Want to add fogs???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RSH904, Jan 30, 2010.
  1. Jan 30, 2010 at 2:39 PM
    RSH904
    RSH904 [OP] Well-Known Member
    Akron, Oh
    Red and Black Attack
    Extang Trifecta Tonneau Painted Stock Wheels De Badged Yellow Fogs AVS Bugflector II UWS Running Boads Hunter Bully Bar HD Satoshi
    :confused:
    Ok help me out guys. I know there have been several posts on this subject but it seems like some of them have contradicting info. I have a 2007 that does not have fogs however it appears to be prewired for them (found the pigtails up on the rebar). Im sure Im oversimplifying this but from what I gather I just need.
    2 OEM Fogs (or am comperables that fit the fog holes in the front cover)
    relay for the fuse block
    oem switch for the dash (plug for the switch is already inside the dash?)
    Will that get me fogs?
    Can anyone post a DIY/Tutorial?
    Do I need any additional parts?
  2. Jan 31, 2010 at 9:32 AM
    RSH904
    Akron, Oh
    No happy helpers?
  3. Jan 31, 2010 at 1:24 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Bump to help you, though I really don't know... Someone here does.
  4. Jan 31, 2010 at 1:32 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    You have the items down correct. It is really plug-n-play. Just pull the tape off the existing pre-wired bundle on the passenger and driver side of the radiator for each fog light connection.
  5. Jan 31, 2010 at 1:35 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    If you have a 4.0L you are prewired.
  6. Jan 31, 2010 at 2:10 PM
    grammy
    grammy Well-Known Member
    Newfoundland, Canada
    4x4 v6 X-Cab
    I have done this and it is that easy.
  7. Jan 31, 2010 at 3:07 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Put fogs on my old 93 yota and was very simple instructions tell all;)
  8. Feb 4, 2010 at 5:49 PM
    RSH904
    Akron, Oh
    OK can anyone who has done this post a pic or diagram if the fuse box so I know where to put the relay. Also what should I buy in regards to the relay. I really appreciate the help.
  9. Feb 5, 2010 at 12:51 PM
    RSH904
    Akron, Oh
    Selfish self bump
  10. Feb 5, 2010 at 2:23 PM
    tomonian77
    tomonian77 Well-Known Member
    Thomas
    Magnolia, TX
    2008 PR DC 4.0
    Painted Rims Black, Painted Emblems Black, Aftermarket Stereo, Grillcraft, BHLM, K&N CAI
    plug the relay in and hhok up the switch. Those 2 will cost about $100.
  11. Feb 6, 2010 at 10:52 AM
    RSH904
    Akron, Oh
    Ok here we go. I have pics. Lead me in the right direction taco guys. I think I have this down just need some clarification. I appreciate you guys being patient with me. So these orange clips under the fender are going to plug into the fogs. Which slot is for the fog switch? (84160-04010 Fog Lamp Switch $34.75) 1,2,3,4,5,6 ??? I marked them. And then does the relay (90080-87010 Relay $16.81) just plug into the box here in one of the empties? which one?
  12. Feb 6, 2010 at 11:02 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Here is a helpful link. I have wired OEM lights for my 5 lug a few nights ago.
    I don't know how the pre-wired Tacomas are setup. But I can help in whatever way I can.
    Do you have an idea where to run the wires for the switch from the relay?
  13. Feb 6, 2010 at 11:21 AM
    400lbGorilla
    400lbGorilla ^Son of a hamster, I smell of elderberries.
    T-LAM
    Ocean City, MD
    BSP 4X4 BASE
    Roof Rack, TRD exhaust, Hood Shield, Side Steps, 5% Tints, Tow Package, Bed Extender, Billies at 2.5, Toytec TSB AAL, Avid Offroad Bar, Cruise Control, Removed Sway, Hella 700s, 6000k HIDs, diff breather mod. DTRL, BHLM,Sockmonkyed.
    Number 1 slot is your Foglight slot. Once you pull the slot you'll see the wires to plug into the switch. I tried asking for clarity on the relay under the dash in the past with no luck. I have a Base 4X4 DC and am prewired also. My OEM switch is wired up but my lights are ran independantly with a hidden cheapo switch (like any aftermarket lights); until I can get the relay ordered and find the place to plug the badboy in.
  14. Feb 6, 2010 at 10:19 PM
    RSH904
    Akron, Oh
    Ok, So I did some investigating myself. If you are prewired Im not even sure you need the relay or fuse at all because they are already there. Since there was nothing fog related in the dash mounted fuse block I checked the apron mounted fuse block. Well the diagram for this one shows a spot for a fog relay and a fog fuse. Guess what? My box already has a fuse and relay in the fog locations. I think I will just be able to plug the fogs and the switch and be good. Any know any different. I posted pics of my fuse block and diagram.
  15. Feb 7, 2010 at 7:42 AM
    RSH904
    Akron, Oh
    Like I said, you might want to check. You may not even need the fuse. Im gonna get the lamps and switch and see if that works.
