Want to firm up my suspension a bit
Discussion in 'Suspension' started by NumNutz, Aug 18, 2010.
  1. Aug 18, 2010 at 8:22 AM
    NumNutz
    NumNutz [OP] One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    I bought a 4X4 truck because I use my 4X4. I don't go wheeling or mudding but I do have to deal with a lot of snow in upstate NY and have a lot of land to take care of. Where I'm going with this is I would like to firm up my suspension a bit for less body roll and better performance in turns while keeping the stock suspension height.
    Any ideas?
  2. Aug 18, 2010 at 8:30 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I'm sure you could put some 5100's all around and it would feel stiffer. And maybe a stiffer set of coils on the front.
    I'd start with that unless someone else has other ides.
  3. Aug 18, 2010 at 8:35 AM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Keeping the stock height may be a bit of a challenge, unless the body roll you're experiencing is more on the front end.
    When I first got my truck I wasn't pleased with the amount of body roll I experienced going around corners and over bumps. Rear TSB springs took care of the back end but that left the front feeling like I was rolling over mashed potatoes every time I went over a bump at any angle other than 90 degrees.
    Adding 5100s to the stock springs up front eliminated most of the "squish". I've never run them at 0" (started at 1.75" and didn't like the look so I dropped to 0.85") so I can't speak for how they ride without at least a little lift. Overall, 5100s are a pretty cheap alternative to firming up the ride quite a bit. If you don't qualify for the Rear Spring TSB then adding 5100s to the back would likely have the same effect.
  4. Aug 18, 2010 at 8:38 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Stiff sway bar? I've never used them but see them for sale and they advertise less body roll.
  5. Aug 18, 2010 at 9:20 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Yea I was thinking 5100s but was looking for a coils and shock options.
    Never heard of a stiff sway bar?
  6. Aug 18, 2010 at 9:43 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Are Timbrens airbags or what? I never really understood what they are or do.
  7. Aug 18, 2010 at 9:47 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Too bad you couldn't get your hands on some Eibachs and 5100's...
  8. Aug 18, 2010 at 9:48 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    :D. I just don't want to lift it. If you want them you can have them.
  9. Aug 18, 2010 at 10:04 AM
    Pugga
    Massachusetts
    http://www.hellwigproducts.com/
    They're supposed to reduce 'roll' in corners. I don't know much about them personally, but when I read what your problem was, this was the first thing that came to mind.
  10. Aug 18, 2010 at 10:12 AM
    WNYTACOMA
    Clarence, New York
    Weren't they only about an inch lift on a 4x4?
    (...though i think i remember your 5100's were set to .85 currently)
    What were you trying to improve on from that set-up?
  11. Aug 18, 2010 at 10:16 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    I could get the shocks dropped back down to 0 I guess.
    See the thing is I really want one of these...
    ...and I could use the cash
  12. Aug 18, 2010 at 10:24 AM
    RItacoNEWBE
    RItacoNEWBE Well-Known Member
    Gerard
    Rhode Island
    2010 trd sport mag grey
    Eibach coils,5100 x4 front set @0,leaf spring tsb,Hellwig rear swaybar, aFe pro dry s,trd front skid plate,weathertech extreme front floor liners, access roll up tonneau
    x 2 on the eibach & 5100,GREAT RIDE:D
  13. Aug 18, 2010 at 10:47 AM
    Pugga
    Massachusetts
    If you set the 5100's to 0 and pair them with the OME 886 springs (from what I've read, they're pretty stiff) would you end up with the same stock ride height or are the springs themselves taller also?
  14. Aug 18, 2010 at 10:53 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    No it would lift the front 1.6"
  15. Aug 18, 2010 at 11:07 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    I saw they had systems for the front as well correct?
  16. Aug 18, 2010 at 11:22 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Okay thanks for your input!!!
