Want your thoughts please!!
Discussion in 'Technical Chat' started by vicky, Jul 20, 2009.
  1. Jul 20, 2009 at 4:25 AM
    vicky
    vicky [OP] Active Member
    Vicky
    Tampa, FL
    Tacoma 4X4 Off Road
    3" lift, Moto Metal Wheels, 32 inch tires, K&N Cold Air Kit, Ipod/iPhone adapter, Blacked out decals, tinted windows.
  2. Jul 20, 2009 at 4:39 AM
    Brunes
    Brunes abides.
    Rotorhead
    What it LOOKS like has no bearing on what it is. A super charger is normally run off a belt or electric power source (more often the belt tho) that runs from the engine. A turbo runs off exhaust gasses piped past a turbine.
    What is your goal in charging the truck?? and what is your budget??
    Can't talk about brakes- but I do know that the brakes on these trucks already limit you to rims 16 inches and larger...Not sure what a big brake kit would do...Lots of folks have had good luck with new OEM size rotors, pads, stainless steel lines, and fluid.
  3. Jul 20, 2009 at 5:12 AM
    vicky
    Vicky
    Tampa, FL
    Tacoma 4X4 Off Road
    Yes I have 17inch wheels. I want a super charger I think over a turbo since it has less lag time? But I do not want to lose what gas mileage when I just drive normal. Thanks for your comments.
  4. Jul 20, 2009 at 5:16 AM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    If you want to keep your warranty stick with the trd if you want to go all out go with urd. Urd actually makes a stock looking pully for the trd supercharger if you want a few more pounds of boost without sacrificing the warranty.
    From what I've read if you're not building boost there is some kind of release valve so the supercharger isn't putting drag on your engine. Also some people reported gaining mpg.
    Sorry I don't know much about brakes.
  5. Jul 20, 2009 at 5:25 AM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah....I'd vote for a S/C over a Turbo any day. MGPs are up to you for the most part. If you are getting into the boost all the time....You are going to lose mpgs...If you drive with a light right foot on the skinny pedal....You should be alright.
    Don't forget with an S/C you will most likely need high test (91/93..I forget what they sell around Tampa) gas.
  6. Jul 20, 2009 at 4:11 PM
    vicky
    Vicky
    Tampa, FL
    Tacoma 4X4 Off Road
    Yes forgot about the gas thing octane thing. Thanks I will check urd for that pulley.
