Wanting to do 6 inch lift???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 4x4srtacoma16, May 20, 2018.
  1. May 21, 2018 at 9:09 AM
    #81
    MCDavis
    MCDavis Taco life is over. Full time 4wd for the win.
    RIC, VA
    2017 TRD Sport 4wd (SOLD) - Currently in a 2016 GX460
    And this is why non drop bracket-ers have some hatred. Hell, I'm annoyed to be associated with this...
    alwaysHI likes this.
  2. May 21, 2018 at 9:14 AM
    #82
    motodude95
    motodude95 Well-Known Member
    Jim
    2012 MGM TRD Sport DCLB, OME 886s, 33s
    6 inch lift on these little trucks is a little obnoxious. Everyone with a rough country 6 inch lift is either an obese teenager with bitch tits or 5' 1
  3. May 21, 2018 at 9:22 AM
    #83
    4x4srtacoma16
    4x4srtacoma16 [OP] Well-Known Member
    Jon
    4x4 sr 2016 tacoma 5 speed manual 4 seater
    Weather tech floor liners Kryptek mandrake full seat covers
    You have the 6 inch?
  4. May 21, 2018 at 9:23 AM
    #84
    4x4srtacoma16
    Jon
    But in 30 5'9 145lbs...... will it work for me :rasta:
  5. May 21, 2018 at 9:28 AM
    #85
    kylemonty18
    kylemonty18 Member
    kyle
    Yes
  6. May 21, 2018 at 9:35 AM
    #86
    4x4srtacoma16
    Jon
    Is it rough country lift? I was looking at the zone 6 inch and the drop bracket looks like it' better built.
  7. May 21, 2018 at 10:22 AM
    #87
    4x4srtacoma16
    Jon
    Yes excactly!
    ChadsPride likes this.
  8. May 21, 2018 at 11:10 AM
    #88
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    Well, let's see. Years of research! And all I was providing was a little caution before proceeding with modifications that could cause warranty issues in the future.
    1. When you lift a suspension, be it with or without a drop bracket. You change the angles and or locations of various drivetrain components. Specifically, with a drop bracket, you lower the front differential. As a result you're changing angles of propeller shaft, carrier bearing, transmission, and transfer case. The dealer to make a case of these changes and angles have worn out equipment in these components early.
    2. I never recommended my suspension to anyone. I even said it would be completely overkill for the OP's intended use. My suspension was only mentioned as an answer to a direct question.
    3. I have never heard anything good about Rough Country, but I've read many good reviews of BDS.
    4. If your dealership installed the left, they usually if not always include that in the warranty. But my understanding for this is that it needs to be written in and included in the warranty at that time.
    I've spent years on Tacoma World and Other forums reading about failed warranty claims due to modifications. And prior to that I had an lx450 in there was highly modded too. And I spent a couple years and IH8MUD forum also reading about failed warranty claims due to modifications. I have also read the rule of law that regulates warranties in relationship to modifications.
    I myself took those steps and made modifications that risk of voiding my warranty for various issues. I've drilled the frame for skid plates. I have welded sliders on the frame. I've cut the main positive battery cable for a dual-battery install. And I have a 3 inch suspension. All of these modifications can result in a refusal of warranty for components that may be affected by these modifications.
    I did none of these modifications blindly..researched and weighed out the risk before doing it.
  9. May 21, 2018 at 11:36 AM
    #89
    jeremy5000
    jeremy5000 Well-Known Member
    Philadelphia
    What are you talking about? Do you expect a stock setup to be capable of being launched 40 feet?
    DirtJumper14 and PNW/TRD Steve like this.
  10. May 21, 2018 at 12:35 PM
    #90
    4x4srtacoma16
    Jon
    No just saying neither a stock truck or a truck with a lift would handle that. Depends on what happends to the truck
  11. May 21, 2018 at 12:36 PM
    #91
    ChadsPride
    Sponsored by TacomaWorld.com
    I personally love big lifts and tires on these Tacomas.
    Just do some research and make your best educated decision.
    Good luck on your quest!!!
  12. May 21, 2018 at 1:00 PM
    #92
    no vtec 4me
    no vtec 4me Well-Known Member
    Kevin
    West Chester, Pa
    2017 Tacoma TRD Sport
    Just buy the Rough Country, get it installed and report back. If you like it, you got a nice lift for $1k that makes you happy. It sounds like you’re pretty convinced already. If you hate it, then oh well, you can always upgrade to the BDS later on :)
  13. May 21, 2018 at 1:26 PM
    #93
    4x4srtacoma16
    Jon
    Yea I can always switch down the road. But what if the drop bar has to be welded in? If they have to be welded in i might as well go with the bds
  14. May 21, 2018 at 2:34 PM
    #94
    no vtec 4me
    Kevin
    West Chester, Pa
    I believe they are both no-weld.
  15. May 21, 2018 at 2:45 PM
    #95
    Long Time Toy Fan
    Long Time Toy Fan Well-Known Member
    17 DCOR
    Cookie cutter Tacoma, 888/Dakars/LR/ECGS/Sliders
    Some bad info on this thread in the beginning. Read this thread for an idea of how a 4" RC goes in with custom mods you should copy to make it plenty tough. https://www.tacomaworld.com/threads/bro-coma-3rd-gen-build-30-bro-60-build-and-25-bs.461225/ I believe it's that thread that also says the RC drop bracket is 3.5 inches on both the 4" and 6" where as the BDS one uses a 6" DB. I couldn't tell you if that's true or not but that alone makes me prefer Rough Country over Big Dick's Suspension. I am a fan of the 4" Rough Country kit with Diablo's mods, looks plenty stout to me with good clearance and a-arms in mid travel for a smooth ride. Can't really say for durability because I haven't owned one...
  16. May 21, 2018 at 3:09 PM
    #96
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Buy the kit and report back too us.
  17. May 21, 2018 at 3:12 PM
    #97
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    The BDS / Zone kits only drops the bracket 4.5 from center bolt to center bolt on the 4" and 6" lift kits.
  18. May 21, 2018 at 3:15 PM
    #98
    Bishop84
    Bishop84 Well-Known Member
    Usually have to weld the steering stops onto the knuckle, Rough country has a bracket that bolts onto the ball joint.
    I always encourage people to weld the seam on the drop bracket for rigidity.
    So many 6" people in here crying about misinformation but I've installed probably 15 and seen 2 in small accidents that bend the frame due to the inherit weakness of cutting the cross member and relying on cheap lateral bars to provide strength.
  19. May 21, 2018 at 4:37 PM
    #99
    Long Time Toy Fan
    17 DCOR
    Bishop, nice to hear first hand info. It was your comment in particular I was referring to about a 6" spacer on top of stock suspension. I see now you that you meant that spacer along with spindles and a drop bracket etc, my bad. If you get a chance to have a look at that thread I linked to Diablo169's build I'd like to hear your opinion on his modifications. Where was the bend on the frame you mentioned? You think it needs fish plating?
  20. May 21, 2018 at 6:00 PM
    #100
    4x4srtacoma16
    Jon
    So as long as I dont crash the truck or slam into a tree stump at 60 mph I should be fine
