w59 tranny looking for help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by paulsar80, Aug 28, 2008.
  1. Aug 28, 2008 at 3:47 PM
    paulsar80
    paulsar80 [OP] Member
    Anchorage
    96 Taco 2wd
    Hi guys,
    I'm new here so I hope asking "how tos" is cool here.
    I JUST bought a 96 tacoma 2WD, and the clutch went out on me. Started to pull the transmission to replace the clutch and couldn't get the darned thing (tranny) off. Then I read online that you have to remove it with the engine just to replace the clutch! I hope this isn't true. Any one have any advice, help, input? Much appreciated! -Paul
  2. Sep 2, 2008 at 3:36 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Well I have never seen any one remove the motor just for a CLutch Job.
    But there are many bolts around the Transmission houseing Plus the Shifter.
    The top 2 bolts are the hardess to see. I use a 3 foot extrension and a swivle to ge them off.
    You also have the Drive shaft off as well i hope.
  3. Sep 2, 2008 at 5:17 PM
    paulsar80
    Anchorage
    96 Taco 2wd
    Yeah, thanks. Man those bolts are hard to see. I WAS able to get the tranny off without pulling the engine, but believe me it wasn't easy. Chilton's insisted it need to happen (i suppose it's because the cross member is welded rather than bolted onto the 2-wheel drive)
    Thanks for the tips on the tranny bolts!
