Wanting to regear in the future and might as well put a locker in.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08BlackenedTaco, Apr 14, 2012.
  1. Apr 16, 2012 at 1:17 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Yes!
    Send me a PM or something. I'm very interested to hear how it performs!
  2. Apr 16, 2012 at 2:05 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    :thumbsup:
  3. Apr 16, 2012 at 3:28 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Why do you say that? As I understand it, the No-Slip is the roadworthy brother of the Lockright.
  4. Apr 16, 2012 at 3:33 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    if you want a full time locker thats built for the street, but obviously is a locker and does what its supposed to do offroad, the no-slip is the best choice! I agree that if it is STRICTLY a street truck go with an LSD but the OP says he also wants to offroad
  5. Apr 16, 2012 at 3:50 PM
    08BlackenedTaco
    08BlackenedTaco [OP] Well-Known Member
    High Point, NC
    Prerunner Murdered....
    14" magnaflow maxflow muffler, intake mod, black headlight mod. VHT Nightshades tail lights, painted stock rims.
    I'm gonna have to take a look at this no-slip. but so far ive found out i need a Bearing Carrier drop kit, squeeky leaf pack fix,put a locker in, and need to regear. LOL and about the regearing should i just take the third member out and bring it to east cost gears? what parts do i need to buy if i do that? obviously ring and pinion gears but what else to hand them and say just do the install. so i can get the parts cheaper.
  6. Apr 16, 2012 at 3:59 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    master install kit and gear and pinion! That is all my friend!:D
    and why do you need a bearing carrier drop?
  7. Apr 16, 2012 at 4:04 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I would call ECGS and talk to Chase. My experience has been that he has what you want already assembled on the shelf. You hand him your third, he hands you what you want. You can't get parts cheaper than Chase does, no need to screw yourself and buy parts somewhere else.
  8. Apr 16, 2012 at 4:20 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Click click click click, screech click click.
  9. Apr 16, 2012 at 4:29 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    sounds like your best bet OP
    women know best! Listen to them;)
  10. Apr 16, 2012 at 5:08 PM
    ItalynStylion
    Steven
    DFW, Tx.
    I don't understand the thought behind uneven tire wear. If you were Derek Zoolander and only made right hand turns your entire life it would make sense. However, most of us generally turn both left and right so wouldn't the end result end up fairly even?
  11. Apr 16, 2012 at 5:16 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Pretty much.
  12. Apr 16, 2012 at 5:43 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Rattles and squeaks? Pshhh, my beast is solid like a brick house. It's about as aerodynamic as one too lol
  13. Apr 17, 2012 at 5:45 AM
    08BlackenedTaco
    High Point, NC
    changed my mind today and might go with LSD, i was going on an on-ramp yesterday and it goes up and loops to the right. and the only thing i could think of was if i had a locker and it was wet i wouldn't be able to drive up it.
  14. Apr 17, 2012 at 6:09 AM
    ItalynStylion
    Steven
    DFW, Tx.
    What do you mean you wouldn't be able to drive up it?
  15. Apr 17, 2012 at 6:10 AM
    #35
    ItalynStylion
    Steven
    DFW, Tx.
    PS: Are there any good LSD's for the front?
  16. Apr 17, 2012 at 6:20 AM
    #36
    ItalynStylion
    Steven
    DFW, Tx.
    Damn....would love to have ATRAC on my Sport with a locker in the rear. I would be happy as a clam.
  17. Apr 17, 2012 at 7:10 AM
    #37
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I have an Auburn Gear lsd in the rear. I've had it installed for about a year now and been on several 4x4 trips where it's come in handy-one of those, I really wished for a full locker was a steeper section of loose rock and other forest debris-spotters said there were a couple of times with rear wouldn't lock. The truck is my daily driver-no problems there either.
  18. Apr 17, 2012 at 9:25 AM
    #38
    08BlackenedTaco
    High Point, NC
    a locker like no-slip is only locked when pressure is applied (gas applied). so with an on-ramp that is uphill and to the right. you have to apply gas the whole time during the loop. if its wet and you have that locker, you will basically drift the whole loop with wheels spinning. lol
  19. Apr 17, 2012 at 9:46 AM
    #39
    ItalynStylion
    Steven
    DFW, Tx.
    Yes. It absolutely helps but it's not quite ATRAC. I experienced it's help on Sunday at an offroad park and was quite pleased.
    Fo-shiz...
  20. Apr 17, 2012 at 9:54 AM
    #40
    08BlackenedTaco
    High Point, NC
    You got it? gas it in a turn and see what happens (now add wet pavement). you probably dont use the gas in a turn. it unlocks because there is no pressure when gas is not applied.
