Wanting to get new headlights and taillights. Opinions needed
Discussion in 'Lighting' started by dwh182, Dec 29, 2014.
  1. Dec 29, 2014 at 7:37 PM
    dwh182
    dwh182 [OP] New Member
    I have a black '09 tacoma and am wanting some black HALO headlights and tail lights. I am wondering what Yall opinions are and which yall would suggest I get. I would like to keep it around $150 for each set
  2. Dec 29, 2014 at 7:42 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    You best bet would be to retrofit your headlights you have now. For a set (with the TW 25% discount) is around $240. Projector light you buy off ebay suck. And if you want a retrofit built for you its about $500-$800 depending on options. Do it yourself, its pretty easy!
    Here is the link to the TW ongoing group buy
    http://www.tacomaworld.com/forum/group-buys/262802-retrofit-source-ongoing-gb-via-andrew-trs.html
    Here are some pics to get you an idea
    http://www.tacomaworld.com/forum/li...-projector-retrofit-completed-headlights.html
    Here is how to do FXR projectors. I would reccomend D2S because its a lot easier and has about the same light output
    http://www.tacomaworld.com/forum/lighting/303795-how-retrofit-morimoto-fx-r-mini-h1-depth.html
  3. Dec 29, 2014 at 7:52 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    I thought the same thing, but them I realized that the existing OEM lighting is more than sufficient for driving. The OEM system actually induces high beam flashbacks from oncoming traffic when my lights are on low.
    I then decided that money would be best spent on additional offroad/work lights.
    Depends where you want to go with your build.
  4. Dec 31, 2014 at 12:27 AM
    refugee
    refugee Member
    Allan
    Missouri
    08 TRD, Off-Road, Access, 4X4, 4.0L
    Im waiting for new headlight & taillight housings but Im not changing the lights themselves, the bulbs will be the same ones that are in the stock housings now. I have a black truck so I bought black background headlight housings and euro style taillight housings. The justification was that I need to replace one taillight housing because somebody cracked one when they hit my truck and skedaddled. I got the housing kit from ebay...we'll see if they suck.
