"Wandering front end" feeling + Other Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LabradorBoy, Feb 28, 2013.
  1. Feb 28, 2013 at 2:47 PM
    LabradorBoy
    LabradorBoy [OP] Well-Known Member
    Canada
    09 DCab TRD Sport
    I have a 2009 4wd DC SB that is nearing 100k km's and works well, but I have a few brief questions that I would appreciate some direction with, I've come up with a few dead end searches:
    (1) My steering feels like it wanders, i.e. my steering seems to have some play between the steering wheel and the wheels themselves. I have briefly inspected the outer tie rods (it's still Winter here so lots of snow and slush on everything) and I cannot see any obvious play there. Are there any common problems with the 2nd gen regarding a lack of steering "feel"?
    (2) My engine is really ticky! Between the throwout brg squeaks (URD kit is on my to do list), the cab fan chirps and the ticky engine this thing makes a crazy amount of annoying noise... good thing I like the truck! Are there any common causes of engine noise? Wondering if the EGR circuit or something may be the culprit, looking for a place to start looking.
    Thanks for the help.
  2. Feb 28, 2013 at 3:27 PM
    LabradorBoy
    Canada
    09 DCab TRD Sport
    It was aligned about 2 yrs ago... I just ordered a set of 5100's in pursuit of a smoother ride, when I get them installed in a couple of weeks I'll go for the alignment as well.
  3. Feb 28, 2013 at 3:30 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Sounds like you need tie rod ends.
  4. Feb 28, 2013 at 3:52 PM
    LabradorBoy
    Canada
    09 DCab TRD Sport
    Ya, I was thinking that too. Are there inners and outers on these like on my 1st Gen?
  5. Feb 28, 2013 at 6:33 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Before you spent anymoney. Tighten wheelbearings. It will take you an hour of your time and costs you nothing. See if you have wandering aftewards
  6. Feb 28, 2013 at 6:36 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Bearings are pressed in and no adjustment can be made..
  7. Feb 28, 2013 at 6:39 PM
    BlueT
    NorthEast
    CV nut is what holds bearing toghether at spec. So it needs to be tighten to spec otherwise bearing and in turn wheel is allowed to move around.
    Just try it OP see if it helps. it helped me on couple vehicles.
  8. Feb 28, 2013 at 6:42 PM
    MonkeyProof
    SoCal- SGV
    If that is the case then the bearing itself is toast. Its just how it is with these bearings
  9. Feb 28, 2013 at 6:52 PM
    BlueT
    NorthEast
    Bearing maybe toast or may have little wear. He will not know until he checks. If truck wanders I would star with that. No point doing alignment on bearings not holding the wheel straight. Both my Toyotas had the same thing and tightening bearings fixed. trucks drove like new. If bearing is toast it will need replacement but no point spending on shocks and alignments if bearings need replacing.
  10. Feb 28, 2013 at 9:58 PM
    sde780
    sde780 Well-Known Member
    Idk if Toyota does this, but Hondas need their steering rack adjusted after some wear and tear. Theyre designed to be adjusted and it's easy to do, YMMV with a Tacoma.
    Did you check the tie rods by jacking the truck up and wiggling the tire?
  11. Mar 3, 2013 at 3:20 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Something else easy to inspect, and there is sort of a TSB a bit related is the steering intermediate shaft. This is a short shaft with u joints near the firewall. The TSB deals with knocking. My 2010 did have the knocking feel in the steering but also had problems returning to center.
    I believe, but could be wrong that this shaft is also a slip joint with universals. I honestly don't remember. Easy to get to, easy to inspect for freeplay. Not saying it is the answer but might be worth a look.
    PK
