VSS wire location 2001 Xcab
Discussion in 'Audio & Video' started by avdog, Sep 12, 2007.
  1. Sep 12, 2007 at 10:58 AM
    avdog [OP] New Member
    Sep 12, 2007
    Hell all,
    I have just installed an AVIC D3 unit in my 2001 Tacoma and I like many am having a hard time finding the VSS & Back up light wire. Anyone out there able to help?
  2. Sep 19, 2007 at 6:40 PM
    krlang NewEnglander
    Sep 3, 2007
    Commonwealth of Massachusetts
    03 2WD 2.4L Tacoma Reg Cab
    Chrome Bumpers F&R, Grille & Corner Lights, Wheel Skins, Red/Clear LED taillights, Remote start, PDL, Cruise, K&N, All Kenwood, DNX-5120 6.1" NAV/TRAFFIC/DTV/DVD/XM/BLUETOOTH/USB/IPOD/SUB/rear cam, Tint, Air Band radio, Class 3 Hitch with 4/7 pin harness, Transmission Cooler, Red Top Battery, "Deck Plate" mod.
    I found it in my 03 2wd reg cab last week.
    Pull down the glove box, you can leave it attached. slide out the A/C duct, and remove the three bolts that hold the filler panel that sits above the glove box. Looking straight ahead, the ECM is right there with 4 connectors attached. The OB one, the one closest to the door has two green wires in one row. Each will have a stripe on them, I thought the green/red was the green/orange that I was looking for, but it would not make the cruise work.
    I tried the wire next to it, it looks like green/yellow, that was the VSS wire, I hooked it up and the cruise control worked like it was supposed to.
    Good luck,
