Wanting to regear in the future and might as well put a locker in.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08BlackenedTaco, Apr 14, 2012.
  1. Apr 14, 2012 at 9:46 PM
    08BlackenedTaco
    08BlackenedTaco [OP] Well-Known Member
    High Point, NC
    Prerunner Murdered....
    14" magnaflow maxflow muffler, intake mod, black headlight mod. VHT Nightshades tail lights, painted stock rims.
    So im looking now because after installing my3" lift and 33" tires my prerunner open diff is a little slower, so i figured hopefully soon ill want to regear it to 4.10 or 4.56. and if i do that i might as well put a e-locker in. to save a shitload of time is there any tacoma third members with 4.10's and an e-locker? if not what locker should i put in along with 4.56's?
  2. Apr 14, 2012 at 9:49 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    the "8.4" is a different 3rd than the elocker one iirc
    best bet is to save up and go with an ARB locker with either geat choice.
  3. Apr 14, 2012 at 9:54 PM
    08BlackenedTaco
    High Point, NC
    Detroit truetrac? and ARB is too much hassel. then i gotta get a friggin air compressor and shit im not that serious about it. lol
  4. Apr 14, 2012 at 9:56 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Call east coast gears. No e locker for you. It's not compatible with your axle.
  5. Apr 14, 2012 at 10:03 PM
    08BlackenedTaco
    High Point, NC
    so what would you suggest since i cant have an e-locker?
  6. Apr 14, 2012 at 11:41 PM
    08BlackenedTaco
    High Point, NC
  7. Apr 15, 2012 at 6:07 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    If your not that serious remember many of the other lockers do not do well with daily driving.
  8. Apr 15, 2012 at 8:10 AM
    TrdSurgie
    TrdSurgie revised
    SoCal
  9. Apr 15, 2012 at 9:09 AM
    08BlackenedTaco
    High Point, NC
    ok, so no locker or LSD for me ? :( screw this rear end.
  10. Apr 15, 2012 at 9:12 AM
    TrdSurgie
    TrdSurgie revised
    SoCal
    You can. Its one of those get what you pay for deals. I run a 2006 tundra diff with factory lsd. They come in 3.9 4.1 and 4.3
    The detroit would be fine. But a selectable would be best.
  11. Apr 15, 2012 at 9:50 AM
    08BlackenedTaco
    High Point, NC
    I would just switch to the tundra but i know a locker is better than LSD. because theres a huge mudhole close the the house where are the rednecks go and i want to play sometimes. :)
  12. Apr 15, 2012 at 10:12 AM
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
    ^^^ This is the route I will be going
  13. Apr 15, 2012 at 10:22 AM
    08BlackenedTaco
    High Point, NC
    I'm really not that serious, ill probably go in the mud maybe 2 or 3 times in a year. MAYBE. so an ARB to me would seem like a waste. and I've been looking at the Lock Right locker. they have one for the 8.4" rear diff. and I wouldnt mind not gassing around a corner. what do you guys think? i just need a cheap option for a locker. to use it maybe 2 or 3 times a year.
  14. Apr 15, 2012 at 10:45 AM
    Bogg
    Surrey, Canada
    07 TRD Sport 4x4
    I like the idea of a selectable locker as it's there when I want/need it and when I don't I just turn it off. If you get the High output compressor it can also be used for other things, not just to engage the locker.
  15. Apr 15, 2012 at 10:56 AM
    08BlackenedTaco
    High Point, NC
    Nope, i just want one :) lol
  16. Apr 15, 2012 at 3:21 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    4.88s w/h rear Powertrax locker, Fox 2.5 Ext. RR COs, Camburg 1.25” ucas, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, 315/75/16 BFG KM2, 16x10" custom beadlocks, BFF front hybrid, GSF rear HC, Relentless Fab ifs skid, BAMF lca skids, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, LCE Dual Comp clutch, URD ss, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, ARB compressor, Grillcraft, FXR TRS, T1 eyelids, 500 hellas w/h 6k hid conv., custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers, Weather Tech
    damn theres a lot of negativity in this thread! OP to answer some of your previous questions, if you want to re-gear, for whatever the reason is, it will only help your truck and if you want to put in a locker, for whatever the reason is, its a good idea to do it at the same time. YES, it sounds like an ARB would be best because it is selectable. YES, between the locker, compressor, and install it is a lot of money for something to be used 2,3 times a year. NO, it is not tha only option. YES, a Lock Right Powertrax no-slip is a very good street locker (thats what its built for), a lot cheaper, and should fit your needs just fine!
  17. Apr 15, 2012 at 6:18 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    You don't "need" a compressor with an ARB. I just have a two gallon air tank I fill to 100psi. I can lock the the arb about 500 times and it will go down to 80psi. I filled it last December and haven't topped it off yet, still at about 90psi wheeling almost every weekend. I have nitrogen as a back up, but haven't needed it once. That said, a lock right will be just fine for what you do.
  18. Apr 16, 2012 at 6:50 AM
    08BlackenedTaco
    High Point, NC
    Thank you guys for the answers i was looking for! I really appreciate the help. Looks like im gonna go with a lock right and 4.56 gears then. Thanks again!
  19. Apr 16, 2012 at 11:53 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I'm looking at the Powertrax No-Slip locker. Any feedback from users on that one?
  20. Apr 16, 2012 at 1:15 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    well, give me about 2 weeks and ill have mine in and can tell you:p
