VSC to the rescue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cvillechopper, Jan 19, 2009.
  1. Jan 19, 2009 at 11:24 AM
    cvillechopper
    cvillechopper [OP] Jackass to the masses
    Charlottesville, VA
    12 DCSB TRD Off-Rd 4x4, Roof Rack, Tube Steps
    K&N drop-in air-filter, extra D-rings, Custom Console lock-box, Leather heated seats, Studly Driver
    My wife and I just got back from an unexpected trip to the middle of Michigan. It was between -14 and -16 every night we were there and never over 10 degrees during the day. Not a good time for a funeral but when is, right? On our way there, about 6 hours into my leg of the trip, we come up on the weather we had been hoping would hold off until we got where we were going. Everything is going fine for about 1/2 hour (mostly wet roads but starting to freeze) and I started to day-dream just a bit. I know... I know... bad move, i screwed up, etc. Usually I know better and pull off for coffee but I wanted to get through the crap and just get to our destination. Anyway, we drifted slightly onto the slush on the right side at about 60mph (getting passed the entire time) and the back-end broke loose. We got to just under 45degrees off with me just trying to keep the front wheels pointed where we needed to go and started to hear the mythical beeps and clicks many have mentioned on here. The truck snapped back straight in the lane and we immediately slowed WAY down and kicked in the 4wd.
    The rest of the trip was slow and we were still getting blown around a bit even with the 200lbs of sand in the back. Of course we were not the ones in the ditch. Must have seen 20 or 30 Ohio and Michigan drivers in the drifts, mostly domestic trucks, and I was very happy not to be a cliche "VA driver in the snow bank".
    Just thought I'd share. VSC absolutely helped me out of a jam. Now I hope I never have to hear those beeps again...
  2. Jan 19, 2009 at 12:37 PM
    z33tec
    z33tec Well-Known Member
    Rochester, NY
    09 4X4 Access Cab 4cyl
    That's the first time you've experienced the VSC? I hear it every time I drift into my driveway or snow packed side street :)
    Edit: Nevermind, didn't take into consideration you live in VA. ;)
  3. Jan 19, 2009 at 12:47 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    Is it a Option or does the VSC come stock on most Tacos?? I have never slid my 06... My 05 must not have had it because i have slid it around a bit on an icy parking lot.
  4. Jan 19, 2009 at 12:49 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    It's a new feature of the '09. Not sure what it's availability is on specific models, but the '09 introduced it.
  5. Jan 19, 2009 at 12:51 PM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Looks like it served its purpose well for cville, but man, that has got to drive you crazy if your always on snowy roads. Is it that sensitive or only when you 'push it' on purpose?
  6. Jan 19, 2009 at 12:54 PM
    Johnson8537
    Oregon
    Hmm... must be late 08's too? OP has an 08?
    I dont know if i would like it... (something about the computer taking over thinking it knows what best..)
    That would be like us closing our eyes and knowing which way to try to correct it... and stay on the road...
    But hey if it helps people out thats great!! :D
  7. Jan 19, 2009 at 12:55 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    I'm guessing he's pushing it... Mine's not sensitive at all, but it did recently kick on when I turned into an icy parking lot and hit the gas, causing the back end to break loose. It's pretty cool when it works. Glad it did it's job for you Cville.
  8. Jan 19, 2009 at 12:57 PM
    Okkine
    Okkine Well-Known Member
    Vancouver, BC
    2009 Magnetic Grey Access Cab - 2.7L I4 - 4x2
    Glad to hear it did it's job.
    Yep, the VSC is WAY too sensitive at low speeds.
  9. Jan 19, 2009 at 12:57 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    It is standard I believe on the '09's and may have been an option prior to that. Nevermind, I am getting slower...
  10. Jan 19, 2009 at 12:57 PM
    cvillechopper
    Charlottesville, VA
    Almost. VSC was available as an option on some earlier models (my '08 for instance) but I think they made it standard in '09. One of the reasons I have the DC short bed is that you couldn't get the off-road package in a long-bed and have the VSC. I wanted the safety net (glad that I spent the extra $$ now) so I got the DCSB.
  11. Jan 19, 2009 at 1:00 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    What you said... :D
    Glad to hear that it helped ya out... good deal... :thumbsup:
  12. Jan 19, 2009 at 1:00 PM
    LonghornTaco
    Minnesota
    Thanks for that clarification. I remember reading in the Toyota "what's new guide" something about VSC... Guess it was "going from optional to standard".
    I like VSC (you can turn it off too if you want). It has helped me since I'm new to driving in these types of winter conditions. However, my experience is that it's kinda slow to engage. Fast enough to be helpful, but still a little slow.
  13. Jan 19, 2009 at 1:19 PM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    My wifes Explorer has a similar feature (Traction System Control)which sure is nice especially on the highway and you hit the slush in between the lanes.
    BTW where in Michigan did you go?
  14. Jan 19, 2009 at 3:10 PM
    cvillechopper
    Charlottesville, VA
    Edmore. It's north west of Lansing. Hit the weather between Sandusky and Toledo.
  15. Jan 19, 2009 at 3:48 PM
    TRDnAZ
    TRDnAZ Well-Known Member
    Chandler, Arizona
    Desert Sand Mica
    I have it on my 07 TRD Off-Road 4X4 but I believe it was only available in a certain "option package".
