vvti
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danstacoma, Dec 21, 2010.
  1. Dec 21, 2010 at 12:00 PM
    danstacoma
    danstacoma [OP] Well-Known Member
    Dan
    pa
    07 Tacoma
    3 inch lift, painted badges, k&n cold air, cherry bomb, tinted windows, yellow fogs, and more to come
    what does vvti mean and is every motor a vvti any help thanks just curious
  2. Dec 21, 2010 at 12:04 PM
    danstacoma
    Dan
    pa
    07 Tacoma
    gotcha thanks alot man
  3. Dec 21, 2010 at 4:12 PM
    dalsmthme
    dalsmthme Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
    Not the SAME as VTEC. VVTi controls valve timing. VTEC controls timing and valve lift.
  4. Dec 21, 2010 at 4:22 PM
    dalsmthme
    Ithaca, NY
    Actually it's not even close and you should take the time to educate properly rather then giving miss information...just saying...
  5. Dec 21, 2010 at 4:25 PM
    jandrews
    '09 FourDubDee TRD OR
    Quoted just because.
  6. Dec 21, 2010 at 4:29 PM
    dalsmthme
    Ithaca, NY
    I did correct the info...you took offense to it...chill dude....
  7. Dec 21, 2010 at 4:33 PM
    jeetS
    jeetS Active Member
    Toyota also uses a system called VVTLI Variable Valve Timing with Lift & Intelligence.
  8. Dec 21, 2010 at 4:34 PM
    jandrews
  9. Dec 21, 2010 at 4:36 PM
    dalsmthme
    Ithaca, NY
  10. Dec 21, 2010 at 4:56 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    VVTI is not like vtec
    VVTLI is like vtec
    not sure if they make those engines anymore though? they were in the celica GT-S
  11. Dec 22, 2010 at 3:03 AM
    dalsmthme
    Ithaca, NY
    They were using it in some of there mid-output 4 bangers but they have gone away from.
  12. Dec 22, 2010 at 5:18 PM
    jeetS
    jeetS Active Member
    also in my wifes corolla xrs...not sure if they use it anymore....
