W59 to R155
Discussion in '1st Gen. Tacomas (1995-2004)' started by Russianman92, Jan 3, 2018.
  1. Jan 3, 2018 at 9:52 AM
    Russianman92
    Russianman92 [OP] Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    Hey guys, new here. I searched for a write up or some info on swapping a W59 4x4 to an R155 4x4 trans in my 1st gen. I guess my questions are:
    1) worth it?
    2) easy to keep the 4x4?
    3) need new mounting?
    4) input shaft the same?
    5) keep transfer case or have to use another, if have to change then diff driveshaft pattern?
    If these questions has been answered many times, please link the info or write-up for me.
    Thank you!
  2. Jan 3, 2018 at 9:56 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    R155 or R150F? It is possible to swap to the R150F and keep your transfer case but why? If you have a 4cyl like it says there's no real reason to, you'll spend lots to get the same outcome as putting in another W59. If you were boosted a lot or swapping to a another more powerful engine then maybe.
  3. Jan 3, 2018 at 11:34 AM
    Russianman92
    Dunwoody GA
    Well from my understanding the R155 has the same bolt pattern for the housing so I assume I need to use the R155 housing with the R150F and change the input shaft? I am building a turbo motor at the moment but I wont have it finished for a year or so due to funding, however, my W59 right now is in need of a rebuild and I am thinking why not just go ahead and beef up the trans now since I have to take it out anyway. Besides i understand the gear ratios are a lot better. With 31s I struggle in 5th on the highway if going up a slight incline.
    The R155 Xfer case drops on the wrong side?
  4. Jan 3, 2018 at 11:40 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
  5. Jan 3, 2018 at 11:42 AM
    Speedytech7
    Well, perhaps talking to @MadTaco461 would do you more good than me, he's got a turbo 2RZ (same bolt pattern) and a R155, they drop on the correct side, both 2nd gens and 1st gens drop on the drivers side.
  6. Jan 3, 2018 at 11:50 AM
    Russianman92
    Dunwoody GA
    @boostedka
    Great info! Thanks I will read through this and If I have any questions all keep this thread going.
    @Speedytech7
    Thanks! I will see what he says. You're saying R155 drops on the driver side?
    Texasdynaryder likes this.
  7. Jan 3, 2018 at 11:54 AM
    Speedytech7
    The R155 was used in 2nd gen Tacos with 4cyls so yeah it'll at least be compatible with that transfer case which drops on the driver's idea for the front driveshaft
  8. Jan 3, 2018 at 11:56 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    R155 bell is a direct swap no issues. Use the R-series throw out bearing and arm. The rest of the 4x4 transmission I have no idea about. I did a 2wd swap.
    Use the same starter, clutch slave, same bolts, everything plugs in. Just need to alter the trans mount.
    Use the r155 shifter.
  9. Jan 3, 2018 at 12:04 PM
    Russianman92
    Dunwoody GA
    I noticed that on the R150F swap in the build thread above, the guy used a post 1996 R150F then had to use a laithe to shorten the input shaft, then like you guys said use the R series arm and bearing and he had to find a driver side drop R series transfer case and modify the mount. I wonder why he didnt use an R155. I'll do more research
  10. Jan 3, 2018 at 12:08 PM
    Russianman92
    Dunwoody GA
    @MadTaco461 @Speedytech7
    Looks like the R155F Drops Driver side like you mentioned Speedy. See attached. Page 3
  11. Jan 3, 2018 at 12:08 PM
    MadTaco461
    CA
    Kinda stock
    I think no one was really that bold to grab an R155. No one would give me info. Only thing I knew was the bell housing is good to go. The r155 input shaft is perfect. I pretty much had to go to a junk yard an buy one and do the measurements myself.
  12. Jan 3, 2018 at 12:10 PM
    Russianman92
    Dunwoody GA
    Hmm the only thing I can think of the 4x4 being an issue is that the transfer case looks like it's not mechanically actuated. All electronic solenoids. Look at page 3 you see a cover plate where a J shifter would go.
  13. Jan 3, 2018 at 12:18 PM
    Speedytech7
    Yeah, we need more research but I'm almost sure a R150F jshift case would bolt up to the R155 and work fine.
  14. Jan 3, 2018 at 12:19 PM
    MadTaco461
    CA
    Kinda stock
    You'd have to look at the wiring diagram and make a switch selector. It can't be that difficult. I know enough EEs that I could with some help make a standalone shift box if I have the transfer case. I could be off a little bit because 4x4 wasn't on my radar. Sounds easier than making a frankentranny.
  15. Jan 3, 2018 at 12:21 PM
    Speedytech7
    It wouldn't be too bad the wiring is almost the same as a locker, just have to know where the stopping points for 4WD and 4Low are.
    MadTaco461[QUOTED] likes this.
  16. Jan 3, 2018 at 12:26 PM
    MadTaco461
    CA
    Kinda stock
    Doesn't sound too bad.
    A lot of junk yards sell the trans and transfer separate. Could see if the R150 transfer hooks up.
    I'll link this again. I dug through all of these for my swap.
    https://www.tacomaworld.com/threads...on-your-5-speed-transmission-write-up.338836/
  17. Jan 3, 2018 at 12:27 PM
    Russianman92
    Dunwoody GA
    I agree. I am pretty good at wiring and schematics (avionics tech), however, I am a big fan of everything being manually actuated. Like Xfer case, hubs, even prefer the hand crank windows. lol Less electronics the better IMO. Honestly thats 1 less thing I have to worry about. I think the R155F output has a different spline count than the R150F so I don't think the Xfer case will work. Then again please correct me if I'm wrong.
    Dalandser and MadTaco461 like this.
  18. Jan 3, 2018 at 12:43 PM
    MadTaco461
    CA
    Kinda stock
  19. Jan 3, 2018 at 1:07 PM
    Russianman92
    Dunwoody GA
    @MadTaco461 Thanks! I will keep this post alive. Time to do some more research! With a cup of Joe.
    And thank you @Speedytech7 for your input as well!
    MadTaco461 likes this.
  20. Jan 3, 2018 at 1:50 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    same lol
    And soldering isn't an issue for me
