. Hopefully that solves the issue.
  4. Sep 16, 2016 at 11:36 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    You can also disconnect the battery for say 20 min.
    I had the Vsc light on also and mine reset itself.
    Icon coil overs up front and all pro expo in the rear.
    Good luck!
    Az
    Appalachian13[OP] likes this.
  5. Sep 16, 2016 at 11:59 AM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Didn't work for me so I had to recalibrate. I posted in that thread on how to do it with two paperclips. The procedure is very easy just make sure you follow the steps exactly and it should work. If not then I would start looking at the ABS wires and make sure there not damaged or a ABS sensor didn't come unplugged.
